Trevor Grace 1 Posted September 20, 2019 Share Posted September 20, 2019 can i change the channel of a used Rx with my DX7 as i cant remember the channel it was origenaly set up to. Quote Link to comment Share on other sites More sharing options...
Brian Lambert Posted September 20, 2019 Share Posted September 20, 2019 I am not sure what you want to do, 2.4GHz systems are not channelized, you just need to bind the receiver to the transmitter. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted September 20, 2019 Share Posted September 20, 2019 Trevor. Try explain what you are trying to do please. As the question makes no sense at all. Are you new to the hobby ? Quote Link to comment Share on other sites More sharing options...
Trevor Grace 1 Posted September 20, 2019 Author Share Posted September 20, 2019 not sure what channel it was origanly used on and cant get it to rebind .may be easier to buy a new Rx. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 20, 2019 Share Posted September 20, 2019 2.4GHz systems don't have "channels". Is your problem actually that the bind process is failing? Try it outdoors, with the TX about 10 or 20ft from the RX. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted September 20, 2019 Share Posted September 20, 2019 Trevor, are you saying, can I change the model memory of a RX used with my DX7.? Quote Link to comment Share on other sites More sharing options...
kc Posted September 20, 2019 Share Posted September 20, 2019 Have you fitted the Bind plug when trying to bind? ( Bind plug for Spektrum is a Rx plug with a tiny streamer attached) Edited By kc on 20/09/2019 09:45:36 Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted September 20, 2019 Share Posted September 20, 2019 OkTrevor. so you need to re bind the rx ? Is it the same rx that was bound to the DX7 ? Have you done any software updates ? Is the tx and rx batteries fully charged ?Any Spektrum users please expain how to bind the rx to his DX7. Quote Link to comment Share on other sites More sharing options...
Trevor Grace 1 Posted September 20, 2019 Author Share Posted September 20, 2019 Hi Don Fry, YES Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted September 20, 2019 Share Posted September 20, 2019 ARR so you want to use the rx with another plane ? Yes ? answer is yes . re bind the rx. Spectrum has model match. for safety. so you can not fly the wrong model. and the memory is in the tx not the rx. Edited By CARPERFECT on 20/09/2019 10:24:38 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 20, 2019 Share Posted September 20, 2019 I don't know Spektrum well but could there be any issues around transmitter compatibility - i.e. DSM2/DSMX modulation - or, given the lack of info re. the OP's experience, is the receiver actually a Spektrum (or compatible) one? For those used to 35MHz PPM interoperability the concept of dedicated receivers for proprietary systems may be new... Please supply details of your "new" receiver. Edited By Martin Harris on 20/09/2019 10:58:45 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted September 20, 2019 Share Posted September 20, 2019 Switch on transmitter, go to the memory you want to bind the receiver to. Enter the menus, go to system setup, and one of the options is bind. Scroll to the bind box, but don't press it yet. put a bind plug in the receiver, and power it up. Make sure that it has no propellers attached if in an airframe. The receiver should be flashing rapidly. If so walk away, minimum 2 meters, better 4 plus. Press the bind box. It will then bind or fail.if it fails try again, with the transmitter in a different place. Power down receiver. Remove bind before you power it up again or it will go into bind mode again. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted September 20, 2019 Share Posted September 20, 2019 Hope that works for him Don. Quote Link to comment Share on other sites More sharing options...
