Epoxy & heatshrink covering
Glyn44
Make the film overlap long enough to reach the wood above/below the joiner slot, it won't matter that it's not actually adhered to the epoxy as the film will be bonded to wood either side of it. When you cover the second side (top of the elevator?) the film will be bonding to the overlap from the bottom covering. It's worked for me on countless models.
Alternately just don't cover the slot then seal the film edges with a smear of epoxy extending across the joiner, it's usually out of site in the elevator hinge line and I doubt anyone will notice.
  • 1 month later...
