Steve Hargreaves - Moderator Posted April 24, 2007 Share Posted April 24, 2007 Anyone got their head around the balance leads fitted to many LiPo packs these days....???Every pack seems to be the same but is subtley different in catches or alignment pins & they don't mate...there seems to JST XHs & JST EHs plus many different interfaces to the balancers themselves.....I can't make much sense of it at all.I've just ordered some connectors & leads from BRC Hobbies that I THINK are correct but I'm very confused. Describinmg it over the phone isn't easy either...."...its a white 5 pin plug with some catches...." "Yeah, they all are...which one have you got" seems to sum it up.....Anyone got a Numpties Guide I could follow??? Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted April 24, 2007 Share Posted April 24, 2007 Yeah, very irritating subject this, it seems simple to me, it's a customer loyalty thing, the balancer leads ONLY fit balancers/batteries of the same type....so if you have Flightpowe batteries, you have to buy a flightpower balancer, if you buy a different make of battery....it won't balance it.....rubbish or what? Quote Link to comment Share on other sites More sharing options...
brian storey Posted July 12, 2007 Share Posted July 12, 2007 hi steve I had the same problem I got a JP EnErg balancer from BRC Hobbies then found the balancer lead does not fit Extreme 15 Batteries.So I contacted BRC and they seem as confused as the rest of us,but they sent me a new lead,needless to say it was the wrong one. I have now spent several hours and days trying to phone them on there new tele number But its like the Mary Celeste there aint no one there.brian Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 12, 2007 Share Posted July 12, 2007 I think they're moving premises. It's not like them to get it wrong though. Check out the article on this very subject in the current issue.David. Quote Link to comment Share on other sites More sharing options...
brian storey Posted July 12, 2007 Share Posted July 12, 2007 Thanks for the info Dave I have seen the article in this months RCME and it goes a good way to make the problem clearer.Thats why I was trying to contact BRC to order the correct lead.Brian. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 14, 2007 Author Share Posted July 14, 2007 The guys at BRC are very good so bear with them Brian.....as Dave sez they are moving premises so be patient....Another option is to try Robotbirds....they seem pretty switched on to this issue too.I just wish the manufacturers could get themselves organised & decide on a standard plug!!!!! Quote Link to comment Share on other sites More sharing options...
Alan B Posted July 14, 2007 Share Posted July 14, 2007 Hi GuysRef Scotts comment about different makes of balancer and BatteriesThere is a way around this I have a Flight power V-Balancer and for example I have purchased a 3 cell Electrolite Maxilife lipo with a 4 pin socket - will it fit the flight power adapters - of course not! However it plugs directly into the first 4 pins of the main socket of the balancer pefectly - No need for a adapter leadAs long as the pin spacing is the same and you keep black balancing lead on the battery to the black lead on the balancer ie pin 1 it will work perfectlyThat is just one example - I have done this with other makes too Some types may need the lugs trimmingAt the end of the day it is only an adapterI cant comment on other makes of Balancer but I presume the principle will be the sameRegards Alan Quote Link to comment Share on other sites More sharing options...
Nick Burroughs Posted July 24, 2007 Share Posted July 24, 2007 I read the article in RCM&E. It just goes into more detail about what I already knew. Different batteries, different connexions. What we need are conversion leads or information. It is fairly easy to see what the battery leads are but not the balancer/charger pin outs Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 24, 2007 Share Posted July 24, 2007 Alan....I did just that....and V balancer went up in a puff of smoke! And that was on an "old" balancer lead on a flightpower battery.....then some simply don't fit at all. My V-Blancer doesn't even want..it seems....to handle a 4s flight pack from the same company! Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 25, 2007 Share Posted July 25, 2007 Were the connectors compatible Scott? David. Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 25, 2007 Share Posted July 25, 2007 Yes, hence I'm not convinced it's that simple.....I have to say...I'm not even that convinced by balancing. Iv'e found [looking at the balance LED's, mine are never improved by the balancer....and only use it periodically now to check.....havn't had one yet that's miles out] that slow charging and only flying to 80% of pack capacity keeps them in good shape. Now I'm not saying don't balance....but I think the best Lipo care system is gently, gently. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 25, 2007 Share Posted July 25, 2007 Yes Scott, I tend to agree with you.I balance most of mine only occasionaly, and even though the odd cell appears slightly out, and the balancer does its stuff, next time, they may well be the same again anyway. I guess we are taking a certain preventative action here though, as by allowing the imbalance to develop to a more serious level, is when problems could occur. I admit to not bothering at all with one or two small 2s packs, which only ever get used for very low current drain, and then are topped up as needed. Quote Link to comment Share on other sites More sharing options...
