Chris McG F-86 Sabre Dog build blog
Thank you both, Phil and Dwain.
In fact, I’m planning two of those but the exact position of the second one is ‘secret’ for the time being and will be revealed in due time… angel
Still no glue delivered, but it isn’t a drama as I have plenty of others things to handle.
I got the wing jig back on the building board, had a lot of planks prepared for the aft fuse and started working on the fuse wing plate… yes
Cheers and keep safe, gents
Chris
Hello to all,
Just a small bite, but a bite anyhow.
The wing bolt plate got its blind nuts and part of it removed to give room for the aileron torque rods.
I’m afraid I just copied Phil’s cut out as far as I could interpret his pics. blush
… youppieyeah… I received my parcel from SLEC today. Entirely not their fault as the postman explained our Bpost is totally overwhelmed with parcels and deliveries from online orders as a result of our confinement. The same with DPD, UPS, DHL and other parcels services. And of course, we had that official holiday last Monday.
No probs, more than ever now, patience is a virtue… angel
Now I’m also the proud owner of those SLEC aileron torque rods… Let’s hope that Phil can stand my daft questions about them in the (near?) future…
Hakuna matata & stay clear all
Chris
BRU - BE / CTR Torque Rods Control
Hi Mark,
Thank you for your very motivating comments.
Just a short session at La Grotte but with the recent glue arrival, I needed to have some planking done. angel
Not that much really, but it seems to be the same as a bike ride, it came back very fast. cool
I also digged up an old ‘test wing section’ that I made some years ago during my Ballerina build.
I will use it now as an additional TM Plan for further testing of Fred’s Sauce in combination with my planned final paint job…
Cheers and stay clear all
Chris
Hello again,
The second session of planking got achieved as well and is still drying.
Now, after the last ‘full length’ planks, the shorter planking up to the wing TE is progressing quite faster.
The bottom of the fuse is amazingly 'flatter' than I thought. But no sheeting here as I prepared way too many planks anyway... blush
I guess I will have to start that Sauce & Paint testing sooner than I thought. wink
Still alternating the jobs, the port wing ribs are almost all prepared for gluing up soon. yes
Hakuna matata & stay clear all, please
Chris
BRU - BE / CTR TM Control
Hi to all,
I had a start with the Sauce test piece so I can add a third item to the TM plan.
I wrote before that I will use a wing section that I made when building Peter’s Ballerina, using the bottom of the airfoil this time.
It’s 3mm Depron test piece glassed with 18g fiber using water based hard varnish. LE and TE are short strips of balsa.
I gave Fred’s Sauce a few drops of Carmin acrylic but forgot about the fact that Carmin is very translucent. After a light sanding, I gave it another coat with Umber mixed in which will give a better contrast.
When preparing some Sauce, it’s better to foresee a small container with a lid allowing to use it without problem during several days.
As the pic shows, there are a lot of brush strokes probably due to the cheap nylon brush. blush
Never had that before so back to the good quality artist brush that I used earlier.
Hakuna matata & stay safe all
Chris
BRU - BE / CTR NACA 3414 Control
Hello again,
Unfortunately, the ‘sky was crying’ all day here in BE.
Close to impossible to work outside to sand the test piece… frown
A little planking will do instead, I guess.
Getting there slowly… cool
Chris
BRU - BE / CTR Rain Control
Thank you, John.
You know, this is really the easy part of the planking especially compared to the tail end. yes
I really like it more and more. In fact, I've even been making some sketches for a small - +/- 400mm - 'Chris Craft' or 'Runabout' type motorboat...
Iris is doing well, thanks. As our confinement has been a bit 'relaxed' since the beginning of the week, she's partly back to the office & homeworking half time.
Gaston has a bit of problems with his sanity mask as the rubber bands interfere somehow with the size of his 'auditive sails'... devil
Cheers
Chris
Hi out there,
I made a start on gluing the first ribs of the port wing using a ‘dummy’ top spar to check the alignment.
My trusty Duplos and my sandbags are still ‘part of the deal’ here. cool
I do realize it all looks a bit ‘amateur’ but it just works for me… besides the fact that I don’t have any Campbell soup tins at hand…
Sarcastic smiles at the back of the classroom are fully allowed though… wink
While the Aliphatic was drying, I took the opportunity of a dry weather outside to attack the wing test-piece. (to be continued) ...
