rcaddict Posted August 25, 2017 Share Posted August 25, 2017 ok so ive put my new tek-sumo together ready for maiden tomorrow - but just wondering how do i stop the prop breaking on landing, is it an ESC Brake on situation ??? Edited By oldgit on 25/08/2017 17:09:56 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 25, 2017 Share Posted August 25, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
J D 8 Posted August 25, 2017 Share Posted August 25, 2017 I fly a Zaggi power wing and so long as power is off at touch down prop is fine. If you did set ESC to brake there would be a good chance of it stopping in the straight up/down position and be more likely to snag and be damaged. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 25, 2017 Share Posted August 25, 2017 I used a nylon prop on my zagi lasted for years. Not as efficient as a composite but did the job well . You can still find them on line. Quote Link to comment Share on other sites More sharing options...
PatMc Posted August 25, 2017 Share Posted August 25, 2017 If the motor shaft is 3 or 3.2mm use a propsaver adapter as illustrated here **LINK** It will also avoid a bent shaft & easy to make if you have a lathe. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted August 25, 2017 Share Posted August 25, 2017 If its a pusher with a normal type prop adaptor it will self undo on a prop strike (my pusher delta does) as long as its not done up too tight!. Works for me! Quote Link to comment Share on other sites More sharing options...
Jeff Powell Posted August 25, 2017 Share Posted August 25, 2017 Hi Oldgit I've been flying a Swift 2 for several years with a fixed plastic prop with no problems. If it's your first flying wing you need to be careful with launching to avoid the prop. The Swift is easy to launch using the frisby technique which keeps the hand well away from the prop. Quote Link to comment Share on other sites More sharing options...
rcaddict Posted August 26, 2017 Author Share Posted August 26, 2017 cheers guys Quote Link to comment Share on other sites More sharing options...
