Martian Posted June 29, 2019 Author Share Posted June 29, 2019 Posted by Graham Donaldson on 29/06/2019 14:23:09: Yes, a Brian Taylor Mossie. Its been under construction for over four years. Every time I get to a difficult bit I take a break. This time its the hinging of the u/c doors, but I will get thee sometime! Yes I couldn't get the hinges right on the TH mossie still haven't at least not the way I want Quote Link to comment Share on other sites More sharing options...
Martian Posted June 29, 2019 Author Share Posted June 29, 2019 Thank you Danny but remind me not to let you look to closely 😏 BT missus sounds good but my mind is set on a Tigercat Quote Link to comment Share on other sites More sharing options...
Martian Posted June 29, 2019 Author Share Posted June 29, 2019 Posted by Martian on 29/06/2019 15:24:55: Thank you Danny but remind me not to let you look to closely 😏 BT Mossie sounds good but my mind is set on a Tigercat Quote Link to comment Share on other sites More sharing options...
Martian Posted July 15, 2019 Author Share Posted July 15, 2019 Hi all pictures of progress right up to date finished I dont think so they are never really finished . I still have the final bit of painting then livery and somehow I have to find room with it fully assembled so I can do the rigging yay what fun . anyway pictures Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted July 15, 2019 Share Posted July 15, 2019 ... wow, super job, Martian. Following closely to see it progress with the rigging & finishing... Cheers Chris Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted July 15, 2019 Share Posted July 15, 2019 It looks amazing. Whatever the minor niggles about scale accuracy on the plan, there’s no mistaking what that is! Quote Link to comment Share on other sites More sharing options...
Martian Posted July 15, 2019 Author Share Posted July 15, 2019 Really thank you Chris and Colin there are a lot of firsts on this for me so it,s not perfect I will just tell my self its been restored badly Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted July 15, 2019 Share Posted July 15, 2019 Looks perfect to me. When you see my shabby effort I am sure you will think so too! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted July 15, 2019 Share Posted July 15, 2019 Looks fabulous well done Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted August 10, 2019 Author Share Posted August 10, 2019 Hi fellow modelers and flyers originally at the start of this build it was my intention to build k3731 but as one does I changed my mind and changed it to K5682 ( which has Cambridge Blue markings ) Cambridge Blue is so varied in hue I settled for the nearest I could well there was no way I could achieve true scale. I made my own transfers and logo. This plane K5682 was assigned to RAF Cranwell as a trainer aircraft and during it,s time there it was damaged beyond repair and scrapped it has not been easy tracking down info but I am doing my best. I have never done any rigging before but have nearly completed the tail end just need some more ali tubing. I destroyed a leather bum bag for the fine leather using it for the cockpit combing and cable patches. I have also deviated from the dummy 22swg wire for the elevator cables and have used plastic coated wire which has shearing elastic attaching the wire to the rear of the cockpit this is having the effect of keeping the wire under tension and also acts as a damper , the plan called for 22swg wire to slide into ali tubing buried in the tailplane. I have used the brass parts intended for the windscreen to make litho frames and made a 3 part glass shield from thick Perspex it looks ok I think that's about it next is the wing rigging goodness knows how long that will take. anyway some pics below poor pic but it is the handholds out of leather since found out they used some form of cord which I will add Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted August 10, 2019 Share Posted August 10, 2019 It looks amazing. Definitely going to be a real eye-catcher when finished. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 10, 2019 Share Posted August 10, 2019 Looks terrific, well done Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted August 11, 2019 Author Share Posted August 11, 2019 Thank you Colin and thank you Danny much appreciated Quote Link to comment Share on other sites More sharing options...
Martin Fane Posted August 11, 2019 Share Posted August 11, 2019 Martin Lovely model, very inspirational Cheers Martin Quote Link to comment Share on other sites More sharing options...
Martian Posted August 11, 2019 Author Share Posted August 11, 2019 Thank you Martin ,having looked all through your build images your work is excellent you don't need inspiration from me looking forward to your next update 😎 Quote Link to comment Share on other sites More sharing options...
Martian Posted August 27, 2019 Author Share Posted August 27, 2019 So far the only part I have not covered in Aluminum is the cowl so I,m biting the bullet and making an attempt to do just that I mean what's the worst that can happen strip it off and start again. the hardest part is going to be the bumps on the top , tried cooking foil but that creases and is hard to planish out.made one from .06mm ali and that,s not to bad will try some even thinner ali see how that goes. I have made a couple of formers and hardened the surface , lets see how it goes will post pics of progress .. PRACTISE MAKES PERFECT Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 28, 2019 Share Posted August 28, 2019 I have shown several times how to do blisters in litho plate, much easier than you think. You need to cut a teardrop shape, slightly larger than you need. Aneal the litho and rub it into the form with the rounded end of a dowel. They look great when done These pics are from my Nijhuis Spitfire build, and are the wing blisters, not as deep dished as the Fury cowl, but you get the idea? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted August 28, 2019 Author Share Posted August 28, 2019 Thanks Danny I'm on the right track then just keep at it until I'm happy ☺ Quote Link to comment Share on other sites More sharing options...
Martian Posted September 7, 2019 Author Share Posted September 7, 2019 This metalwork is not easy with arthritic hed doing it but it does take some effort and would loved to have done better but a while back when I changed over to the Cranwell Training aircraft I figured it would look better if it appeared to have a lot of use and somehow I think that is what I have anyway some pics up to date just the wing rigging to do Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 7, 2019 Share Posted September 7, 2019 Looks great, loads of work, well done for tackling it.... serious respect Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted September 7, 2019 Author Share Posted September 7, 2019 Thank you very much Danny I'm glad I have it a go Quote Link to comment Share on other sites More sharing options...
