iqon Posted October 17, 2015 Share Posted October 17, 2015 First let me start by saying this is a petrol trainer, so if the mods want to move elsewhere, please feel free to do so..... This is described as a basic trainer, but its also aerobatic trainer. Wingspan = 83", Length =60", Flying weight11.6lb,Engine = 20cc to 30cc. Everything arrived well packaged, taped to the box, no chance of anything moving. First impressions - undercarriage looks very strong, wing tube feels heavy, covering looks excellent. But wait, next day on further investigating, Only 2 of the 6 undercarriage holes have been drilled all the way through,decals on wing dont line up and that is going to annoy me. Quality of fitting could have been better. Have now found that the bolts for axle`s are short and wing bolts are just long enough.....Nothing that cant be sorted...Didnt take long to have vertical and horizontal stabs fitted Quote Link to comment Share on other sites More sharing options...
iqon Posted October 17, 2015 Author Share Posted October 17, 2015 All of tail end glued on.......including this confusing bit A V3 kit with a V2 rudder ???...problem soon sorted by removing sticker....apparently wrong sticker put on...having done some checking up it`s true...... There is a choice of 1 or 2 servo elevators, was going for 2 to help with balance but decided on just the 1 as the elevators have already been cut and drilled for joiner and seam to be a perfect fit as long as I can leave in place for a few hours . Also fitted tail wheel to rudder at same time. Notice the CA hinges, must be the way they do them in USA. Now that the Elevators and rudder are fitted it looks massive. Quote Link to comment Share on other sites More sharing options...
iqon Posted October 17, 2015 Author Share Posted October 17, 2015 Engine fitted. Tank temporarily fitted, it looks lost in a large airframe. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted October 17, 2015 Share Posted October 17, 2015 Now that's what I call a large trainer. Quote Link to comment Share on other sites More sharing options...
iqon Posted October 17, 2015 Author Share Posted October 17, 2015 I`ll let you carry it one day, or if you insist........more than one day Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted October 17, 2015 Share Posted October 17, 2015 Go easy with the lead weights then ...... edit .... and I hope the tin cans aren't still glued to the underside of the tail. Edited By Gary Manuel on 17/10/2015 21:20:30 Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 18, 2015 Share Posted October 18, 2015 I recommend you add some strut braces between the lower fuz and the tips of the tail. This model was reviewed in another magazine and the tail fell to bits when recovering from a loop resulting in the loss of the model. It might have been a one off, but its not worth taking the chance. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 18, 2015 Share Posted October 18, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
iqon Posted October 18, 2015 Author Share Posted October 18, 2015 Hi Percy, it will get a liberal coat of glue before long, tank just put there out of way for now, final position not know yet. iso mounts ?, none fitted, but i did think about it.... thanks Jon, Percy for any all input Quote Link to comment Share on other sites More sharing options...
iqon Posted October 20, 2015 Author Share Posted October 20, 2015 Fittings are , using my own, fitted ball links to elevator and rudder. Quote Link to comment Share on other sites More sharing options...
iqon Posted October 21, 2015 Author Share Posted October 21, 2015 All done, ready for maiden ....forecast not so good for next few days......seams to be built very strong, well thought out, easy to put together..... only negatives I have found - axle bolts short, wing bolts short and would have been better with better fittings....... tank is in almost the same position,..retainer fitted to rear of tank.Thanks Percy........ Quote Link to comment Share on other sites More sharing options...
iqon Posted October 27, 2015 Author Share Posted October 27, 2015 Maiden done at weekend, didnt need trimming, flew just like a trainer Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted February 23, 2017 Share Posted February 23, 2017 Iqon, I'm building one of these. Can I ask a few questions? What engine? Any nose weight needed? Did you brace the tail; if so, how? Mine is at the stage of rear servos and closed loops fitted but not connected as I don't want the tail glued in till the engine (a borrowed Zenoah 25cc) is fixed and plumbed. I will brace the tail and am wrestling with carbon tube as it will only be needed on the upper surface and previous experience with wire was unsatisfactory. Fixings with enough tensile strength are a bit awkward though. Has your u/c been up to it; any other tips/mods whilst mine is still in bits? Quote Link to comment Share on other sites More sharing options...
iqon Posted February 23, 2017 Author Share Posted February 23, 2017 G26 up front no added weight required with that engine, tail end as instructions, undercarriage looks to be strong - cant help much, didnt last long, went into failsafe ? after doing a stall turn. Quote Link to comment Share on other sites More sharing options...
