Dwain Dibley. Posted February 13, 2021 Author Share Posted February 13, 2021 I have started on the wing now, and have just about sorted all the pieces out, so I know what they are and where they go. Just got to check the instructions to see the order they go in, as this is not apparent from the plan. D.D. The main spar ply piece under straightening training. Some parts figured out. The fuselage after primary sanding, still loads to do here, but I need covering first. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 13, 2021 Share Posted February 13, 2021 Coming on well DD, nice sheeting work. Pretty looking model. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 13, 2021 Author Share Posted February 13, 2021 (edited) Thanks John, reminds me of a boats hull. The three piece centre brace is all glued up and drying as we speak. D.D. Edited February 13, 2021 by Dwain Dibley. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 14, 2021 Author Share Posted February 14, 2021 I have now added the Spruce reinforcement to the main Spar and constructed the undercarriage bearers from ply. These are normally chunky hardwood blocks. I have also missed out a balsa former, I will attempt to retro fit it somehow, as it does add support to the Rx mount. Waiting for glue to dry is almost as boring as watching paint dry. D.D. The component parts. Dry fit test. The main spar with spruce added. Close up. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 14, 2021 Author Share Posted February 14, 2021 (edited) The centre section under construction, and under pressure. D.D. The odd bits of balsa are just spacers. Edited February 14, 2021 by Dwain Dibley. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 14, 2021 Share Posted February 14, 2021 Glad to see you're back to your ME, Dwain. ? Keep safe Cheers Chris Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 14, 2021 Author Share Posted February 14, 2021 Thanks Chris. The wing is certainly something different in the way it's constructed, to me anyway.. ? D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 20, 2021 Author Share Posted February 20, 2021 (edited) I made a start on the wings today to find that one of the trailing edge spars, where the aileron hinges is mis-cut. So first a repair was needed. A bit naughty on a new kit but easily fixed with a strip of timber and my trusty plane. D.D. The mis-cut part. Cut from a bit of scrap. Under pressure. Planed. New slots. Preparing the bottom centre sheeting Edited February 20, 2021 by Dwain Dibley. 2 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 20, 2021 Author Share Posted February 20, 2021 (edited) OK. Might have got a bit further, except for a call out at work. Hey Ho. All the bottom sheeting and trailing edge is laid out, and glued in, the rib cappings too. I don't normally do it this way but that's the instructions. I had to plane a little off the centre section main spar to make it flat to receive the bottom sheeting. This needs to go on before I proceed with the wing. I changed all the tubes in my workshop to daylight tubes this afternoon, it's a big improvement. D.D. The Aileron. The centre section and main spar assembly. My new lamps. Like being outdoors. Edited February 20, 2021 by Dwain Dibley. 1 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 20, 2021 Share Posted February 20, 2021 Raptor 50 ? I had I.C version. ? Nice build by the way. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 20, 2021 Author Share Posted February 20, 2021 Thanks John, Can you believe I paid £400 for 2 six cell batteries back in the day. I still have them and they still produce a good 7 minutes flight apiece. Had a Trex 600 nitro, enjoyed that but sold it on, got all the leckies down to the 250. D.D. 1 Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 20, 2021 Share Posted February 20, 2021 Still following, Dwain. ? I must still have an Atom Compass 500 somewhere in the attic. To be honest I never really had a passion for helis but I inherited it in an early combo deal... Must find it back and sell it as a good reputation 'vintage' heli. Cheers & stay safe, young man Chris Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 20, 2021 Author Share Posted February 20, 2021 Hi Chris, Glad you are still there. ? Helicopters used to be so popular, just like Drones are now, it will all come full circle. Take Care. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 20, 2021 Author Share Posted February 20, 2021 Bottom sheeting now glued to the centre section and under a bit of pressure from the usual batteries. Just needs trimming in the morning and then the ribbing can begin. Night night Lads. D.D. