trebor Posted January 14, 2015 Share Posted January 14, 2015 Daft question but it's niggleing me. On a plane with twin alleron servos one for each side, you fit a Y lead or can you assign a spare channel in tx to work the second alleron servo ? Quote Link to comment Share on other sites More sharing options...
Steve T Posted January 14, 2015 Share Posted January 14, 2015 Y lead, very simple just set your servo movement up opposite way to each other, if you get me. If you used two channels on a reciever you would need two tx functions as well, I know what I mean anyway. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted January 14, 2015 Share Posted January 14, 2015 If you've got a modern radio with even basic mixing it's not a problem to set up differential ailerons. Flick through your radio's manual, it'll be there somewhere. Y leads are OK, but getting the mechanics correct at the servo can be a pain, and of course with the tranny doing the mixing the individual aileron throws and rates can be finely set. Edited By Cuban8 on 14/01/2015 13:01:31 Quote Link to comment Share on other sites More sharing options...
John Lee Posted January 14, 2015 Share Posted January 14, 2015 Either. Y lead - one less connection, one less channel 2 channels - Can trim individual servos. Can set up differential. Most modern radios have a dedicated set up for using 2 channels in the Tx menu. Quote Link to comment Share on other sites More sharing options...
Pete B Posted January 14, 2015 Share Posted January 14, 2015 On your DX6, select 'Dual Aileron' in the 'Aircraft Type' menu. Connect the starboard wing aileron lead to the aileron ch on the Rx and the port wing aileron lead to the Aux1 ch. This is pretty well universal for the Spekky system. If you want flaperon or spoileron function on the ailerons, select 'Flaperons'. This will enable access to the Flap menu for moving the ailerons in unison, whichever way you wish. Pete Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 14, 2015 Share Posted January 14, 2015 My own experience with sports and semi scale models there is no advantage in using differential aileron. I have experimented, particularly with models which initially had handling issues, with differential. Not on one occasion did I see any benefit, most disappointing. On that basis i tend to go for a "Y" lead. The main advantage i have found in using two channels is on deltas and flying wings, where they become elevons. Quote Link to comment Share on other sites More sharing options...
trebor Posted January 14, 2015 Author Share Posted January 14, 2015 Well the only reason for asking is I got an Efilte 330 sc for Christmas. It's a profile fuselage and the channel for the cables is very small the cable plugs and sockets will hardly fit in. I was thinking of cutting rudder and elevator plugs off and solider wires together which would be easier to get them in. The Y lead I don't think would go in and the servo plugs would be better going straight into Rx on the outside of fuselage. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 14, 2015 Share Posted January 14, 2015 I wouldnt recoment soldering Rudder and Elevator servos together - might make for some "interesing" control issues!!!! But soldering and extention lead to a servo is fine, I habitually do it in wings so there is less possibility of a disconnection between RX and Aileron servos Quote Link to comment Share on other sites More sharing options...
trebor Posted January 14, 2015 Author Share Posted January 14, 2015 Sorry I forgot to say the bit about extension wires, it's more fiddly than I thought Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 14, 2015 Share Posted January 14, 2015 It is fiddly if you try to terminate the extention wires into plugs yourself, me I cheat and snip the supplied plug of the servo lead, the splice in the desired length of wire and re-use the plug.. 6 soldered jooints, or like me 12 if you forget to slip the heatshrink on first!!! Quote Link to comment Share on other sites More sharing options...
trebor Posted January 14, 2015 Author Share Posted January 14, 2015 I'll have to get some wire, I've just cut the plugs off and extended. Also forgot to put shrink tube on one lead had to do it again. What a twit. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 14, 2015 Share Posted January 14, 2015 What I've done a few times is to remove the servo lead pins from the plastic housing, feed the end of the lead through the tunnel then replace the housing. No soldering required. I found it's possible to get the wire with pins fitted through a snake outer, which is useful if you want to update an old wing to twin servos. Quote Link to comment Share on other sites More sharing options...
