Peter Miller Posted September 9, 2019 Author Share Posted September 9, 2019 There wos a touch of up elevator but when I corrected it went down much harder than I would expect.. The symptoms of a rearward CG I agree. Elevator control throws at low rates are 1/4" each way. Next time I will reduce throws and also reduce the power by using a smaller prop and allow it to gain more height before correcting. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 9, 2019 Author Share Posted September 9, 2019 I have now solved the problem pf why it dived into the ground. It was basically a total idiot called Peter MIller. My only excuse is that I have been having problems with a mains water leak, a semi blocked sewer and a pigeon stucj half way down my chimney for four days. As a result I have been stressed out and tired out When I set the controls up the elevator servo must have been out of line and even though the control directions were independantly checked on the field no one noticed what I should have seen at home, at neutral elevator stick I actually had half down elevator. As I have saind many times "I can't help it if I am thick!!!" Quote Link to comment Share on other sites More sharing options...
Paul C. Posted September 9, 2019 Share Posted September 9, 2019 Good to hear you have found the cause it's easy to get distracted when other things are going wrong 😨 . We had to get wire covers put on our chimneys after a magpie decided to pay a visit , ended up with bird plus a load of soot in the living room 😈 Quote Link to comment Share on other sites More sharing options...
kc Posted September 9, 2019 Share Posted September 9, 2019 It can happen to anybody Peter! I had noticed that your static shot showed some down elevator while the inflight shot showed some up which made me wonder if the elevator was reversed or perhaps jamming. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 9, 2019 Author Share Posted September 9, 2019 I console myself with the thought that Roy Chadwick, designer of the Avro Tudor was killed in one which took of with the aileron controls reversed. Now that takes some doing!! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 16, 2019 Author Share Posted September 16, 2019 Well yesterday was perfect and I was able to fly Moon Dancer 2 and getthe flying shots. It is highly aerobatic and I flew the usual aerobatics plus my square loops and four point rolls. It really needs a slightly larger rudder to fly sustained knife edge but I am happy with it as it is. Quote Link to comment Share on other sites More sharing options...
kc Posted February 14, 2020 Share Posted February 14, 2020 The last issue of RCME said the Moon Dancer 2 would be a plan in the March issue due out on 14th Feb - that's today. Has anybody got their copy yet? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 14, 2020 Author Share Posted February 14, 2020 No and subscriptions usually arroive on the Monday before the publication date Quote Link to comment Share on other sites More sharing options...
MaxG Posted February 15, 2020 Share Posted February 15, 2020 Mine arrived this morning complete with Moon Dancer plan. Excellent. Maxg Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 15, 2020 Author Share Posted February 15, 2020 Posted by MaxG on 15/02/2020 12:16:30: Mine arrived this morning complete with Moon Dancer plan. Excellent. Maxg so did mine. They have done a reallynice spread Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 16, 2020 Share Posted February 16, 2020 Well just finished my Lysander, bench clear Moon Dancer 2 plans attached to building board. cutting starts tomorrow..... want something to get my rolls better, this looks like it may help me! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 16, 2020 Author Share Posted February 16, 2020 Have fun with her Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 16, 2020 Share Posted February 16, 2020 Thank you Peter, I've started a build log album, and will photo document as I go.many thanks for what looks like a great easy to and quick to build model. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 17, 2020 Author Share Posted February 17, 2020 These days I like quick and easy!! I willlook forward to your build album Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 18, 2020 Share Posted February 18, 2020 Well made a start, all plan parts cut, I have cut the rudder slightly larger so I can decide later what to use... Edited By charlie holdford on 18/02/2020 18:49:52 Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 18, 2020 Share Posted February 18, 2020 Ready to start building.... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 18, 2020 Author Share Posted February 18, 2020 Very smart!! And that bench looks disgustingly clean!!! Quote Link to comment Share on other sites More sharing options...
dan h Posted February 18, 2020 Share Posted February 18, 2020 hi charlie. i will be watching this one with interest. those parts look very neat, dan Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 19, 2020 Share Posted February 19, 2020 I do make a big mess, honestly Peter! But I have a working restriction, from the station commander, that I must clear up. As this is the only restriction I obay religiously , Hi Daniel, Thanks, hopefully the photos will help, and any non plan mistakes that I make will certainly help you.... Some progress today, glue the ply doublers. Then I started cutting for the next longer term build (72" Lancaster) The LED lighting over the desk creates interesting colour on photo's Edited By charlie holdford on 19/02/2020 19:04:10 Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 20, 2020 Share Posted February 20, 2020 Made a start on putting the fuselage together. Due to the doublers it needed a bit of assistance to keep it all square as the glue dried. Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 20, 2020 Share Posted February 20, 2020 Still it worked, so far its all straight and square... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 20, 2020 Author Share Posted February 20, 2020 I cut 90 degrees triangles of 1/8" balsa and super glue them in place to hold the formers vertical. Just my way of doing the job. Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 22, 2020 Share Posted February 22, 2020 Hi Peter, Thanks for the tip. I have just adding the last few former's and have found a discrepancy in the plans. The F6 former cutout is 5mm too short. Making the top stringer out of alignment. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 22, 2020 Author Share Posted February 22, 2020 Sorry. Missed that during checking the proofs. I should just glue an extra piece of 1/8" sheet across the bottom of the former. Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted February 22, 2020 Share Posted February 22, 2020 No problem, so much easier to find when its someone else ... that's what I did Quote Link to comment Share on other sites More sharing options...
