Fuse
david miles 7
Hello Everyone.
This is my first post.
I have just downloaded the plans for a Frog Diana 36 inch wingspan glider. I notice that there is a "string fuse" at the end of the fin. Can anyone tell me what it is for? This is my first attempt at building a model glider!
Thanks for any help.
David Miles.
I'll take a guess that this fuse is inserted into the rubber band holding the trailing edge of the tailplane down, and that there is a wire hook arrangement on the leading edge with a second rubber band engaging this wire hook and passing around the fuselage thus holding the front of the tailplane down. This arrangment is known as a dethermaliser, when the smouldering fuse melts the rear rubber band the front band pulls the tailplane up to an angle of about 30 degrees, fully stalling the model which then comes down like a parachute. It was aimed at limiting flight times to a few minutes and hopefully preventing the model vanishing upwards or downwind if it caught a thermal.
Of course what Bob and Pat describe is for free flight and not needed if using Radio Control. There are still a few people flying free flight now but it needs plenty of space and that's not easy to find. So most use RC.
The next question is do you want to make such a small glider for RC or make something which is easier to see?
David maybe you should ask the question " which is the best glider for a beginner to build from plans "
IMO around 6ft span is the best size for decent performance, visibility & ease of build matched to bouncability.
The Orangebox plan downloadable here is a good example, they are simple to build, robust, good control & have a decent performance.
Personally I'd make a couple of simple mods. I'd make the wings 2 piece for ease of storage & transporting. Also I'd change the fin & rudder to have a vertical hinge line in order to have a sensible horn linkage & for aesthetics.
There are a few 'different' gliders.
Are you looking for a free flight glider or radio controlled ?
Do you have a flat field to fly or are there hills and slopes ?
Do you want a hand launch, (just throw), tow line, or catapult launch ?
There can be differences in the design, and how you would like it to fly, they could influence an suggestions. Not trying to be awkward, just trying to get an idea of what you want to give you the best chance of a success, and a good introduction to modelling if this is your first model.
Posted by PatMc on 22/03/2019 14:22:59:
I'd agree with pretty much all of that Pat.
I've got an old Orangebox and one of the great advantages of the way the fuselage is built really helps a beginner to get a straight, accurate fuselage. Mine has got wings that split in the middle using brass tubes and piano wire dowels.
Mine has the fin and rudder with angled hinge line which works ok with a closed loop linkage, even though as Pat says it is not great aesthetically.
It does go well from the slope or flat field (I've bungee launched it and used a power pod over the years). It's a tough, no-nonsense design!
I had an Orangebox back in the late 70s-80s and it was versatile and as Alan did, I flew it from slopes, off a bungy, with a Cox .049 glow motor on a pylon and then later in it's life I replaced the noseblock with a mount for an old style brushed motor and folding prop. I built a second wing with a couple of bays less each side that I used for slope flying on windy days. A similar model in kit form would be the Westwings 'Orion' or the DB Sport & Scale 'Rookie'
David, a small model might appear to be an ideal solution for a beginner, but in reality they can be tricky to construct accurately, and you may well wind up putting a lot of effort into something that is frustrating and won't perform well. Give yourself a fighting chance and select a glider of around a couple of metres wingspan and see how you get on. A Balsa Cabin Sonata kit is a good one, inexpensive , can be configured as a sloper or thermal soarer or for electric power. With a little care it'll.be a guaranteed performer.
Edited By Cuban8 on 22/03/2019 15:44:30
PatMc, I've been toying with building a flat field soarer, is a 100s type much better than an Orange Box type. I would like a casual low key machine, probably with a motor on the front. Plan build. Not a great investment in time.
Edited By Don Fry on 22/03/2019 16:57:29
Hello All.
Thanks for replies. I haven't started building yet, so advice on best model type would be most welcome. I would like to start by making a F/F glider. I know a rural site on a small hill that I thought would suit hand launching ( perhaps discus launch?) and a fuse arrangement - just incase I get lucky with my first plane!
I will download the "orangebox" plan to have a look as well.
David.
Posted by Don Fry on 22/03/2019 16:57:05:
Don, from the performance POV the greater the wingspan the better.
When I previously mentioned 6ft span being good it was with David's lack of building & presumably flying experience in mind. IMO 6ft is about the minimum span generally for a decent thermal performance & visibility but about the max size for the other factors mentioned.
