Gary Vinten 1 Posted April 28, 2015 Share Posted April 28, 2015 Hi all does anybody know how to add rudder to my throttle on takeoff Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 28, 2015 Share Posted April 28, 2015 Yes....in a Pmix if you have futaba. Or use the throttle as a master control and rudder as a slave, then dial in some % rate to adjust the movement. Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted April 28, 2015 Share Posted April 28, 2015 It's normal to use a thumb. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 28, 2015 Share Posted April 28, 2015 Posted by john davies 8 on 28/04/2015 19:40:31: It's normal to use a thumb. Oh, that as well.....oops Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted April 28, 2015 Share Posted April 28, 2015 Probably a great deal easier to use the Mk1 Thumb - other than that you would been something like a flight mode to dial is some rudder when that mode was selected but not during normal flight Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted April 28, 2015 Author Share Posted April 28, 2015 Sorry fogot to mention I have a taranis Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 28, 2015 Share Posted April 28, 2015 Most planes will tend to yaw one way as the power is added, due to the P effect, but as airspeed increases this takes over and you don't need the rudder to counteract the yaw. So if you were going to try and control this with a mix you'd need to have two inputs, throttle and airspeed, you could always do what some of the scale guys and others do and put a gyro on the rudder servo................ Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 30, 2015 Share Posted April 30, 2015 Posted by Gary Vinten 1 on 28/04/2015 20:21:54: Sorry fogot to mention I have a taranis wink No need to apologise, this is the FrSky forum after all, not sure why Futaba solutions were being suggested... If you want right rudder to come in with increasing throttle, just add in an ADD mixer line under the rudder, source Thr, weight and offset equal at (say) 15%, and set it to be activated by a switch of your choice or (even better) a Takeoff flight mode. If you want to get advanced you could even use logical switches with time functions to make this activate only once on the initial throttle up after selecting Takeoff flight mode. As always with OpenTX, anything is possible, you just have to think it up! Edited By MattyB on 30/04/2015 01:55:33 Edited By MattyB on 30/04/2015 01:59:16 Edited By MattyB on 30/04/2015 02:00:37 Quote Link to comment Share on other sites More sharing options...
