One Eighteenth of a Canberra B.2
Andy Blackburn
Preamble...
The very first version of my Canberra B.2 plan dates back to July 2002 (!), the design has been through a number of (for want of a better term) evolutions, each of which had a different construction, airfoil section (S3021, Clark Y), planform twist etc.
By about 2007 (no sense in rushing these things) I’d settled on one of the best-performing sections with good manners that I could find (HQ2.5/10 blending to HQ 2.5/12), but construction wasn’t easy – the HQ airfoil is undercambered with a delicate aft section, the wing was a fairly complex build and was constructed upside down because there's a compound taper on the bottom but the top is flat, the nacelles were built from thick sheet and triangle section balsa like small “kipper” fuselages and were threaded onto the wing after being planed (an operation that, because of the small size of the nacelles, put the tips of one's fingers at serious risk from the blade of a razor plane) and sanded to shape, and the fuselage was made from an octagon of thick sheet like the old Flair Hawker Hunter so it required contest-grade wood and you had to be good at bending thick balsa. Or good with filler.
I sent out 3 or 4 evaluation copies of the plan to various friends and aquaintances to see what they thought, Terry Lidstone of the West Mendips club built one as a T.4 (solid nose), it was covered in Profilm and came out quite light (39 oz) in spite of the rather agricultural construction. Terry’s conclusion was that although there were some constructional difficulties (that upside-down wing again), it flew really well.
However, I was never really happy with the design, so the part-constructed bits have been stuck in a corner of the workshop, staring accusingly at me for the past 7 or 8 years, and I’ve tinkered with the plan over the years with a view to finishing it properly...
The full unexpurgated, oversized story of Scott Edwards' double-size Cranberry is covered elsewhere on this forum (see "One Ninth of a Canberra"), but Scotty's requirement for a flat-bottomed wing was the trigger for what I hope will be this final re-draw of the plan; after a bit of thought it was concluded that Eppler 205 (which requires a generous allowance from Dr Reynolds - or a turbulator - in order to do its best work) should be really good at that enormous wing chord with low drag and lots of speed potential, and that it would still be fine for the (double-sized) tips because they’d still be about 10 inches wide.
However, if we changed the tip section to Clark Y – a magnificent thermalling and general-purpose section – it would be better at low speed (thermalling and landing) and would probably have better manners around the stall as there's about a degree of aerodynamic washout when compared to E205, but we can add a bit (1.5 degrees) of geometric washout to help things along. And since the wing was now flat-bottomed it should be easy to build and could be constructed the right way up.
After a while, of course, I realised that what would work for Scotty's very large Canberra would probably also still work for the original (and more sensibly-sized, some people might say) 43” span model! This was an exciting find and I spent a couple of weeks pulling everything on the drawing apart and re-drafting it; the fuselage is built on a keel, planked, with a disposable jig. Nacelles are now built on the wing and sheeted in situ (thanks to Steve McLaren for this idea), this approach requires more parts but that’s not a problem if the laser-cut parts are used, and is a lot safer on the fingers. Best of all, the Wings are now built the right way up (hooray)! The inner panel are built first on a spar that runs all the way out to the tip, then the wing is tipped-up onto the bottom skin for the outer panels.
All the parts were copied onto separate .DXF files to that they could be laser cut by SLEC who produced 15 sheets of wood in varying thicknesses, printed the plan and sent everything to me for a reasonable sum.
-obviously, I didn't want to say "very reasonable" in case they put their prices up, but there does seem to be quite a lot of wood.
Gratifyingly, I found that all the parts do seem to just slot together with a minimum of fuss; the only time any minor fettling is required is when the balsa is not 100% correct in thickness – some of my 1/8”, for example, was a few tenths of a mm oversize and the 1/4" was about 6.9 mm. However, I’m told this is quite normal.
Wings
The inner panels are built first:
There's a fair bit of careful infill needed, and the spar strength has to be tapered off towards the dihedral break:
The wing joiner is 5 mm carbon rod running in carbon tube, the incidence pegs are 3/32" wire. I should have taken more care with the alignment because I had to make a small compensation when installing the incidence tubes in the fuselage.
