J D 8 Posted November 30, 2020 Share Posted November 30, 2020 Had a good days flying with my Major Mannock at the club site yesterday. A number of old models of mostly IC trainer types had been donated . However I brought two home. [ join the winter fix up?] The Motor glider has a plastic fuzz and flying surfaces are balsa with built up wing and sheet tail. Span 70 inches. The old power system has been removed. Boy it's heavy, at 533 gram, more than a lb. Performance with a brushless / lipo system should be good.. No idea what it is but motor is a Jamara unit. The little prop jet of F15 / MIG type may be O/D or plan and is unfinish, pretty heavy so may be more of a missile or a Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 30, 2020 Share Posted November 30, 2020 Looks like an " Easy Pigeon " one of the first commercial electric ARTF's from back in the 90's I think . Might have been a J Perkins model model Link Good view at 3min 12 sec. They were supplied with a 500 brushed can motor and used 7 cell "C" cell nicads or NiMh packs and were heavy. but flew quite well as seen in the link. The little prop jet looks like one of the Nigel Hawes free plans from the same era . Probably had a 400 brushed motor and a used the 500 Mah AR Nicads . Fit a brushless motor and lipo set up to both and have some fun. Edited By Engine Doctor on 30/11/2020 14:49:34 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted November 30, 2020 Share Posted November 30, 2020 2nd on the E.P. Had one of them, won it in a comp I think, from SWM. D.D. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted November 30, 2020 Author Share Posted November 30, 2020 Thanks for the info ED, I am did not recognised the Easy Pigeon. Only airframe fix needed is the badly damaged badly repaired section. Probably make a new one. The jet has a bell type motor which I doubt would fly it's 400 ish gram very well. However have something in the cupboard that would give it some zing. Could not find any details of F15 by Nigel Hawes but looks like his style. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 30, 2020 Share Posted November 30, 2020 Good day flying ? Lucky you - I am counting the hours until lockdown ends and I can visit the field again. GG Quote Link to comment Share on other sites More sharing options...
J D 8 Posted November 30, 2020 Author Share Posted November 30, 2020 I feel doubly lucky to get back to the flying field as having in September been diagnosed with a TIA. And only recently was able to drive again. J D Edited By J D 8 on 30/11/2020 21:58:57 Quote Link to comment Share on other sites More sharing options...
David Forbes Posted December 1, 2020 Share Posted December 1, 2020 The F15 looks like the Tony Nijhuis one from RCME June 2002 with a nose mounted motor in place of the rear motor on the plan. Wingspan 590mm. Quote Link to comment Share on other sites More sharing options...
