Biggles' Elder Brother - Moderator Posted October 7, 2018 Share Posted October 7, 2018 Go on Percy! You know what they say - given enough power anything will fly! (But that one would be a challenge I'll conceed that! Smashing idea on the hatch - I can see everyone at the strip being dead jealous as you flick a tx switch and catch the flying hatch in the other hand - very slick! BEB Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 7, 2018 Share Posted October 7, 2018 Certainly solved the problem of sufficient airflow for cooling... Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 7, 2018 Author Share Posted October 7, 2018 We may have to create a rule at the club which means hatch jettison must not be carried out in the pits. Funnily enough your posts reminded me of what happened to my Fun Cub when Action Man jumped... Guess what you can see above the Rudder Back on topic. Stabilising surfaces covered but will be fitted after the fuselage is covered. The film was found on Ebay and turned out to be from Als Hobbies. Was very, very good value at £8.95 for 5 metres, doesn't have the removable clear protective film which I discovered after 5 minutes of trying to peel, the non existent, layer off. Very easy to use, highly recommended . The Eagle Eyed will have spotted what could be described as a school boy, or girl, error but I can assure you it is all part of the plan... Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 8, 2018 Author Share Posted October 8, 2018 Continuing the theme, fuselage done. Cowl sprayed in a matt black. Quote Link to comment Share on other sites More sharing options...
trebor Posted October 9, 2018 Share Posted October 9, 2018 Is that a real ActionMan ? Or a smaller imposter ? Only asking as my Red Devil is ready to go Quote Link to comment Share on other sites More sharing options...
Gary Murphy 1 Posted October 9, 2018 Share Posted October 9, 2018 Devcon1, great build keep looking for the next instalment. Being a novice can I ask 2 questions? The lightening holes in the fuse,is the weight saving noticeable? and surprised how square the tail front egdes are? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 9, 2018 Share Posted October 9, 2018 I thought the square edge was the actually planned schoolboy error? Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 9, 2018 Author Share Posted October 9, 2018 A couple of answers, a bit misleading on my part on the brand front. A bit like referring to all vacuum cleaners as Hoovers. What I should have said is HM Armed Forces Parachutist instead of the original great Action Man, he has been on some great drops though. He's the same size as AM but a bit heavier I think but. The blunt leading edge is deliberate as I want to have a slightly mechanical/techno look to the finished product which will be revealed a bit later, on a model of this scale and purpose I'm not overly concerned about aerodynamic rules. In my eyes the weight reduction is worth it but I accepts some will see it as a pointless exercise, what I would say is have a read of the excellent article in the current RCM&E special by Richard Crapp which takes weight saving and great justifications to a different level. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 9, 2018 Author Share Posted October 9, 2018 No photographical evidence of progress but. Spent some time creating the basic model template on OpenTx Companion then setting up a FrSky Sbus decoder linked to an X6R. What a neat little bit of kit it is, I'll have 4 wing servos to drive Ailerons and Flaps but what a joy it will be to only have one dangly wire to grapple with in the winter. What I did learn though was the decoder seems to favour digital servos only, the FrSky manual was a little vague but all was explained on a great thread on this forum. When connected to the normal servo output my Hitec 225 behaved normally but when connected to the Sbus decoder it struggled to return to neutral consistently and buzzed a bit. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 10, 2018 Share Posted October 10, 2018 for SBUS, nice easy to connect wings, used it on my Radial Rocket Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 10, 2018 Author Share Posted October 10, 2018 That's neat, I'm thinking of soldering on a dog leg or pins from an old servo connector to get connection no 4 to sit parallel/flat with the other 3 connectors. I wonder why they made that last connection stand up ? Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 10, 2018 Author Share Posted October 10, 2018 All tail feathers will be hinged with Blendtherm tape so I tried a little mock up of the rudders. A single peice up the centre of the vertical stabiliser. Them attach the two rudders. Fold over and a single strip on the outer hinge line for each side. Seems to work OK and keeps the weight down and a clean look to the model. Talking of weight, the concept of losing a little from every possible component has got the better of me. Casting aside the metal elevator joiner I've replace it with thick walled alloy tubing, seems more than strong enough for the job and the figures give me some satisfaction. 2 at the back is 10 at the front. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 12, 2018 Author Share Posted October 12, 2018 Found a solution to make visible the LED display on the FrSky LiPo Sensor, I know I have the data via telemetry also but the placement will be in keeping with the final look. Trim made from a hand cream lid, painted then finished with an acetate window. Not quite happy with the crumpled edges so will seek a fix.. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted October 12, 2018 Share Posted October 12, 2018 Some really great imaginative ideas here Devcon - its going to be a stunner when its finished! BEB Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 14, 2018 Author Share Posted October 14, 2018 Lipo Sensor installed. I shortened the the balance lead extension and neatened the cable by positioning the layout and then warming with a a hot air gun. To keep the install neat the balance lead socket is epoxied in place. The sensor itself is mounted on a film covered backboard purely for visual effect. T Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 14, 2018 Author Share Posted October 14, 2018 Thanks BEB, it's been a real fun build/tinkering project so far. Motor and ESC now installed together with the fuselage radio. I've modified the pin arrangement on the FrSky Sbus decoder to tidy up the installation, still can't fathom why they have 3 connections horizontal and 1 vertical but hey ho.. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 16, 2018 Author Share Posted October 16, 2018 It's a very long time since I played with some of these but looking forward to it. Bits starting to arrive for the wing project Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted October 16, 2018 Share Posted October 16, 2018 Mmmmm, intriguing! Lots of ball bearings for a wing,....should be interesting. BEB Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 16, 2018 Share Posted October 16, 2018 Folding wings for storing on aircraft carrier! Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 16, 2018 Author Share Posted October 16, 2018 Folding wings, now that would be fun on a WOT 4, maybe the next one. Other items needed, 2mm carbon rod, 4mm alloy rod and some Plastruct T profiles. Fuz nearly done. Never liked the way those plastic horns had the external clamping plate so have recessed the plate and covered with film. Happy with the way the rudders have come out. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 16, 2018 Share Posted October 16, 2018 Hmm, hidden radial drives? Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted October 17, 2018 Author Share Posted October 17, 2018 Not radial drives but I do like the concept. The other bits have arrived, the fuselage is completely finished now so work on the wing to commence. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 18, 2018 Share Posted October 18, 2018 Caterpillar track for the undercarriage? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 18, 2018 Share Posted October 18, 2018 What's the T track for, airbrakes? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted October 18, 2018 Share Posted October 18, 2018 We have threaded bar, a rider nut and bearings,...some sort of indexing mechanism or linear drive? But 10 beaings is a lot - it better be useful cos it's going to be heavy! I'm puzzled! BEB Quote Link to comment Share on other sites More sharing options...
