Martian Posted May 24, 2017 Share Posted May 24, 2017 This Mustang kit from SFM was launched at the model show earlier this year I been waiting nearly 2 months for it to arrive here are the first piccies Quote Link to comment Share on other sites More sharing options...
Martian Posted May 24, 2017 Author Share Posted May 24, 2017 Enough silliness , as you can see the outside of the box shows a very detailed drawing clearly showing layout of parts and inside an excellent 27 page photo guide on construction plus a large 2 sheet plan all though not in the usual sense of a plan. This kit cost £139 plus postage from Hurricane models . The laser cut parts mainly balsa and some lite ply are excellent quality . A full hardware package is included comprising wheels uc legs all horns (very good quality) screws bolts control rods control dowels shrink sleeves spinner a painted pilot decal set in fact nothing seems to have been forgotten ,recommended glues are white pva ca and uhu por, the control surfaces are preshaped and tapered , highly recommend these kit from sfm and I feel its going to be a fun build. Not sure at this point how scale it can be finished, Quote Link to comment Share on other sites More sharing options...
Martian Posted May 24, 2017 Author Share Posted May 24, 2017 Oops forgot some pics Quote Link to comment Share on other sites More sharing options...
Martian Posted October 4, 2017 Author Share Posted October 4, 2017 Well less than a week ago I started this kit having perused the manual at length I had fully intended to log progress with piccies but it has gone together so well I never stopped to take any. I am now at the stage where the fuselage is virtually complete ,it should be finished by the end of today. The manual is as is always with these things in black and white rendered from colour images therefore the contrast is very poor making it hard to I'd e notify the parts but reference to the 1-1 drawing it can be worked out also some of the text identifies the wrong part no . Other than that its a 'll good fun. I will post pics if anyone is interested Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 4, 2017 Share Posted October 4, 2017 Id like to see the pics Martian! Looks like a lovely model, laughed at the air fix by he way Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 4, 2017 Share Posted October 4, 2017 Over 600 views on this so far Martian, would suggest that your Mustang is not going unnoticed. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted October 4, 2017 Share Posted October 4, 2017 I'm interested, go on show us how you are getting on with the build Regards Robert Quote Link to comment Share on other sites More sharing options...
Martian Posted October 5, 2017 Author Share Posted October 5, 2017 Ok some photos of the build so far, quality is poor I took them with my tablet. The hatch extends a fair way and is built first Quote Link to comment Share on other sites More sharing options...
Martian Posted October 5, 2017 Author Share Posted October 5, 2017 Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted October 6, 2017 Share Posted October 6, 2017 Hi Martian, Looks a very nice kit indeed, watching with interest. Regards Robert Quote Link to comment Share on other sites More sharing options...
Martian Posted October 13, 2017 Author Share Posted October 13, 2017 Life got in the way but at least the fuselage is complete ready to cover in chrome oracover Quote Link to comment Share on other sites More sharing options...
Martian Posted October 18, 2017 Author Share Posted October 18, 2017 😕 not been well but have made progress wings are done and balsa dusted ready to join will post some pics tomorrow before I make any more progress Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 20, 2017 Share Posted October 20, 2017 welcome to the planet earth there Martian.....I've used the chrome oracover/profilm,make sure that your RX aerial is well exposed out in the open.....because the covering will shield the signal is some circumstances....resulting in a couple of seconds of hair standing on end scenario's ......... ken Anderson...ne....1..... raised hair dept.. Quote Link to comment Share on other sites More sharing options...
Martian Posted October 20, 2017 Author Share Posted October 20, 2017 Thank you for that advice Ken ,will be looking to bring them outside of the fuselage and try to disguise somehow Quote Link to comment Share on other sites More sharing options...
Martian Posted October 20, 2017 Author Share Posted October 20, 2017 Here are some pics as promised, but first some observations the balsa used in the tail feathers/leading and trailing edges plus wing tips is very hard and therefore takes some serious sanding but once done they look good and don't bruise ,the wings were straightforward to build but care has to be taken with the sheeting as all sheets are glued together before placing on the wing. The U/C mounting is the same regardless whether retracts used I'm using HK retracts ( HK-15090S ) these have a metal trunion and 4mm pin fitted but not required the grub screws are located either side of the trunion and not easy to see, they are a excellent fit onto the recessed mount. The retract door is designed to be held in place with wheel collets on the u/c wire unfortunately this method lifts the door about 4/5mm clear of the wing skin so i'm going to use brass straps Quote Link to comment Share on other sites More sharing options...
Martian Posted October 23, 2017 Author Share Posted October 23, 2017 This kit allows for a slight modification to fit retracts but to actually modify is a little more than slight , first the bend has to be cut off so the leg fits in the retract that bit is ok next the door is held in place with collects slid over the leg not ok the door sits about 4/5mm above wing skin so fitted the door to the leg with brass straps but that is not enough the door still sits to high about 2mm ,decided to remove the retract mounting plate and make a spacer so the retract unit sits lower in the wing trail fit shows a reasonable fit so onto the next bit ,pics below Quote Link to comment Share on other sites More sharing options...
Martian Posted October 24, 2017 Author Share Posted October 24, 2017 Received my Warbird Rep Spitfire retracts today all though a similar method of mounting the main difference is the u/c leg in that the spit one only has one coil whereas the Mustang has 2.5 coils that brings the leg above the wing skin so I Will see how it all fits and if necessary make a pair of new legs with one coil although this gauge is a pig to coil . Quote Link to comment Share on other sites More sharing options...
Mike T Posted October 26, 2017 Share Posted October 26, 2017 What about some HK 'oleos'? You get the spring, but without the coil. Nice looking kit, BTW... Edited By Mike T on 26/10/2017 01:30:18 Quote Link to comment Share on other sites More sharing options...
Martian Posted October 26, 2017 Author Share Posted October 26, 2017 Posted by Mike T on 26/10/2017 01:29:49: What about some HK 'oleos'? You get the spring, but without the coil. Nice looking kit, BTW... Edited By Mike T on 26/10/2017 01:30:18 Thanks Mike it is a consideration I'm not sure whether there is a debate about oleos being to rigid on grass Quote Link to comment Share on other sites More sharing options...
Martian Posted November 24, 2017 Author Share Posted November 24, 2017 Breaking news i have finished lolipoop the mustang will post pics tomorrow Quote Link to comment Share on other sites More sharing options...
onetenor Posted November 24, 2017 Share Posted November 24, 2017 LOLIPOOP??? Do you really mean that or LOLLIPOP?? Quote Link to comment Share on other sites More sharing options...
Martian Posted November 25, 2017 Author Share Posted November 25, 2017 No that is its moniker ☺ Quote Link to comment Share on other sites More sharing options...
Martian Posted November 25, 2017 Author Share Posted November 25, 2017 I,ve enjoyed building this SFM kit and was hoping to add scale detailing but there are quite a number of areas that would not make it look authentic so I have settled for stand of scale, I covered most of the plane in chrome oracover but found that just to shiny and as has been pointed out shows all marks so have oversprayed with rustoleam chrome spray can from B&Q the result is in my opinion much better producing a near ali finish. The colours and markings are from a Tuskegee red tail Lollipoop pictures are not great Quote Link to comment Share on other sites More sharing options...
Martian Posted November 25, 2017 Author Share Posted November 25, 2017 This is a depiction of the aircraft modelled Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted November 26, 2017 Share Posted November 26, 2017 Hi Martian, A great looking model you have produced there Regards Robert Quote Link to comment Share on other sites More sharing options...
