Rocker Posted January 28, 2018 Share Posted January 28, 2018 Anyone tell me what size bolt holds the Wots Wot XL spinner on ,not sure if it is a M4 or an M5 .need to order one Quote Link to comment Share on other sites More sharing options...
Tony F Posted January 28, 2018 Share Posted January 28, 2018 http://www.ripmax.com/Item.aspx?ItemID=Z-CF005/11&Category=900-010-110-140 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 28, 2018 Share Posted January 28, 2018 No one knows Rocker, which long bolt that you will settle on I have never seen a 5mm socket cap head used on a spinner All my spinners are M4, that is 4mm But you are going to order the M10 long nut from Just engines, so they will decide the caphead size Quote Link to comment Share on other sites More sharing options...
Rocker Posted January 28, 2018 Author Share Posted January 28, 2018 I am sure the bolt I need for the Laser 180 is an M10 bolt and a M4 thread for the spinner bolt to screw into .I give Just Engines a ring on Monday .Failing that I need to find a long M8 bolt and drill out the spinner to take the 8mm bolt Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 28, 2018 Share Posted January 28, 2018 This is what I did for mine, an 8mm hex head bolt turned down to the profile of the spinner then drill the spinner out to take the 8mm bolt: Sorry about the orientation of the photos, the upload decides which way round they go! Anyway, if you would like one I can machine one for you so that you can use the Laser supplied bits, just pm me your postal address and I'll get one made tomorrow. Quote Link to comment Share on other sites More sharing options...
Rocker Posted January 28, 2018 Author Share Posted January 28, 2018 Brilliant ,that is really good of you to do that .I have e-mail you my address , let me know how much I owe you and I get a cheque of to you Thanks again Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 28, 2018 Share Posted January 28, 2018 I cut a piece of M10x1.5 bolt to fit inside the Laser sleeve nut then drilled and tapped it to accept a M4 spinner bolt. We really should not have to resort to such measures. Most will not have the use of a lathe. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 28, 2018 Share Posted January 28, 2018 Just double checked the 160v against the 155, the 160 has an 8mm shaft against the 155’s 10mm, so the 8mm spinner bolt will be no good. Check with Just Engines tomorrow to see if they do a suitable adapter to fit a 10mm x 1.5 shaft, if you get no joy let me know and I’ll make an adapter similar to that described by Martin. Quote Link to comment Share on other sites More sharing options...
Rocker Posted January 29, 2018 Author Share Posted January 29, 2018 Just rang "Just Engines " about this problem and they where really helpful..They have exactly what I needed.and will post it out today so hopefully problem solved I can not recommend "Just Engines " enough ,they where really good and went through the options with me and recommend the best option.They are the people to ring with regard any engine query 10 out of 10 for customer service Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 29, 2018 Share Posted January 29, 2018 Second that Rocker, they are a really good company and glad they solved your issue. Quote Link to comment Share on other sites More sharing options...
Rocker Posted January 31, 2018 Author Share Posted January 31, 2018 Received the nut adaptor from "Just Engine " Spinner all secure and everyone will be glad the Wots Wot XL is finished ans awaiting it's maiden flight when this windy weather gives up and our flying strip dries out (,at the moment our field is waterlogged) might have to wait till the spring but I am sure the wait will be worthwhile and have great confidant that the Wots Wot XL will fly great Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 31, 2018 Share Posted January 31, 2018 Can't remember Rocker, but have you sealed the joints on the covering yet, if not I advise that you do as they tend to lift after not much flying. Quote Link to comment Share on other sites More sharing options...
Rocker Posted January 31, 2018 Author Share Posted January 31, 2018 Yes went over all the edges and transfer with clearcoat ,two coats so that hopefully will help there .Just run up the Laser 180 and as I would expect from a Laser started second flick with a chicken strip ( not an electric starter) and ran perfectly ,just richen the main jet by half a turn ,ran perfect retuned the main jet after a short run ,tick over was fine so left well alone .Jon has done all the hard work setting the 180 up so left it alone ( good job there Jon it was perfect ) Now the maiden to do Quote Link to comment Share on other sites More sharing options...