Outer panels are made by sliding the bottom outer wing skin into place and then tipping the wing up so that the spar is flat on the wing skin.
Ready for the top skins:
Edited By Andy Blackburn on 01/06/2016 15:30:16
Nacelles
Nacelles are now built directly onto the wing, the only thing you have to be careful of is keeping the vertical keels dead straight:
After a bit of experimentation, I discovered that it's possible to pre-set a compound curve in a piece of light, straight-grained 3/32" balsa but running both sides under a hot tap for a minute, leaving it for 10 minutes and then just bend it with the fingers, scraping the inside with a fingernail to induce curves in both directions. When it's dry, you're left with this:
Sheeting the nacelles is then pretty straightforward, but there's a lot of waiting for wood to dry:
I'll detail it on the plan including some cutting patterns but basically the process is
  1. Pin some scrap bits of 3/8" square onto the wing surface 3/32" from the formers so that the sheet fits between, and sand a the sheet for a reasonable fit.
  2. Tack-glue it in place with medium cyano.
  3. Take off the bits of 3/8" square and properly glue it to the wing surface, I don't like kicker (awful stuff!) but in this case it's very useful.
  4. When it's set, carefully dampen the skin, leave it a few minutes, apply some medium cyano and then carefully roll it onto the formers, one or two at a time, cutting a dart at the front as necessary (see picture) and some V-shaped cut-outs to allow the excess wood to bend.
Here's the almost-finished nacelle:
- hasn't turned out badly, needs planing, sanding and the jet-pipe...
..and of course the starter fairing, made from rings of balsa mounted on a 1/8" dowel, spun in a drill and sanded:
Fuselage
Ah, the interesting bit...
One of the changes to the original plan was to add a traditional battery box. I still make them 1 1/4" square to fit old-style NiCd batteries...
Glueing the keel pieces showed up a minor difference between the plan and parts - unusually for me, I didn't fuss about it (paper will expand and contract with atmospheric conditions) and just went with the parts.
However, here's where there was a minor hiccup:
When the laser cuts wood, it's a very precise cut but the cut itself is V-shaped, and on thick sheet it can be 0.75-0.8 mm wide at the top of the V; this means then when keel pieces are trued-up for gluing together, there can be a gap of up to 0.5 or 0.6 mm, as shown here. I've added some thin sheet to adjust the fit of the keels, but it looks as though there might have to be some adjustment of the parts patterns to allow for this.
The other issues were:
  1. I hadn't really though in sufficient detail about where the servos would be mounted;
  2. It turned out that the snakes were mostly in the wrong place, and the holes were too small anyway, and
  3. The side keel pieces were both cut from 1/4" sheet and the wood was slightly bent - normally this wouldn't be a problem (wood does this all the time) but they were bending in such a way that the fuselage was twisting during assembly.
Clearly, some redesign and re-drawing of parts would be necessary, and some more parts would have to be cut. Oh dear. That's not what I said at the time, of course, but the sentiment was broadly similar...
Fast-forward several weeks and SLEC had produced and sent another sheet of poplar ply formers, and we could finally get down to the fuselage. Basically, it's built upright on 1/4" keels with some disposable jigs to hold everything straight, it can be almost completely assembled and then hit with cyano to lock everything in place:
This is a stressful photograph - I had to clear the workbench!
Here's a close-up of the incidence peg fixing:
The idea is that when everything is tacked in place, you can remove the incidence pegs and pins and lift it off the bench, add the remaining structure and then sand everything to shape before slotting back into place, adding the snakes, fitting the servos and then planking the top part of the fuselage; once that's done, it should be rigid enough to plank the bottom without anything being pinned down. That's the theory, anyway .
Fuselage Part 2
Amazingly, the revised snake routing was nearly correct, only a few minor changes required;
Here's a close-up of the rudder servo mount arrangements:
...and another view showing how it's retained:
We had a small ceremony on Saturday to mark The Laying Of The First Plank:
As you can see, no expense was spared on the accompanying refreshments - genuine Sainsburys organic ginger nuts, those are...
