iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Back to the front end, another gamble, G160 still out of stock but G110 is same prop adapter dimension so decide to fit the spacing piece at back of spinner first picture shows its made from 4 pieces, this reduces the end grain on finished item... and how it finally ended up complete with air inlet hole Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Thanks colin....thats one of the hardest parts for me.....not that good with bending balsa, not bad with filler and sandpaper.... hang on... i`m not that good at sanding either, I always go to far... Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Next part is the worst for me, dont like doing wings........first is the stab, this is using - Dave Snow design , details can be found using links on page 1....I would not have even attempted without a jig.... The sleeve is a page from a magazine, and worked well... I did not imagine they would turn out this good, well pleased with the results and game me confidence to start the wings Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Wings - first the jig - making sure to drill holes in the right place in fuz.... This time its a sleeve from Slec, bought with the tube..... End result , once again very pleased with Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Air outlet hole done..... Motor and ESC arrived. if you use the Yep then you need a programing card - thanks again GM... Now I have everything it was time to decide on how I was going to cover, was an easy decision based on HK covering being out of stock once again, and I quite fancied a go a glassing.Having watched Danny Fentons vid`s re covering .....more weight but more ding proof...... Have used 25g cloth and Polyester resin....smelly and takes a long time and needs to be at least 20c for this to cure, luckily SWMBO was away that week.... 1 tip I read somewhere on the net is to go over the area with a hair brush, this helps the cloth to stay put. and dont forget to wear gloves as the cloth will fray easily.... Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Time to start painting, never done anything like this before, used spray paint in tins....and plenty of them having asked for advise on here I purchased Tamiya and frog tape.....and in my opinion the Tamiya tape gave a professional finish..... I did want to purchase a slotted spinner for this for more air in but as you can see it would not have worked The lettering was bought through Ebay from - signsbypost.com and was delivered within 2 days.... Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Since completion I entered it into our clubs winter build and came a lucky 2nd....The following day It went for its maiden . Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 I just want to add - if you build this for F3A - use carbon wing tube and dont glass at least not all of it.....mine is over the limit.....If i changed the wing tube and fitted smaller batteries it "may" be under......I dont do competitions ,so it makes no difference to me, I would rather have it more suitable for my flying skills...IE ding proof...... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 25, 2015 Share Posted April 25, 2015 Cracking job Iqon, looks good and straight as a die John Quote Link to comment Share on other sites More sharing options...
Bob Rowland Posted April 25, 2015 Share Posted April 25, 2015 Looks Great mate! Is there enough of an exit for cooling purposes? Cheers Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Thanks Bob. The exit hole is big enough, only had the one flight so far and everything cool, however as you know the more you get used to them the more it will get pushed so will be keeping my eye on it... PS thanks John . will let you have a go at carrying it tomorrow....... Edited By iqon on 25/04/2015 19:19:15 Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 25, 2015 Share Posted April 25, 2015 Super build.....you should be deservedly proud Quote Link to comment Share on other sites More sharing options...
iqon Posted April 25, 2015 Author Share Posted April 25, 2015 Thanks Cymaz.. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 26, 2015 Share Posted April 26, 2015 What did it weigh in the end Iqon? Quote Link to comment Share on other sites More sharing options...
iqon Posted April 26, 2015 Author Share Posted April 26, 2015 Will let you know, not actually weighed it since finished, think its around 5.5kg flying weight , thats with 5000mah batteries.. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted April 26, 2015 Share Posted April 26, 2015 Lovely job Iqon Well done an inspirational build blog Martyn. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 26, 2015 Share Posted April 26, 2015 Iqon, I take my hat off to you. To get to 5.5 ish KG for a first build F3A which looks as good as it does is amazing! Quote Link to comment Share on other sites More sharing options...
chris Bond - Bondaero Posted April 26, 2015 Share Posted April 26, 2015 Great to see this great build thank you for sharing Quote Link to comment Share on other sites More sharing options...
iqon Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks Martyn, thanks Peter I always new I could build it lighter , especially if i did not glass and use carbon wing tube, other`s have come out flying weight around 4.6 to 4.8 kg I`m sure mine was around 4.2kg plus batteries It`s deffinatley an interesting build and I am sure i will be building another at some time in the future Quote Link to comment Share on other sites More sharing options...
iqon Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks Chris.... Quote Link to comment Share on other sites More sharing options...
Martyn K Posted April 27, 2015 Share Posted April 27, 2015 Hi iqon Regarding the HK YEP ESC - I was wondering how you manage to keep it cool, there doesn't seem to much of a heatsink fitted. Martyn Quote Link to comment Share on other sites More sharing options...
iqon Posted April 27, 2015 Author Share Posted April 27, 2015 Hoping it will stay cool coz its oversized...untill it`s had a few more flight I wont really know motor running at 74A on 19 x 12 prop.ESC 120 - 140 max Quote Link to comment Share on other sites More sharing options...
Martyn K Posted April 27, 2015 Share Posted April 27, 2015 Thanks iqon The setup that you have used looks like an economical way of getting started in 2m F3A. Very useful indeed. Martyn Quote Link to comment Share on other sites More sharing options...
iqon Posted April 28, 2015 Author Share Posted April 28, 2015 Here is another one Quote Link to comment Share on other sites More sharing options...
