Nigel R Posted September 25, 2018 Share Posted September 25, 2018 In which case you've got the answer - the circuit you already posted the diagram of. Change your pot for the proper value & power one, add an ammeter, and you're home dry. Quote Link to comment Share on other sites More sharing options...
Dickw Posted September 25, 2018 Share Posted September 25, 2018 Unfortunately the proper value and power pot is probably something like this. Actually this would be better and you don't have to buy 10 if them. Might be able to find something cheaper on ebay though. Please note, it is the current you are controlling with the OP circuit, not the voltage. Dick Edited By Dickw on 25/09/2018 13:21:34 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 25, 2018 Share Posted September 25, 2018 A very simple solution would be to add another terminal for lower voltage plug usage and wire this via a short length of nichrome wire to add a small resistance. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 25, 2018 Author Share Posted September 25, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dickw Posted September 25, 2018 Share Posted September 25, 2018 Posted by supertigrefan on 25/09/2018 15:43:55: ........ I get that it's the current that is regulated but glow plugs are rated in volts, hence my reference to the Voltage. .......... **LINK** Sorry didn’t explain myself very well. Just wanted to make sure you understood that in the original circuit you linked to you cannot set the voltage using a voltmeter before connecting the plug – it will just show battery volts. You have to connect the plug then adjust the amps to suit the plug – you can use a voltmeter at this stage, but with a bit of experience you can soon make your own scale for the pot. A lot of interesting reading in that link! Dick Quote Link to comment Share on other sites More sharing options...
robert chamberlain Posted February 2, 2019 Share Posted February 2, 2019 sometimes my "Nistarter" gets a little low by the end of the afternoon. This is the kind with the batt and little meter that pushes onto the glow plug. I still have my good 12 volt batt on the tool box,--so how can I give the 1.5 glow starter a charge up from the 12V? I do not have a power panel. Resister of some value?---or for that matter, instead of trying to recharge the Nistarter, just run a line from the 12 V with a long voltage dropping wire and/or big resister? Of course, I guess I could just but 2 Nistarters! ---Thank you,---Bob in KS,USA Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 2, 2019 Share Posted February 2, 2019 Easiest is to have 2 glow sticks Bob, But read through this if you are an experimenter **LINK** Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted February 2, 2019 Share Posted February 2, 2019 This has been published on here previously by me and is as easy to make as you can get. The plug voltage will be as measured with or without a plug connected. R `x` can be zero Ohms if you wish because the minimum output voltage is an ideal 1.2V, or you could add a couple or so Ohms if you wish it to be higher. Pump and starter included on the panel. Use a separate 1S Lipo for the glow to reduce heat in the regulator to a minimum. Quote Link to comment Share on other sites More sharing options...
