Adrian Smith 1 Posted March 4, 2015 Share Posted March 4, 2015 I used to get small O-rings from ModelFixings to use with small screws for fixing cowls to the fuz or for attaching a canopy. However, I don't see any on their website any more. They stock 3 sizes of grommets but they are way too big. Any idea where I can source them from? Thanks. Quote Link to comment Share on other sites More sharing options...
David P Williams Posted March 4, 2015 Share Posted March 4, 2015 Er - they appear about halfway down the page here, along with the servo screw listings. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted March 4, 2015 Author Share Posted March 4, 2015 As usual David can't see beyond my nose! Thank you. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 4, 2015 Share Posted March 4, 2015 Try Ebay. I have found lots there. Quote Link to comment Share on other sites More sharing options...
onetenor Posted March 5, 2015 Share Posted March 5, 2015 Also gas fitting suppliers. Quote Link to comment Share on other sites More sharing options...
will -0 Posted March 5, 2015 Share Posted March 5, 2015 Simply bearings have a good selection (and do bearings too) often cheaper than modelfixings. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 29, 2015 Share Posted April 29, 2015 Try using thin neoprene tubing ,the type used for air retract to make you cowling grommets from. First fit you cowl and make sure your happy with positioning having drilled holes that are just clearance for the screws Now remove all screws an fit a cut length of the tubing to the screws. The length needs to be the thickness of the cowling plus 2mm. Now push or screw this up to the head of the screw. Drill the holes in the cowling for a snug fit on the tubing when fitted to the screw. Screw up and the neoprene will slide through the hole and as it compresses it makes shoulder both sides of the cowling. It also protects the screw and cowling from the effects of any vibration stopping screws from loosening. Quote Link to comment Share on other sites More sharing options...
Andy Butler Posted April 29, 2015 Share Posted April 29, 2015 I use a small sliver of fuel tube, about 2-3mm and this works very well. Comes in different diameters too. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 29, 2015 Share Posted April 29, 2015 Engine doctor is a genius, I would never have thought of that. Pure genius, thank you, made my day. Quote Link to comment Share on other sites More sharing options...
will -0 Posted April 29, 2015 Share Posted April 29, 2015 Hello. I use simply bearings for bearings and o-rings http://simplybearings.co.uk/shop/ Quote Link to comment Share on other sites More sharing options...
IanN Posted April 30, 2015 Share Posted April 30, 2015 I've found this seller **LINK** useful for small o rings Quote Link to comment Share on other sites More sharing options...