A 100" span glider would be a step change in overall performance & flexibility compared to a 6ft span. Mind you if I was considering scratch building a 100" sports thermal glider I'd go to 108"+tips span as balsa wood comes in 3ft lengths. wink 2
Ooh - it would also have an electric motor up front driven by 3s lipos.
Edited By PatMc on 22/03/2019 19:38:46
I suggest you look at what the local clubs do - you will get an idea of whether a glider or perhaps a motor glider might suit you. Gliders with a small electric motor are popular now.
If free flight is your thing then it's worth finding out what people do nowadays - I think fuses are thought to be a fire risk and some sort of timers are used now instead. Free flight is a specialist thing and quite rare now but there are a few real enthusiasts somewhere. Look at the BMFA website for info.
I think that even free flight gliders would be covered by the laws that prevent flying within 5 k of airfields so you need to be careful where you fly and also have insurance.
Thanks for everyone's input. I feel that there is real depth of knowledge on this forum. I feel like I am wanting to go from zero to 100mph before even learning to drive, but that is just the way I am, I usually choose the steepest learning curves when I decide to try something new!.
One last question. After looking at lots of designs,( and I think that there are so many that it is starting to confuse me as to what to choose! ) it appears to me that the gliders with a "stick type" body should be easiest and quickest to make. Am I correct, or am I overly simplifying things?
David.
A square box is the easiest to make because it is the easiest to get everything square, and symmetrical. If you are starting out, a good kit is IMO the way to go, because you have some instructions to follow, and the wood supplied will be fit for purpose (hopefully).
PatMc, thank you for that, I will store that knowledge away.
If you are looking for a FF glider then Ripmax have just started producing Keil Kraft kits again and they have the Caprice and Invader models. Steve Webb models have them on their website.
Belair also produce some laser cut parts for FF gliders but you will need to by extra wood and get hold of the plans for some. If you go down that route the Mercury Gnome is an easy build and very robust for your initial attempt - you can down load the plan from OUTERZONE website.
But, I would advise, you are on a radio control website. Search the Web, "free flight gliders".
They will be a lot more knowledgeable about that branch of the hobby, and bottom line they will be more up to speed about current trends, and responsibilities, of free flight machines. Be aware, you can get seriously in trouble with old bill if you fly too high, or in the wrong place.
And, you have not yet have the joy of watching you pride and joy, climb in a thermal, and disappear from a dot in the sky, to nothing, before the fuse burnt through.
I would fit a radio controlled version of the fuse.
Mind instead of doing that, I would fit a second servo in the elevator, and rudder, and you get back to an Orangebox.
My first 30+ years in the hobby were all free flight but it will be 15 years or so since I last built one so I'm out of touch with current trends and regulations.
I must confess to many happy years free flighting but one of the main problems was always space. Clubs tended to negotiate use of old airfields for flying meetings so you couldn't just turn up and fly whenever. If you were really lucky, the weather would be flyable when you had a meeting. Even then, models would sometimes fly beyond the airfield boundary and some form of dethermaliser like the one described and shown earlier were a must.
I don't have the ability to walk too far these days but even if I could, I no longer see the fun in a half mile hike after every flight, coming back with my feet caked in mud from some farmer's field or being scratched to ribbons in the undergrowth, hopefully with the model in one piece.
The glory days of free flight are fast slipping away as space is lost and more and more regulations restrict flying. With radio control, you don't need the same amount of space so clubs tend to be more local and have flying sites rented from a local farmer or land owner. These are often available to members seven days a week so poor weather conditions become less of an issue and landings are usually only a few yards away from your feet.
Although I look back on my free flight time through rose tinted glasses, radio control is certainly the more viable and sensible option these days, in my book anyway.......Being far more of an old school plan or scratch builder than a flyer myself, I admire your desire to build from a plan. Whatever you choose, enjoy it and learn from the experience. smiley
We used to use the auto rudder to keep the model circling, as you say, which with luck on a calm day would keep the model somewhere near the launch site give or take 1/2 a mile. If the model gets into a good thermal it can vanish upwards to several thousand feet surprisingly quickly, any wind at all and it could travel miles. Even if it comes down within that half mile it can take binoculars to keep track of it. If you want the model back invest in a dethermaliser, the clue is in the name!
