Engine Doctor Posted January 16, 2019 Share Posted January 16, 2019 I don't know how or if the plastic you have used is affected by the paint thinners. The reason I say that is that some years ago I painted some Flair Vintage wheels with Solarlac silver. All was fine and model was mothballed over winter. Next spring the model was brought out and readied for a flying session . On the take off run one wheel shattered like an egg shell. The paint had de- natured the plastic causing the brittling effect . Your wheels look really good and wouldn't want all that work ruined. The replacement wheels I fitted were painted with Humrol and the less aggressive thinners didn't damage the wheels for years after. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 16, 2019 Author Share Posted January 16, 2019 Thank you sir. it is all experimental anyway, so time will tell is the thinners in in primer filler will effect the plastic. i used humbrol for the colour. i have the files and can always print more if needs be. the benefits of owning a 3D printer. Tony B Quote Link to comment Share on other sites More sharing options...
Martian Posted January 16, 2019 Share Posted January 16, 2019 PLA is an organic filament up to now no compound seems to break it down ,being organic it is biodegradable depending on conditions but as Tony says you can always print new ones Quote Link to comment Share on other sites More sharing options...
Martian Posted January 16, 2019 Share Posted January 16, 2019 Apparently methylene chloride is used to smooth PLA and to bond it it is a solvent again an organic compound it comes with a heap of dire warnings as it is highly toxic . If you are going to use it make yourself aware of the dangers Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 16, 2019 Author Share Posted January 16, 2019 well i did not like th big hole in the radiator cowl, so i printed this. fills the space a bit now. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 16, 2019 Share Posted January 16, 2019 You have certainly mastered the art of 3D printing Tony. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 17, 2019 Author Share Posted January 17, 2019 waiting for tyre material. so i am wrapping the trailing arm covers with folded tissue before i paint them. cabane bending next week, then hopefully covering in feb. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 19, 2019 Author Share Posted January 19, 2019 well i decided that my wheels were too big, so i am making some more. I have a future design i can use the large ones on though. Sanded the lower wing to shape and hope to fit all the brass parts tomorrow, then i can start covering it. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 19, 2019 Share Posted January 19, 2019 Tony, where did you get the tyres from, may I ask? Quote Link to comment Share on other sites More sharing options...
Martian Posted January 20, 2019 Share Posted January 20, 2019 What size are the wheels Tony ? Measuring on the plan they should be 4/5_8ths Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 20, 2019 Author Share Posted January 20, 2019 It's 12mm Neoprene cord Sir. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 20, 2019 Author Share Posted January 20, 2019 The new smaller wheels are finished. Just sorting out the wing to fuselage fit with some filler, the cling film is there so i can seperate the wing once it has all dried. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 20, 2019 Share Posted January 20, 2019 It looks great. I asked about the tyres because I wondered how you can get a neat and secure join if you glue the ends together. I am working on the 4 5/8”/115 mm wheel diameter and the DuBro vintage wheels I have are that size. Interestingly the 1/72 plastic model I have shows them slightly larger, scaling up translates to 120mm. All of the illustrations I can find seem to show the same diameter wheel with the cantilever undercarriage as with the standard, so I will stick with that. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 20, 2019 Author Share Posted January 20, 2019 As i will need a pilot to go in my Fury, i have been learning how to design and sculpt better facial features. this is a low resolution print of my progress so far with the design. doing the hair will be fun and then i need to look at the body and clothing. It's all good fun, if sometimes frustrating at times, at least i will only have to do it once, as i will be able to print off as many as i want from the one design. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 21, 2019 Author Share Posted January 21, 2019 i cant decide on wheel size. the plan says one thing, but you look at the pictures of the full size and the wheels look smaller. i will just pick a size and make do. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 25, 2019 Author Share Posted January 25, 2019 well i have not done much to the Fury of late, been too busy with work. i have started covering the lower wing with tissue and will be adding silk to that later. my pilot figure is coming on slowly. this is the Mk2 head. It was printed at 0.2mm layer height as i needed a quick print to see how it would turn out, the final version will be printed at 0.1mm to get a smoother finish. we plod on. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 25, 2019 Share Posted January 25, 2019 Have you printed the Vickers guns Tony? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 25, 2019 Author Share Posted January 25, 2019 i have yes. Tony B Quote Link to comment Share on other sites More sharing options...
Martian Posted January 25, 2019 Share Posted January 25, 2019 That's looks brilliant Tony Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 25, 2019 Share Posted January 25, 2019 Looking great Tony and I love the gun and pilot. Where did you get your silk from?Martyn Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 26, 2019 Author Share Posted January 26, 2019 i found a place on ebay that sells silk. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 26, 2019 Share Posted January 26, 2019 Also have a look at Free Flight Supplies. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 3, 2019 Author Share Posted February 3, 2019 My pilot is starting to come together. positionable arms, legs and head. though i am dreading the clothing. Tony B Quote Link to comment Share on other sites More sharing options...
Martian Posted February 3, 2019 Share Posted February 3, 2019 Excellent pilot Tony decent set of pecs to Edited By Martian on 03/02/2019 18:35:33 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 9, 2019 Author Share Posted February 9, 2019 still plodding along in the back ground. pilot is coming along. just done the bit i hate about biplanes. the cabanes. bent. solderd and a test fit. i need to bend all the "P" clips up next. flying officer Cuthbert Caruthers having a sit in the jolly old office. Tony B Quote Link to comment Share on other sites More sharing options...
