MattyB Posted May 22, 2018 Share Posted May 22, 2018 That is beautiful - great job! Time to find some very long grass for the CG test glides! Good luck... Quote Link to comment Share on other sites More sharing options...
Rich Bailey Posted May 23, 2018 Share Posted May 23, 2018 Hello Harry. I have plans for the 215, for depron. Don’t want to mess them up though! How do I make the templete for bulkheads, ribs? Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted May 23, 2018 Share Posted May 23, 2018 Trace them onto greaseproof paper? Photocopy then cut out and stick onto balsa? Many ways to skin that cat. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted May 23, 2018 Share Posted May 23, 2018 As with many of the often called secret German aircraft of the latter part of WW2, the majority did not exist at all. Most are described as Brochure Tender documents, mainly for specifications issued by the RLM (Reich Luft Ministrium). In a sense there is no absolute right, as even those that made it to mock-up, such as the Fw Flitter would have been modified in the light of requests primarily of the the RLM. Great models though. Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 23, 2018 Share Posted May 23, 2018 Posted by Rich Bailey on 23/05/2018 05:35:16: Hello Harry. I have plans for the 215, for depron. Don’t want to mess them up though! How do I make the templete for bulkheads, ribs? You could take them down to your local copy shop and make a copy and expand them in size. I did this with my Sorcerer plan which I copied to a stick and then had enlarged and printed - making this from this. Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 23, 2018 Share Posted May 23, 2018 Posted by Erfolg on 23/05/2018 09:48:25: As with many of the often called secret German aircraft of the latter part of WW2, the majority did not exist at all. Most are described as Brochure Tender documents, mainly for specifications issued by the RLM (Reich Luft Ministrium). In a sense there is no absolute right, as even those that made it to mock-up, such as the Fw Flitter would have been modified in the light of requests primarily of the the RLM. Great models though. Interesting stuff Erflog. Yes a lot of modelling potential from the Luft '46 proposals and many RC models have flown successfully. I have been picking away at a PSS Flitzer glider which should be a good flyer I think with a layout similar to the Vampire. Quote Link to comment Share on other sites More sharing options...
Rich Bailey Posted May 24, 2018 Share Posted May 24, 2018 Kiwikid how can I get the plans for this plane? Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 24, 2018 Share Posted May 24, 2018 No plans sorry, it's a scratchy built off three views and info on websites like this one: **LINK** Quote Link to comment Share on other sites More sharing options...
onetenor Posted May 24, 2018 Share Posted May 24, 2018 Great job Would love to do a ducted I/C version. Quote Link to comment Share on other sites More sharing options...
Rich Bailey Posted May 26, 2018 Share Posted May 26, 2018 Where did you find the fuselage? Quote Link to comment Share on other sites More sharing options...
Rich Bailey Posted May 26, 2018 Share Posted May 26, 2018 Would like to use a 90 mm 12 blade EDF Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 26, 2018 Share Posted May 26, 2018 The fuse, booms and canopy are hand made one offs. Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 26, 2018 Share Posted May 26, 2018 Getting a bit more back on track, this is an inspiring vid of the maiden flight of a well presented EDF 215. Some initial teething problems are overcome and lead to a great flight. <</div> Quote Link to comment Share on other sites More sharing options...
