Gentle Curves - Lucas his Skywriter
Lucas Hofman
Great build Lucas
It is difficult to keep flat sheet flat, but here goes
Wipe soap across the area to be annealed
Play the flame too and fro across the area to be worked and stop as the soap turns brown
Allow to cool
This is as soft as it gets without melting
With the new fold, the crease work harden slightly, and should be left alone from then
The loft is finished! I promised myself I can build a plane, maybe more than one, before starting on the next big house job. So I hope to move faster with Gentle Curves now.
Yesterday glued the remaining bits on the top of the fuse:
Cowling is next, and then the whole can be sanded.
Edited By Lucas Hofman on 08/12/2017 06:47:05
At least some good progress. First defining the shape of the cockpit coaming. I using a template to ensure left and right become identical:
Then it is time to rough shape the fairing round the tailplanes. Hurra for the razor plane:
The cowling needs sanding, the rest also but how nice she becomes:
Lucas
Fiixed lower wing to the fuselage last night. The Lyndsay method for the dowel allows more flexibility when fitting the wing, but I think I prefer the Miller method with a slot in the center ribs. Below my method for ensuring a perpendicular fit of the wing:
The ruler does not stretch like a piece of string does, and bij lining up the fuse on the building jig one can use any point on the centerline (on the jig, not the fuse) to measure from.
Lucas
