Stephen Jones Posted July 11, 2016 Author Share Posted July 11, 2016 Hi, Do you know as i was covering it, i thought to myself, it almost looks like a .... from this angle what with that sweeping curve over the top of the body. Hmm with a couple of air intakes under the wing it could pass as a Jet especially with the hole at the back. And i showed my son, and he said to me do you know dad it looks a bit like a .... from here . So what did we think it resembles. Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 11, 2016 Author Share Posted July 11, 2016 Two more pictures, Well i am happy with it so far . Steve Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted July 11, 2016 Share Posted July 11, 2016 Steve, First name that came to mind for me when I saw your new model is RAZOR, very sharp! Rich Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted July 11, 2016 Share Posted July 11, 2016 Steve, I think it looks like your creation. If we want to make any jet comparisons, with the slight wing sweep, let's go with the Dassault Ouragan from the early 50s. It doesn't resemble it, but somehow for me it makes a similar impression. Ouragan sounds good and it means Hurricane. Edited By Colin Leighfield on 11/07/2016 23:20:57 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 11, 2016 Author Share Posted July 11, 2016 Posted by Richard Harris on 11/07/2016 23:15:49: Steve, First name that came to mind for me when I saw your new model is RAZOR, very sharp! Rich I like this suggestion, Very descriptive Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 11, 2016 Author Share Posted July 11, 2016 Posted by Colin Leighfield on 11/07/2016 23:18:28: Steve, I think it looks like your creation. If we want to make any jet comparisons, with the slight wing sweep, let's go with the Dassault Ouragan from the early 50s. It doesn't resemble it, but somehow for me it makes a similar impression. Ouragan sounds good and it means Hurricane. Just had a look at that, and i see where you are coming from, Just had a look at some pictures on the webb and it does look like a Mk1 .... I will show some picture later on if no one gets it . Admittedly my model would need a few modifications to look more like .... but it could be done. Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 16, 2016 Author Share Posted July 16, 2016 Ok, I hope to Maiden This tomorrow i will then decide what to call it. The connecting rods to the Rudder and Elevator are straight to the servos with no bends or slop. Tank Bay, Switch and charging socket along with the rudder connecting rod are on the opposite side to the Exhaust . Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 17, 2016 Author Share Posted July 17, 2016 Well she Flies, Well we went to the field expecting it to be busy, what with the sun shinning an all, No we where the only ones there having stepped out of the car i discovered why. It was windy. We had a couple of goes with Paul`s F15 as we had upgraded the motor to a 350 watt Motor, then some more members turned up with no models, just to see who was at the field i guess. So after a short while i decided to fire up my Os .15FP and give it ago despite the strong wind after all i had designed it to fly in windy conditions. I hand launched it from a standing position with no problems at all she climbed away very nicely. I did however discover that i have too much down thrust and right thrust and i need a little more nose weight. After flying her around and getting the feel for it, i tried some loops, rolls and inverted flight, she is very sensitive on the elevator, but performers well and is very smooth through out she flies fast but not excessively and the windy conditions did not bother me or the plane. So i have a few alterations to do then i will try again. Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 19, 2016 Author Share Posted July 19, 2016 Still not sure at the moment as to what it should be called, I spoke with a colleague at work today and he reckons is should be called the "wind Whisperer" i thought about interceptor or ridge racer , We have Razer or E-Razer if it`s Electric powered. Thunderbird 19 SJ.Sapphire Omega, Omega E, Omega G, Omega 3, Porpoise ( which could be short for multi purpose ) Mako or Barracuda COD + (,s wallop ) ( piece ) ( chips ) Flying Fish Dolphus Propellerus So many to chose from . Well now that it has flown i know it`s not CODs wallop. Hmmmmm.............. Steve Edited By Stephen Jones on 19/07/2016 00:17:10 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted July 19, 2016 Share Posted July 19, 2016 Congratulations Stephen, another success on your hands! Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 19, 2016 Author Share Posted July 19, 2016 Thank`s Colin, Just need to do a little tweaking with the thrust line and move the battery forward to correct the CoG . And hopefully get someone to video it for me. It is always worrying having to maiden a model without a helper especially if you are a mode one flyer and the model has to be hand launched. Considering this model does not have any dihedral and the windy conditions it flew straight and level giving me plenty of time to get my hand back on the controls although it was pitching up due to the Cog issue . So at this point it does look like i have archived everything i wanted from it . Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 30, 2016 Author Share Posted July 30, 2016 Hi, Woke up this morning to bright sunshine so i decided to take this one out again to check i have corrected the CoG and thrust angle . As you can see the weather went crappie. But the model flew well in the windy weather and the Cog and Thrust are now correct she rolls nice, Inverted flight also good as well loops . Big Thanks to Robert Tomlin For taking his time out to do some Pictures for Me. Cheers Steve Edited By Stephen Jones on 30/07/2016 22:54:24 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 3, 2016 Author Share Posted August 3, 2016 Hi, I am thinking of calling it Guppy what with that large colorful fin. I can not wait to get out and fly this one again and i am amazed just how stable and easy the hand launches are. Fast, stable, maneuverable, everything i wanted from it. Steve . Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted August 4, 2016 Share Posted August 4, 2016 Guppy seems quite fitting Steve with that tail as you say, certainly seems to go well. Linds Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 7, 2016 Author Share Posted August 7, 2016 Cheers Linds, Thank`s Guy`s for all the great suggestions , As you can see i have gone with Guppy. I got to fly this again Friday evening . I am really happy with the hand launches probably one of my easiest models to hand launch and flies really well too. Steve. Quote Link to comment Share on other sites More sharing options...
trebor Posted August 7, 2016 Share Posted August 7, 2016 Is that an eye or has it been shot ? Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 7, 2016 Author Share Posted August 7, 2016 Posted by trebor on 07/08/2016 17:34:41: Is that an eye or has it been shot ? Of course it`s an Eye, Put you're glasses on .. He He finally managed to find an excuse to use that smiley. Steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 17, 2016 Author Share Posted September 17, 2016 Well what a nice day today has been, I have been out again with this one. My son could not keep track of it un-till i slowed down for him, But i soon got board and opened up the taps again, Steve. Quote Link to comment Share on other sites More sharing options...
