GaryG Posted December 26, 2017 Share Posted December 26, 2017 I recently ended up with 2x Taranis X9d plus. I cannot get either to bind with the supplied receiver. No matter how many you tube videos I watch, or how many forums I check with, the issue will not resolve itself. I have decided that i am going to replace the radio with either the Hitec flash or Hitec aurora. Does any one have experience of both Hitec radios? I only have 4 aircraft to replace receivers in 2 trainers, arising star and tutor 2. Zĺin z50 and Phoenix glider. GaryEdited By GaryG on 26/12/2017 10:18:55 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted December 26, 2017 Share Posted December 26, 2017 hello Gary, I used futaba for 20 years +changed to 2.4 and decided after having a look at my friends Hitec A9 to give it a go.....user friendly and spot on in my opinion......oh and reasonable price.....consider it... ken Anderson...ne...1.... A9 dept. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted December 26, 2017 Share Posted December 26, 2017 I was faced with this choice some while ago. Should I go Aurora or Flash 7 then working out will I ever need 9 channels I opted for the 7. Still has all the needs of mixing switches expo etc etc I like the throttle warning set up and throttle lock even on switching on you are asked are you ready to transmit. Rc Plane Flyer .. Flash 7 Dept Edited By RC Plane Flyer on 26/12/2017 10:28:47 Edited By RC Plane Flyer on 26/12/2017 10:30:34 Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 26, 2017 Share Posted December 26, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 @GaryG, don't give up on the Taranis, it is one of the best value for money radios there are with features that put many much more expensive radios to shame. They are also very, very reliable and the Rx's are also brilliant value for money too. One of the problems I had when I first tried to bind my Taranis to a Rx was holding the Rx bind button down at the same time as plugging the Rx power in. In the end I enlisted the help of my wife! The sequence of operation I use is, put the Tx into bind mode (annoying beeps, beeps) then hold the Rx bind button down and plug in Rx per supply (red/green flashing lights on RX). Unplug Rx power supply, put Tx back into normal mode then switch Rx back on. Works every time for me but now I also have a switch that I use with the Rx battery to make it even easier and I no longer have to bother the wife. I am assuming that you have a FrSky Rx to go with the Taranis and not some other make! Edited By Ron Gray on 26/12/2017 10:57:47 Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Ron, the problem is that no matter what I do, I cannot get the taranis to bind with the receiver. If I cant get a bind I am as well replacing the radio Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 Sorry Gary, I edited my post after your last one! So to try and help, which Rx are you trying to bind? Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted December 26, 2017 Share Posted December 26, 2017 Hi GaryG, I can't advise on radio choice as I have no knowledge of them but don't give up on the Taranis just yet. Out of interest which receivers do you have and are the Rx and Tx on EU protocols and what bind process do you use. Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Ron and Devcon, thanks for the responses guys. I have been trying to bind to the 8xr's that came with the transmitters. Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 26, 2017 Share Posted December 26, 2017 Hi GaryG,I'm a Futaba man, but I agree with a colleague's Ron Gray statement that he does not have to give up on Taranis. I do not know if you tried to contact owners of Taranis on the forum?, one of them is our moderator Mr. BEB.I believe he will give you real advice. Merry Christmas Edited By Josip Vrandecic -Mes on 26/12/2017 11:08:39 Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Devcon, I didn't think that receivers had to be on eu protocols. How do you do that? I select bind within the transmitter options. Switch on receiver and push bind button. Thats the normal bind process, isnt it?Edited By GaryG on 26/12/2017 11:08:49Edited By GaryG on 26/12/2017 11:10:36 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 GaryG - as long as the protocols on the Tx and the Rx are the same they should work. So you have selected bind on the Tx and it is emitting the annoying beeps? Next hold down the bind button on the Rx BEFORE switching the Rx on. Switch the Rx on with the bind button still held down and you should now see a flashing LED alternating red/green. Switch the Rx off and switch Tx to normal mode or switch Tx off then back on again. Then switch Rx on, you should now see a steady green LED on the Rx. Quote Link to comment Share on other sites More sharing options...
iqon Posted December 26, 2017 Share Posted December 26, 2017 Dont give up on the Taranis, it will be something simple. Recently got the flash 8, It`s a great transmitter Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Well Ron i tried the bind process above and it didn't work. Thanks for trying to assist. Problem solved i just saw this online : Aurora 9 2.4GHz Transmitter, Optima 9 Receiver. Thanks for everyone's input. GaryG Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 Before you splash the cash: Was the Tx emitting the beeps indicating that it is in bind mode? Did you get the Rx to show the alternate flashing red/green LED? Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Ron, the tx was emitting the annoying beeps. The rx initially flashed red/green once then changed to solid red. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 What mode have you got selected on the Tx, D16? How close is the Tx to the Rx, greater than 3 ft? Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Ron I have D8 selected and yes the tx is around 6ft away. Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted December 26, 2017 Share Posted December 26, 2017 I've had the Aurora for about 5 years, it's been faultless. Having the touch screen to programme it is very intuitive. An excellent radio and I've been very pleased with it. I moved away from Futaba as the cost of the receivers was just going up all the time, the Hitec receivers have stayed the same. I've also bought a Hitec clone from Airtek but not used it yet. I saw that it's being discontinued so there should be some deals if there are any left. Quote Link to comment Share on other sites More sharing options...
GaryG Posted December 26, 2017 Author Share Posted December 26, 2017 Does ? 317 from Horizon sound reasonable?Edited By GaryG on 26/12/2017 13:43:22 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 26, 2017 Share Posted December 26, 2017 GaryG, change the mode to D16 and keep that distance to more than 3 feet! Quote Link to comment Share on other sites More sharing options...
Stephen Smith 14 Posted December 26, 2017 Share Posted December 26, 2017 Take the hammer to the taranis, that most of your problems solved and buy the aurora. Bind set up go fly simples Quote Link to comment Share on other sites More sharing options...
Tim A Posted December 26, 2017 Share Posted December 26, 2017 Gary, if your are going to switch to Hitec, go for the Aurora. I have an A9 and a Flash 8. Brought the Flash on a whim as my itchy finger hit the buy button, I did some research prior too but missed the fact that although it is good radio it is only a reasonably well featured basic starter level set. Not as well featured as the A9. It even say's that on Hitec's site somewhere. Although it has telemetry capabilities they are limited compared to the A9. It is also not upgradable nor has computer connectivity. As for the Aurora A9 & A9X being discontinued this is news to me, Hitec have been selling the A9 alongside the A9X since the A9X came out and they will still fill the gap between Flash8 and 16ch set feature and price wise. So there we go my tuppenny's worth. Quote Link to comment Share on other sites More sharing options...