This is a few more planks added (on Sunday, I think); I'm using tapered planks because the nose former tapers quite a lot, parallel planks are less work to prepare and would have to be narrower (maybe 4.5-5 mm as opposed to about 7.5 mm) because of the small nose former diameter, so there would have to be more of them, and some would have to be angled at each end. I don't know which approach is quicker.
I'm using thin/medium cyano to glue the planks to the formers and Deluxe Materials Aliphatic Resin to glue the planks together; I did try Titebond as it's supposed to be the best, but for me it's too thick, difficult to apply and gets everywhere...
This was the state of play at about 6 pm today (Tuesday):
I've just lifted it from the jig and as hoped, it's very rigid with just over half the fuselage still to be planked.
As you may have noticed, I've had a change of plan at the tail end - rather than continuing the planks to the last former, I think it's going to be much easier to in-fill the last fuselage bay with thick (and light) sheet and then plane/sand everything to shape afterwards.
> Up-town Top Planking! Wasn't that a song?
I really couldn't say, of course, as it was before my time...
> FOUR ginger nuts for the first plank laying ceremony............. that's nothing short of outrageous!!!
Well, obviously a spare is required in case one drops into the tea during the ceremonial dunking process...
> Damned good planking there. Are they all 1/8 thick ? For the solid infill tail end, at a guess you can hack out some of the inside to save weight ?
All 1/8" apart from the small bits on the centreline - bits of soft 3/16" squashed into place. I'm hoping that the tail end will be light enough that hacking bits out won't be worth the bother.
> Any comedy quips from the Mrs about building a balsa cucumber ?
She hasn't seen it yet. I think she saves her best Nora Batty voice for my efforts
Edited By Andy Blackburn on 15/06/2016 15:46:12
Been a busy couple of weeks so maybe not quite as much progress as hoped, but I've been fettling the tail surfaces and other bits. The stabiliser alignment was pretty close (stab tip to bench measurement 118 mm one side and 119 mm the other) so only required a little bit of adjustment, the fin and rudder wasn't quite vertical so that'll need looking at later:
I think that doesn't look too bad. Shall we have a little treat and put it all together? ...
Not bad.
This is the tail bay in-fill being pinned carefully before glueing:
And this is it with the stabiliser off. This just requires a bit of care with a coarse permagrit block and several try/fit attempts to get the right shape, it takes a while but I can't really see an easier way of doing it.
The tail end is now also relatively stiff, so it's probably back to planking tomorrow.
Edited By Andy Blackburn on 26/06/2016 16:26:18
I assure you that Mr Edwards is exaggerating - there are loads of bits where it's not quite right, possibly because the planks might be a little too narrow (7.5 mm) and are difficult to get to run straight against existing planks without persuasion from masking tape.
And yes, I have already trimmed off some of the proud edges - just couldn't stop myself...
Should have an update later on today.
This was a few days ago - planking coming along well, but slowing down because each of planks is getting to be a different (and odd) shape:
I always seem to need masking tape to persuade adjacent planks to fit together properly, otherwise they're so flexible that they tend to fit where they're pinned but not in-between the formers; that probably means that the grade of wood I'm using (very light, about 6 lb/cu ft) is probably a bit too light, and/or the planks are a bit narrow - the 1/8" sheet was initially stripped to 7.5 mm, 8.5 mm would have been fine, possibly even 9mm.
This is the jig that I used to taper the planks the right amount for most of them:
...and this is the tail area that's been in-filled with 3/8" sheet; you can just about see the different pieces of wood that were used to do the job. Also, the balsa cement has blushed which means that I'm doing the right thing in building when the weather is unsuitable for flying
A quick look inside the tail area where it's filled-in with 3/8" sheet - you could perhaps dremel some of that out, but it might not be worth the bother.
- and (drum roll, please) the last plank has been laid:
..just to show it's not smoke and mirrors, here's the top:
Next job is to add soft block around the fin & stabiliser, tail cone and sand to shape - after leaving it for at least a couple of days to make sure the aliphatic resin has hardened properly. Then I suppose I'd better have a go at the formers for the canopy and bomb-aimer's transparency.
