iqon Posted January 25, 2015 Share Posted January 25, 2015 Having a go at building one of these Details can be found here progress will be slow to start, formers to cut out and jig to make I`m in no rush to be outside I dont do cold anymore........ Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted January 25, 2015 Share Posted January 25, 2015 It's the type of model i wouldn't mind having a go at, so I'm subscribed. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 25, 2015 Share Posted January 25, 2015 That's a nice looker Iqon, plenty of pictures please John Quote Link to comment Share on other sites More sharing options...
iqon Posted January 25, 2015 Author Share Posted January 25, 2015 I`ll be asking questions ( and borrowing your tools ) ... Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 Jig ready to put together, still doing formers , coming along nicely for my first attempt. Starting to look at motors if anybody has a suggestion of a budget motor to run on 10s.compatible with a Turnigy dlux esc if possible. I suspect it will need to be around 220kv to 250kv Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 28, 2015 Share Posted January 28, 2015 Bit of delicate cutting in there Igor, coming on nicely buddy John Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 It`s easy when you borrow the right tools....... Quote Link to comment Share on other sites More sharing options...
chris Bond - Bondaero Posted January 28, 2015 Share Posted January 28, 2015 Watching with interest. The Turnigy G160 appears to be pretty well regarded for the money but perhaps heavy. I have just bought one of these Not yet flown but run up on the ground and appears a good cheap contender on a 20x13 prop with 10s Also the euro is currently only about 75p **LINK** Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 Thanks Chris , I will have a read of that later.... Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 Anybody have any experience with - Dualsky XM6355DA F3A-12 MOTOR 223KV... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 28, 2015 Share Posted January 28, 2015 No and we don't have a link either Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 Just for you John it here Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 28, 2015 Share Posted January 28, 2015 Try a question in the improve your aerobatics thread ? John Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 time to start on the fun bits - 1/8" ply and carbon fibre cloth Quote Link to comment Share on other sites More sharing options...
iqon Posted January 28, 2015 Author Share Posted January 28, 2015 Posted by john stones 1 on 28/01/2015 22:08:14: Try a question in the improve your aerobatics thread ? John Good idea Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 29, 2015 Share Posted January 29, 2015 Looks very interesting - subscribed M Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 29, 2015 Share Posted January 29, 2015 Just downloaded the parts plans - the wing parts plan looks OK, but the fus parts plan is reduced. Have you managed to scale this or did you manage to get a full sized plan from somewhere? Or are you building the kit? If so, what did you actually buy? So many questions... Thanks M Quote Link to comment Share on other sites More sharing options...
iqon Posted January 29, 2015 Author Share Posted January 29, 2015 Hi Martyn - for plan - go to here ,If you read through the build you will find that you have to ask for them , Jeff will send them via email there is a pdf of wing and stab parts and jig - link for pdf is just above shortkit price list on here the one you downloaded is of no use, dont know why they have put that on ....... Edited By iqon on 29/01/2015 10:24:10 Quote Link to comment Share on other sites More sharing options...
iqon Posted January 31, 2015 Author Share Posted January 31, 2015 I`m still here plodding away, started to cut wing & stab ribs out & still putting CF cloth on formers. I read last night that the spec of the G160 is higher than advertised and at 250 W/LB should be more than enough. starting to look at ECS`s - want 100+ A opto , there is only 2 in the running - Gecko & Dlux - Is the Gecko compatible. are there any other reasonable priced ones I have not found Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted January 31, 2015 Share Posted January 31, 2015 Have you considered this one? YEP 120A HV Quote Link to comment Share on other sites More sharing options...
lightning 759 Posted January 31, 2015 Share Posted January 31, 2015 hi looked at title thought great , had a look at thread not a proper lightning NO AVONS shame andy Quote Link to comment Share on other sites More sharing options...
iqon Posted February 6, 2015 Author Share Posted February 6, 2015 Building jig done, let the fun begin Quote Link to comment Share on other sites More sharing options...
iqon Posted February 7, 2015 Author Share Posted February 7, 2015 All formers that fit to jig in place, F1 bolted into place using washers as spacers giving me down and right thrust, CF covered ply stringers put into place at front and glued .. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 7, 2015 Share Posted February 7, 2015 Unusual method, looks like a model you would build in 2 halfs usually, at what stage will the jig come out...will some sheeting be added before then ? John Quote Link to comment Share on other sites More sharing options...
iqon Posted February 7, 2015 Author Share Posted February 7, 2015 Undercarriage in plus locking plates. It will be getting another layer of ply on top of this as i intend to use T nuts for UC ,so far its all going together nicely... JS - It stays on the jig until the top half is sheeted, then hopefully you can take it off..... Quote Link to comment Share on other sites More sharing options...
