Anybody Know Where To Get Miniature/Micro O-Rings?
  • 1 month later...
Try using thin neoprene tubing ,the type used for air retract to make you cowling grommets from. First fit you cowl and make sure your happy with positioning having drilled holes that are just clearance for the screws Now remove all screws an fit a cut length of the tubing to the screws. The length needs to be the thickness of the cowling plus 2mm. Now push or screw this up to the head of the screw. Drill the holes in the cowling for a snug fit on the tubing when fitted to the screw. Screw up and the neoprene will slide through the hole and as it compresses it makes shoulder both sides of the cowling. It also protects the screw and cowling from the effects of any vibration stopping screws from loosening.
