Tim Cheal Posted October 17, 2020 Share Posted October 17, 2020 Hi Guys I'm after a bit of help if I can. I recently broke a servo arm on my Futaba S9154 servo. The problem I am having is finding a replacement servo arm. The diameter of the attachment (sprocket?) is larger than the regular Futaba servo horns (it's about 6mm diameter) but I cant find any spec that includes this. Does anyone know how I can ensure I order the correct servo arm? Thanks in anticipation Tim Quote Link to comment Share on other sites More sharing options...
kc Posted October 17, 2020 Share Posted October 17, 2020 Whilst looking for something else I came across this - I have no idea whether it's what you need but it's worth a look. Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted October 17, 2020 Author Share Posted October 17, 2020 Thanks kc I called pro-build but they didn't suggest this one, so I'm again not sure of the sprocket/spigot (whatever it is) size? Thanks for answering though. Tim Quote Link to comment Share on other sites More sharing options...
dave parnham Posted October 18, 2020 Share Posted October 18, 2020 normal Futaba servo splines are 25T although that servo is only plastic geared digital servo at 4.5kilo/torque so i would personally swap it or the pair if aileron servos for something a bit better spec. Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted October 18, 2020 Author Share Posted October 18, 2020 Thanks Dave That is an option, but the model has 2, they are bigger than the normal servo housing and if I can I would like to try to replace the arm. It's also a £60 servo that I would rather not bin! Tim Quote Link to comment Share on other sites More sharing options...
John Lee Posted October 18, 2020 Share Posted October 18, 2020 Specs here - it may be worth dropping them an email "Notes: No other arms will work on this servo, because of the unique spline size. Stock/Manufacturer #FUTM0214 '' Quote Link to comment Share on other sites More sharing options...
John Lee Posted October 18, 2020 Share Posted October 18, 2020 It may also be worthwhile posting on the GBRCAA Forum, their Members are the most likely to have spares lying in a draw. Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted October 18, 2020 Author Share Posted October 18, 2020 Thanks John. That's a good idea and I will do that. Tim. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted October 18, 2020 Share Posted October 18, 2020 Quite a few GB suppliers on Internet for your servo maybe worth a few calls to see it they have odd servo arm for your servo hanging around ?? Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted October 18, 2020 Share Posted October 18, 2020 Try Servo Shop / Steve Webb Quote Link to comment Share on other sites More sharing options...