(continued)
A few words of explanation for those interested. The white ‘lane’ at the bottom is just the glassed Depron as it was before the Sauce test.
The pink lane is the sanded Carmin first coat while the rest is the later mixed coat offering a better contrast.
The sanding of the mixture is fast and easy, but the thin Depron and glassing are a bit too soft. They tend to ‘sag’ showing the spars and ribs too easily. blush
No probs, as this will not be the case with the Dog’s wooden sheeting and the thicker glass cloth.
Hakuna matata & stay safe, please
Chris
BRU - BE / CTR Sagging Control
Hello again,
Clouded sky here in BE, but at least dry and no wind.
Perfect for a partial coat of yellow to the test piece.
As you can notice, I decided to try without a primer coat, but the yellow has some difficulties to cover the brownish underground. 'Nice try', but I will use a thin primer coat for the Dog.
As Jean Gabin, a French movie comedian, said at the end of his life: “Now I know, I know that we never know”… cool
While that was drying, I went on with the fuse planking… and got it completed…
As from today, the last fuse plank is a fact. smiley
Chris
BRU - BE / CTR Primer Control
Thank you both, John & Phil. yes
As I mentioned in my OP, the planking experience was one of the main reasons to start the Sabre build.
Now with that part done, I can't really 'stop' the build now, can I?
By the way, I never used to totally sheet a wing either. Let that be a valid reason to persevere then... cool
Speaking of sheeting, I have a question, please... angel
I duly noted Phil's method of sheeting with the pins to the main spar, the weighted down TE and the 'baton/pinned' LE.
But do all the concerned parts (ribs, TE, LE, hinge blocks, etc.) get some glue at once?
In fact, using Deluxe Aliphatic mainly, I'm somehow afraid that the glue will start to go off before having the time to getting the sheeting properly in place.
I noticed my PVA (Belgian brand Soudal) is 'slower' to start drying. Should I preferably use PVA then?
Thank you in advance for the mountains of perfectly structured advices. wink
Cheers
Chris
Hi,Chris !
As you can see in my blog -begin ,i glue the sheets together before glueing them on the ribs. This way i can sand the skins in advance.
If you sand the skin after offering it to the wing ,then you sand more on top of the ribs and less between the ribs.(you push the sheeting down) Result :a golf terain !
There's only 2 glues in my shop :epoxy and zap ,red and green.
Cheers friend !
Hija Dirk,
... and thanks for your reply.
Yep, I saw your method of 'joining' sheets on different blogs. yes
That's exactly what I did including the sanding while they were flat on the board.
The sheeting is also cut with the correct angle at the root and an small overhang (about 15mm) at the LE, TE and wingtip. So far, so good, I guess... angel
My main question was regarding the glue to use to have enough time to pin/weight it down. In my case, Aliphatic or PVA?
I don't have CA - which I suppose the Zap products are.- as I never used it before.
Anyhow, a big thanks for your answer. cool
I can only hope to get some clues about which glue to use.
Cheers & stay safe, mate
Chris
Hi Chris,
Either of those two will do the job and as long as it isn’t really hot while you are doing it, will give you time to get it in the right place and pinned down.
If it was me, I’d be using Aliphatic. (The normal stuff, not the superphatic)
Cheers
Mark
Hi Mark,
Thank you so much for answering my query.
After I got your reply, I did spend some time doing some testing with both of the glues. cool
At ambient temperature - 21 > 23°C - in La Grotte, both glues are starting to 'take off' between 4 & 6 minutes.
I then made a 'bain-marie' with water out of the fridge at 7°C and had the glues cooling off in it for some time.
The result for both was then a working time of 8 to 9 minutes. A lot better as it is then controllable/repeatable for this use.
I'll stick to your advice and use the Aliphatic. yes
Thanks again & stay safe, Mark
Cheers
Chris
Sorry Chris, been away from my PC most of the weekend.
Regarding your question - But do all the concerned parts (ribs, TE, LE, hinge blocks, etc.) get some glue at once? - Yep - all the top surfaces of all these components got a good coating of (in my case) white PVA before the top skins were weighted and pinned and battoned down.
Apols for slow reply.
