Bill Reed Posted September 5, 2019 Share Posted September 5, 2019 Having probs with the following. How do I get the Timer to work on the throttle time rather than "stop watch" sort of thing? Also I have a "save recovery" function on a BNF and would like to tie it to the trainer switch,can not find how to do this with no TX manual Quote Link to comment Share on other sites More sharing options...
JOHN MOSLEY 2 Posted September 5, 2019 Share Posted September 5, 2019 Press top of roller switch, scroll down until you get to timer, press top of roller switch, scroll down till start is highlighted.Move throttle stick you see Thr stick. Press back button. Test time starts when throttle is over 25% by default. Edited By JOHN MOSLEY 2 on 05/09/2019 13:16:28 Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 5, 2019 Share Posted September 5, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 5, 2019 Share Posted September 5, 2019 I think you may be right Steve. Edited By Piers Bowlan on 05/09/2019 14:44:16 Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted September 5, 2019 Share Posted September 5, 2019 You can definitely do it on a DSX9 Mk2. Not sure about Mk1. Quote Link to comment Share on other sites More sharing options...
JOHN MOSLEY 2 Posted September 5, 2019 Share Posted September 5, 2019 As I posted incorrect info, thought I should clarify. DSX9 is the JR Transmitter, I misread it for a Spektrum DX9. Sorry Quote Link to comment Share on other sites More sharing options...
Jeff Langley Posted March 2, 2020 Share Posted March 2, 2020 Hi All, I've just acquired a JR DSX9 transmitter, & have a couple of queries about it's use & abilities, hopefully they're not overly inane! First off, where does the Buddy Lead plug in to the tranny, & is a standard lead usable? Second, can you assign one of the stick outputs to a switch? Either slider or toggle. Thanks a lot, Regards, Jeff. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 2, 2020 Share Posted March 2, 2020 The buddy cord goes in the DSC socket in the back Jeff And just a note about toggle swiches, they are on or off, so not proportional The levers are proportional and assignable Quote Link to comment Share on other sites More sharing options...
Jeff Langley Posted March 11, 2020 Share Posted March 11, 2020 Cheers Dennis, Yes, I'm OK with the toggle/lever differences, but my query was probably a bit mad, but I have a 3 channel leccie fun foamie, with a 4 channele receiver (new Spektrum type) & had a thought (dangerous I know!). Could I re-assign the redundant aileron out put (joystick) to a "switch", & use it as a flap output? Be pleased to have any thoughts. Thanks, Jeff. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 11, 2020 Share Posted March 11, 2020 Mixing, AIL to FLAP on Mix Switch Mixing Mixing allows control input for a channel to affect more than one channel at a time. Mixing functions support: • Mixing a channel to another channel. • Mixing a channel to itself. • Assigning offset to a channel • Linking primary to secondary trim. These mixes are available for each model memory: • 10 programmable mixes • Cyclic to Throttle (HELI) • Swashplate (HELI) • Elevator to Flap (ACRO) • Aileron to Rudder (ACRO) Assigning a Mix to a Switch If you wish to assign a mix to a switch position: 1. Make sure you are in the desired mix screen. 2. Move the switch you want to assign the mix to. 3. Scroll to the switch position where you want the mix to be active. 4. Press the scroll wheel to activate the mix. When the box is filled, the mix is active. The mix is Active when the box is filled and Inactive when the box is open. You can assign a mix to be active in multiple switch positions (0,1 or 2). Tip: Use Auto Switch Select to select the switch. CAUTION: Always do a Control Test of your model after changing mixes. Back Mixing Back Mixing applies a mix to all related servos in a wing or tail type. For example, if you select 2 AIL, 2 FLAP in the Aircraft Type screen, a mix to one aileron channel affects both aileron servos. The mix response, however, depends on the aileron channel included in the mix. A Back Mix also enables you to use fewer mixes to achieve the desired response, for example adding roll to a split elevator. 28 • Rudder to Aileron/Elevator (ACRO). • Aileron>Rudder (SAIL) • Aileron>Flap (SAIL) • Elevator>Flap (SAIL) • Flap>Elevator (SAIL) Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted March 11, 2020 Share Posted March 11, 2020 You make it sound so simple Denis Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 11, 2020 Share Posted March 11, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted March 11, 2020 Share Posted March 11, 2020 Clever! And simple. Might just work. Adding flaps to a 3 channel model may not be so straight forward. Quote Link to comment Share on other sites More sharing options...
Jeff Langley Posted March 12, 2020 Share Posted March 12, 2020 Thanks so much Dennis, I really do appreciate the help. I don't think I realised how comprehensive the DSX9's abilities were when I bought it! Looks like I've got lots to learn! I'll work my way through all you've listed, & see what I can achieve, thanks again, Regards, Jeff. P.S. Have you thought about writing a fully understandable user manual for the DSX? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 12, 2020 Share Posted March 12, 2020 Jeff, that post is part of the manual slightly edited But are lines of mix that I found useful before Everything needed from the Tx, makes sense when you aim for a certain outcome Quote Link to comment Share on other sites More sharing options...
