Funcub replacement ?
trebor
A sad day today, I put my old go to model into the top of a tree crying The damage it received getting it down has made me very sad. I liked flying it but what can I replace it with ? Or do I just get another, what do you chaps recommend ?
The Riot is OK, I've got one and before I got my ARTF Wot4 Mk2 (balsa) was my 'go to' model (it still is sometimes) but it's very different from either a Fun Cub or a Tundra (I have both). The thing I don't like about the Tundra is the number of tiny screws you need to fit to assemble it (and I've had some plastic threads strip). It flies well but I prefer the FunCub.
I don't know about the Wot4 foamie as I've never flown one but I'm fairly sure it won't have the short take-off/landing as the FunCub and doesn't have flaps to play with.
Geoff
I'm on my 4th Wot 4 foam-e. The others succumbed to abuse and , er, enthusiasm. It's the best all round hack I've ever had. Geoff - even with the standard motor and prop it will leap off the ground every bit as quickly as a Fun Cub!
No flaps though - it doesn't need them. But if you must have flappage, then another Fub Cub or the Tundra is the way to go.