Alan B Posted July 25, 2007 Share Posted July 25, 2007 Hi ScottIm sorry to hear that you have had some problems. There must be something wrong somewhere! There should not be a problem I have taken several photos of the connections with 3 different makes of battery if you wish you can email me and I will by return gladly email the photos to youRegads Alan Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 26, 2007 Author Share Posted July 26, 2007 Scott, I too agree with you & Timbo about the balance issue....if you consistantly run 'em down to the wire then thats when problems seem to occur....run them sensibly & everything seems OK....I have a Hyperion balancer & I tend to find that when I use it to charge up my pack I get less duration....it also has a strange habit of showing no lights (light on indicating which cell its trying to balance) & then lighting all three LEDs at once!!! Wots all that about then.....!!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 26, 2007 Share Posted July 26, 2007 Well not sure if it is the same as my F/Power balancer, but twhen all my " 3 lights flash together " it simply means that all 3 cells are now harmonised..... Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 26, 2007 Author Share Posted July 26, 2007 I shall have to read the instructions I suppose but from memory it flashes a LED to show a particular cell is being discharged at low rate, solid (ie no flashes) means discharge at a high(er) rate & theres a LED for each cell so I get cell 1 flashing, cell 2 solid. cell 3 nothing & then various combinations including all three LEDs lit!!! I suppose it might mean all three cells have sneaked above 4.2volts but the charge display will probably show 11.984V or something......Its not a problem it just seems a bit odd!!!! Quote Link to comment Share on other sites More sharing options...
Brian Ingrey Posted July 27, 2007 Share Posted July 27, 2007 Good article by Dave Ashby on balancers and li-po charging.Bought the Tornado one by Overlander which,as Dave says,comes supplied with a very complete pack of leads all for under £20.I have decided to stick with their Poly Pro series as they are my most expensive packs!I can just squeeze a 2500Ah 3s into my Micro Show Flyer and after several flights now the three Led's' before and after charging, glow without a flicker thus saving another trip to the Bank of England!I would recommend the Tornado to anyone as it is simple to operate with all charging leads supplied.As a Footnote I have several Kokam Li-po's which do not come with a balance plug. Has anybody had any problems with Kokam's that have had a fair bit of use? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 27, 2007 Share Posted July 27, 2007 My oldest packs are Kokam 2000s 3S at 15C - approx 4 years I guess.They are well used at about 42A ( paralled ) right up until about 3 months ago, maybe 70+ cycles or so/...and although they expectedly do not perform as well as they used to, they still get up to 12.4V and take around 1600 m/a after a full run. No balancer on these of course, way before all this namby pamby balancing malarky :)I am not currently using Kokams, as others of equal / better quality are available at lower cost, but back then they were the mutts nuts. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 28, 2007 Share Posted July 28, 2007 I see Overlander are promoting a new range of Kokams again.. my old ones without a balance plug are still jogging along, not the punchiest of packs but, like you Tim, definately my oldest. David. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 28, 2007 Share Posted July 28, 2007 What d'ya you mean I am your oldest?....your oldest what David, forum member perhaps?? LOL Quote Link to comment Share on other sites More sharing options...
Graham Reid Posted July 28, 2007 Share Posted July 28, 2007 I just read David Ashby review in August RCM&E but surprised no mention of Thunder Power. I recently bought a Thunder Power balancer but I think it only fits their Lipos. I have thought of changing the balance connectors on non TP lipos to Thunder Power, but concerned about getting it wrong. Are adaptor leads available for Thunder Power to other connectors? Graham Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 29, 2007 Share Posted July 29, 2007 The Thunder Power connector is the same as FlightPower Graham. Try ringing West London Models, they ditribute the brand and should be able to help. David. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 29, 2007 Share Posted July 29, 2007 Tim...LOL ;-) Quote Link to comment Share on other sites More sharing options...
Graham Reid Posted July 30, 2007 Share Posted July 30, 2007 Thanks David. WLM supplied Thunder Power connector leads to replace the various other connectors on my Lipos. Job done, but what a pain. Wires arent even colour coded the same way. Graham Quote Link to comment Share on other sites More sharing options...
Tom Goodacre Posted October 22, 2007 Share Posted October 22, 2007 Hi Guys, The problem carries through to the Li-po protector units which are installed between the Li-po and the receiver. I recently purchased a couple of these units from 'Galaxy' and found that the pin configuration is not compatable with any of my Li-po's.Has anybody else come across this problem? Found any solution? I agree that it is about time the manufacturers put their heads together and standardised on the plug issue for everybodys interest. Quote Link to comment Share on other sites More sharing options...