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 21, 2021 Author Share Posted February 21, 2021 Bottom sheeting all trimmed around the centre section and ready to go. I found the only way to go was to put the ribs in to see what lined up with what, as you cannot see the plan with the bottom sheeting on. However, if you squint closely there are very tiny lines to follow, when adding the outer ribs. It all went well, and I now have half a wing and one aileron finished, bar the top sheeting. A 3 mm shim is required for washout under the tip before sheeting. Also the servo has to be fitted, this will be unreachable without surgery later, so I am making the usual servo hatches. D.D. The bits. Cap strips cut from scrap. Main root ribs joined. Ribs in. I cut the Aileron free at this point. Servo in position. Hatches to make. When you have fitted a new blade, don't drop your knife and try to catch it. LOL Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 21, 2021 Author Share Posted February 21, 2021 I have made one of the servo holders and hatches, one in the same really, and made the frame for it to sit in. All I have to do now is add the little triangle pieces to take the screws. The C.A. I am using seems to react with my usual plastic sheeting, weird. You can see it stuck to the airframe. Ah well, more sanding. LOL D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 21, 2021 Author Share Posted February 21, 2021 Finished the servo hatch. D.D. Little triangles. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 23, 2021 Author Share Posted February 23, 2021 I ordered some Natural Oratex on Sunday night, 3 metres of it, it arrived this morning . Good Old Steve Webbs Models. Also, added a bit of reinforcing to the servo cover braces. D.D. Mmmmm. Smoooooth. Solid. I need to make a bearer for the Horn, in the aileron. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 27, 2021 Author Share Posted February 27, 2021 (edited) This morning I plucked up the courage to add the top sheeting to the wing, I taped the servo in place just in case. I also added the extension lead and the lead lock. I forgot to transcribe the shape onto the third piece to make life easier on the second wing. ? Anyway the application went as smoothly as it could, I added the 3mm of washout. The process was made slightly more awkward with the two spars sticking out the port side. I also dampened the sheet from the aileron out, where it was thinner. D.D. Don't forget to leave a bit of slack for access. 3 mm, plus I mustn't forget the capping strip on the last rib. Bits of scrap to stop things flapping about. Edited February 27, 2021 by Dwain Dibley. 3 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 27, 2021 Author Share Posted February 27, 2021 Top Capping strips, false leading edge, leading edge and Tip sanded to a nice profile. Trailing edge all squared up with the aileron in place. D.D. Capping. 1.5 mm False leading edge glued using aliphatic. Aileron. And finally the leading edge glued on using Aliphatic. 3 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 27, 2021 Author Share Posted February 27, 2021 (edited) Made the slot for the horn in the Aileron, and planed up the leading edge. The horn is not glued in until after covering. Planing one at a time makes it easier to handle. Next I will cover some things, this will keep them safe. D.D. Edited February 27, 2021 by Dwain Dibley. 1 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 27, 2021 Share Posted February 27, 2021 Been planing have you. ? You're working well DD, very neat, how much better are the photos now. ? Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 27, 2021 Author Share Posted February 27, 2021 1 minute ago, john stones 1 Moderator said: Been planing have you. ? You're working well DD, very neat, how much better are the photos now. ? Thanks John. ? I think this new forum might just catch on Matey, pics are great. D.D. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted February 28, 2021 Author Share Posted February 28, 2021 (edited) I have two wings, or depending on your point of view, one big one. D.D. Marking out AGAIN. More of the same. The Skeletal framework. The sun was shining, can you get your hat on ?? Edited February 28, 2021 by Dwain Dibley. 3 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 6, 2021 Author Share Posted March 6, 2021 A nice relaxing day today, went to a local garden centre and bought some things, took mothers day pressy to Mother as it's her Birthday next Tuesday, she is 85. ? Then a couple of hours in the workshop making the last skin and servo hatch. Final capping was added also. Tomorrow will be the leading edges, false and real, and perhaps the centre top sheeting. D.D. 2 Quote Link to comment Share on other sites More sharing options...
