fly boy3 Posted February 24, 2019 Share Posted February 24, 2019 Hi all, my Winter build is the Flying Aces Sportster down load from Outer zone. 54 inch w/s AUW 3 1/2 lbs. I have always used Futaba 148 servos over many years of building models, and I will use 5 in total on this model. As the fus is less than 2 inches wide, I wondered if these servos are over kill. 5 Fut.148 are nearly half a pound which seems a lot for a 3 1/2 lb plane. Looking at HK 9g servos steel gears. Wonder if these are suitable. Cheers Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 24, 2019 Share Posted February 24, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted February 24, 2019 Author Share Posted February 24, 2019 Thanks Percy, I do like the spec of the Hitec you mentioned, certainly will fit in my wings. I assume plugs will fit my Futaba gear ? Cheers Quote Link to comment Share on other sites More sharing options...
Andrew767 Posted February 24, 2019 Share Posted February 24, 2019 FB3 Yes the plugs will fit but as Percy suggests have a look at the radients. If in doubt, give Peter at Airtek a call. He is always very helpful. Andrew Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 25, 2019 Share Posted February 25, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted February 25, 2019 Share Posted February 25, 2019 Hi I have used Hitec gear for many years and my only comment would be the HS81 is a little gem to fit in tight spaces but you have to be careful not to knock them via the surface it is controlling as you will need to find replacement gears Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 25, 2019 Share Posted February 25, 2019 Posted by RC Plane Flyer on 25/02/2019 08:40:25: Hi I have used Hitec gear for many years and my only comment would be the HS81 is a little gem to fit in tight spaces but you have to be careful not to knock them via the surface it is controlling as you will need to find replacement gears 4 times before I learned my lesson and bought the HS 82MG As you say knocking a control surface strips the gears The mechanical force must be enough by knocking a surface Edited By Denis Watkins on 25/02/2019 10:26:41 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted February 25, 2019 Share Posted February 25, 2019 You can get the 9 gram metal geared servos . They take a knock without any damage to the gears . The actual servos depends greatly on the load or size of the surfaces , type of or speed of model and flying style . As its vintage style racer the 9 grams would probably be fine power wise but metal gears definitely . Quote Link to comment Share on other sites More sharing options...
Dickw Posted February 25, 2019 Share Posted February 25, 2019 I can back up what Engine Doctor says - I use 9gm servos all round in a 1.7Kg (3.75lb) 150 mph+ multi task electric glider. They have performed reliably over several years - including the odd control surface knock. I have been using KST X08 for the past few years but have also been OK with Hyperion and some others. Dick Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 25, 2019 Share Posted February 25, 2019 HS82MGs would be top of my shopping list. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted March 8, 2019 Author Share Posted March 8, 2019 Hi all, took your advice and my Hitec hs81,s arrived today. Being Futaba 148 man all my modelling life, boy these look small lol. I assume I will have to enlarge the holes in servo arms to suit my standered push rods ? Cheers Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted January 2, 2020 Share Posted January 2, 2020 Somehow I have been unaware of this thread! Mine was originally fitted with Ripmax SD200s. Horrible things which have been popular over the years but in my experience have not lasted long - end up jittering when re-centering. I replaced them 7 years ago with Hitec HS81s and these have been perfect, even in 30mph wind, which for this model is quite a challenge. If I was doing it today I would consider MGs but I don't think they are really necessary. My sportster has been in regular use all these years, unfortunately a recent water main burst which flooded my garage has soaked the wing roots and alas it's not safe to fly. FB3 have you completed and flow yours? Quote Link to comment Share on other sites More sharing options...
