Peter Miller Posted June 2, 2016 Share Posted June 2, 2016 I think that Ballerina would be marginal on a .30. MY Peyret Maubousin is a large model that does fly on a .30FS BUT and it is a big BUryT it is more like a powered glider. Ballerina would probably fly in calm weather but with no reserve of power. I know that a 60" span VIntage Super 60 did fly on a very early Saito 30 so your model will fly but as I say not going to do even mild aerobatics. I think you should look for a good second hand O.S 40 FS Surpass. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 2, 2016 Share Posted June 2, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Low pass Pete Posted June 2, 2016 Share Posted June 2, 2016 Mine has an OS52 4 stroke and goes really well on this. I fly from grass and would not like to use a smaller size engine. You can always throttle back but if there is limited power then options get shorter. Best Regards Peter Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 2, 2016 Share Posted June 2, 2016 Saito 45 special for sale on our website, £50 in for sale section Don Valley Model Flying Club Not mine but will be in good nick John Edited By john stones 1 on 02/06/2016 22:38:58 Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted June 11, 2016 Author Share Posted June 11, 2016 Well the saga continues. I took the new Saito 30 back to the shop I brought it from and the proprietor very kindly did a straight swap for an OS FS52S. It is second hand in that it had been installed but never run. It's as new. Given that OS are fairly more expensive than the Saito's, I felt happy with the deal, but having got home I now find out that it's a discontinued engine. Most spares websites appear to have either "shadow stock" or "out of stock" parts. I need the needle valve extension and the tool kit for it and I'm feeling a little bit mugged over the deal. Can anyone give me some advice on a) when were they discontinued? b) are they difficult to get parts for? c) and here's the biggy, have I been sold a pup? STOP LAUGHING! Cheers for any help. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 11, 2016 Share Posted June 11, 2016 Just engines.co.UK have your requirements for the OS It is a fine motor, andwill last you a long long time if you look after it Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 11, 2016 Share Posted June 11, 2016 Not a pup Richard, in fact probably a fair deal seeing it's as new. As for the extension, isn't it just a piece of wire with a bend in one end? The OS fours strokes I've had only came with a couple of allen keys, nothing special about them! Just Engines list spares including the valve adjusting kit if you can't source a spanner, feeler guage and allen key locally. Denis pipped me to the post! Edited By Bob Cotsford on 11/06/2016 21:28:04 Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted June 11, 2016 Author Share Posted June 11, 2016 Excellent guys. Many thanks for the advice I'll take a look at Just Engines. Sound like I've at the very worst broke even if not a jump up in quality. Much obliged. 😃 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 11, 2016 Share Posted June 11, 2016 You have bought a superb engine. I bought a second hand one off Ebay and it is in my Super Marauder. Just beautiful. As the other say the needle valve isa bit of 16 SWG wire.Any metric feeler guages, a 5 mm spanner and a small allen key is the tool kit but you will not need to adjust tappets for years. Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted June 11, 2016 Author Share Posted June 11, 2016 Thanks very much for the advice guys.. That's taken a load off my mind. 😃 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 11, 2016 Share Posted June 11, 2016 Owned lots of O.S Richard, never needed any spare parts John Quote Link to comment Share on other sites More sharing options...
Low pass Pete Posted June 21, 2016 Share Posted June 21, 2016 My Ballerina flies brilliantly on an OS52 Surpass (inverted\). I have 2 of them and never had problems with them or needed spares. Would jump at the chance to get a third if I could find one. Superb engines. Why OS replaced them is a mystery to me. Regards Peter Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted July 1, 2016 Author Share Posted July 1, 2016 Posted by Low pass Pete on 21/06/2016 22:28:14: My Ballerina flies brilliantly on an OS52 Surpass (inverted\). I have 2 of them and never had problems with them or needed spares. Would jump at the chance to get a third if I could find one. Superb engines. Why OS replaced them is a mystery to me. Regards Peter Peter, Thats good news. Thanks. One more question for you if you will. I've arrived at the point where I'm considering engine mounts and former F1. Can you tell me what engine mount you used as a staring point please? The one I have as a spare is just a pair of bearers but the portion that bolts to the fire wall is too bulky and fouls on the engine. Is there a make/model/part number for the one you're using please? Much obliged. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 1, 2016 Share Posted July 1, 2016 Hi Richard, engine mounts come in two sizes, too big and too small. Your hole centres on the motor are 44mm and your crankcase is 33mm wide. Look up flair mounts at Balsa Cabin co .uk, and seebif they suit. Cosford in 2 weeks, so try your motor there in some mounts Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 1, 2016 Share Posted July 1, 2016 Just for reference guys, the Saito is available from SMC.co.UK Both 30s, the SC and the Saito, will fly 3lbs of aeroplane, as I do both. For reference they come out approximately to 320 watts, so are capable and sound GREAT Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 1, 2016 Share Posted July 1, 2016 Try going to SLEC and buying their long engine mounts. Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted July 2, 2016 Author Share Posted July 2, 2016 Thanks guys. Most helpful as always. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 2, 2016 Share Posted July 2, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Low pass Pete Posted July 6, 2016 Share Posted July 6, 2016 Richard, sorry not to have replied earlier (on holiday and no internet). Ref engine mount cannot recall the specific make but it was a standard 45 size mount from our local shop Inwoods (I think). One point is that when I did my install I reduced the Fuz length a tad (about 14 to 1/2 half inch) to keep the prop driver position the same as peters original plan. Seemed to work for me OK. Regards Peter Quote Link to comment Share on other sites More sharing options...
Richard Walton Posted July 6, 2016 Author Share Posted July 6, 2016 No problem Pete. Thanks for coming back to me anyway. Thanks to the help received I took delivery of one from SLEC yesterday and on initial exam it looks like it'll work fine. I have seen your set-up in the build log and got some good ideas from it. Much obliged. Quote Link to comment Share on other sites More sharing options...