Edited By Andy Blackburn on 04/07/2016 22:05:54
All of a sudden, we're not actually on the home straight but at least it's in sight. Managed to get the nose and tail blocks glued in place, it all looks a bit agricultural...
...here's the tail blocking, the dummy tail surfaces are probably just about visible in all the mess:
...the nose block is easy. I was unable to resist a bit of preparatory trimming
And I spent this morning planing and sanding the fuselage - for some reason, razor-planing large blocks of balsa is almost as therapeutic as glueing the leading edge onto foam wings.
The edges of the planks were just knocked off with the sharpest (newest) Permagrit block I could find, then it was a question of how to make sure the fuselage ended-up properly circular; you can't use a foam sanding block because all that does is sand away the balsa leaving the glue lines in place, and you end up with something that looks a bit silly - nobody remembers threepenny bits, do they? It's possible to sand freehand with a flat sanding block using a kind of rolling motion at an angle to the fuselage axis, but you've got to go slowly and watch what you're doing so that you only take off the high spots, and it's not easy.
So, I made this curved sanding block from a couple of bits of thick card (like the stuff you get on an A4 pad) and some 120 grade sandpaper taped to the fuselage using contact adhesive:
...and it seems to have worked quite well, after the corners were rounded off to stop it marking the balsa - it has enough flexibility to adopt a tighter curve if required, but it fits the fuselage nicely and seems to work well. Here's the result:
The fuselage weighs just about 9 1/2 oz including the rudder servo, which for something that size (~44" long) is not very much. Adding that to all the other bits, we get a structural weight of only 22 oz.
Even allowing for the usual weight escalation with the finishing process I find it difficult to see how the finished item is going to exceed about 38 oz, which is awfully light for a model that has 3 sq ft of wing area - I might have used wood that's a bit too light. This is very promising for flying in dodgy conditions, but It's beginning to look as though I might have to make provision for ballast.
Trying to avoid the 'threepenny" planking look is my personal nemesis I very much like the idea of a bespoke curved sanding sheet. I will deffo try that ! Will the fuselage need a layer of filler, or (as I suspect) is it so bloody perfect you can see your face in it ?
For ballast, how big is the wing joining tube ? Could that double as a ballast tube ?
Edited By Scott Edwards 2 on 10/07/2016 09:04:25
The wing joiner is 4.5 mm OD carbon rod running in carbon tube; that's an idea, though - replacing the wing joiner rod with wire should give about another 1 1/3 oz.
I think a small ballast tube for F3F-type ballast slugs will be required; if they're the usual 19 mm brass ones from Sloperacer and the like they're almost exactly 3 oz each, so with 3 sq ft I'd need a couple to make a noticeable difference. Maybe four slugs will be enough...
Wing Fairings
To be honest, after Scotty had employed his patented "curvy wing root" wing fairing and explained how easy it was, I did wonder if I was making a bit of a mistake with this so wasn't looking forward to it, but in the event it turned out fine - tack-glue the 1/16" root rib to each wing root, assemble everything, apply a judicious amount of cyano and then fill-in the gaps with wedges of sheet:
..which looks fine. Here's the high-tech trimming tool in action:
...and the finished fairing:
Didn't take that long, actually.
Tail Surfaces
The wing & tail control surfaces are now fitted and hinged, so the tailplane and fin can be assembled onto the fuselage:
That didn't take long either, but there was lots of waiting for PVA glue to dry - didn't have the courage to use cyano!
It's just possible to see in this shot (between the red and green pin heads) that the rudder snake has been sawn right through to allow the fairing to be removed and then replaced - sounds suicidal but works fine.
The "Finished Structure" Shot...
Really pleased with this:
What's required now is a canopy buck that I can send to Steve at Vortex, a bit of filler and a final decision about the colour scheme. I'm still leaning towards a black/medium sea grey 101 squadron aircraft from 1951, similar to this:
... but I must confess I'm wavering very slightly.
Covering will be Japanese tissue / sanding sealer / non-shrinking dope and then either car spray cans from Halfords or enamel paints from Hannants.
Edited By Andy Blackburn on 23/07/2016 18:22:55
