martin collins 1 Posted June 30, 2021 Share Posted June 30, 2021 (edited) I bought an aircraft at the weekend that has not flown in a while, it uses 4 speed 400 motors and has the esc tucked away within the wing. It has written in the battery hatch GP 3300 X7 what would be the voltage of an equivalent lipo pack? It is years since i used those type of cells and i cant remember what the voltage is on them! Thanks for a point in the right direction..........M Edited June 30, 2021 by martin collins 1 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 30, 2021 Share Posted June 30, 2021 (edited) It's the volts Martin, 7 nimhs are 7 x 1.2 volts = 8.4 volts A fully charged lipo cell is 4.2volts So you need a brushed speed controller and 2 cell lipo, at 8.4 volts and 3000 mah range lipos are very popular Edited June 30, 2021 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted June 30, 2021 Author Share Posted June 30, 2021 Thanks for the quick answer, the controller is in it but unviewable as it`s built into the wing, would 8.4 volts power 4x speed 400`s enough to fly a plane? Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted June 30, 2021 Share Posted June 30, 2021 martin The question really is how well did it fly on 8.4 V 3000mAh NiMh? A 3000 mAh 2s LiPo will be about 40% lighter than the same capacity NiMh so it should fly somewhat better although you will have nothing to compare it too. Note the position of the lighter battery may need adjusting to maintain the plane's correct balance point. The really big change would come from changing those heavy speed 400s for suitable brushless motors but that would require 4 new controllers as well so it is quite a significant task. However both the performance and duration would be greatly improved. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted June 30, 2021 Share Posted June 30, 2021 What Simon says plus ... another alternative would be to get a higher capacity LiPo weighing the same as the original 7 x NiMhs, perhaps a 2s 4000 - 4500mAh. This would give longer flight times and not require the battery to be repositioned. Quote Link to comment Share on other sites More sharing options...
