Shaun Walsh Posted September 26, 2021 Share Posted September 26, 2021 An 8x6 3 blade prop on a motor with a Kv rating around 1300 would probably work OK. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted September 26, 2021 Share Posted September 26, 2021 Shaun, That is what I did with mine, I went the brushless route but then to get the cg right I ended up with two 3s 2200 lipos right in the very nose of the model. As I got the model already built it meant some careful keyhole surgery inside the nose to make enough space. As Leccyflyer says the model was designed for heavy brushed motors and nicads. Also the cg seems to need to be quite well forwards on the wing. Having said all that it does seem to be quite a nice model to fly. 1 Quote Link to comment Share on other sites More sharing options...
Nightflyer Posted September 26, 2021 Share Posted September 26, 2021 Having had other Pete Nicholson Design models Ie Balsacraft, such as Bearcat, Hurricane and FW190 with the first two built originally as Speed 600BB brushed motors 2400 nicads, that were subsequently modified to 3536 brushless power and 3s2200 lipo power. The performance difference was such the FW was built with brushless at the outset. A twin3536 motor and esc with twin 3s 2200 would be a cheap effective solution with good performance for sure. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted September 26, 2021 Share Posted September 26, 2021 (edited) My similar sized Avro Anson has two D3530-14 (1100kv) and 2x 3s1p2200mah packs, turning 9x6" 2 bladed props. Performance of the Anson is more sprightly than the Blenheim. Edited September 26, 2021 by leccyflyer Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted September 26, 2021 Share Posted September 26, 2021 49 minutes ago, Cliff Bastow said: Shaun, That is what I did with mine, I went the brushless route but then to get the cg right I ended up with two 3s 2200 lipos right in the very nose of the model. As I got the model already built it meant some careful keyhole surgery inside the nose to make enough space. As Leccyflyer says the model was designed for heavy brushed motors and nicads. Also the cg seems to need to be quite well forwards on the wing. Having said all that it does seem to be quite a nice model to fly. Thanks Cliff - as you've noted that's one of the points that some of those who have flown the Blenheim are making. The construction of the model is such that it puts some constraints on how many degrees of freedom you have with the battery packs. My other Balsacraft models are fitted with brushless motors and lipos -usually AXI2820/10 and 3s1p4200mah, but they started life with Magnetic Mayhem buggy motors, with replaced heavier duty bearings and 8 cell NiCd packs. Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 27, 2021 Author Share Posted September 27, 2021 Being a notorious cheapskate I will probably go with the two Speed 600 - old Robbe ESC option. I have half a dozen 3S LiPos ranging from 3000mAh to 4400mAh and I will change the fuselage structure to suit the battery. If that doesn't work, I'll fit brushless motors and two speed controllers. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted September 27, 2021 Share Posted September 27, 2021 That sounds like a very pragmatic solution David, if you are building the model, it might be worthwhile to put three motor wires to each nacelle to make the model relatively upgrade-proof, should you later decide on going brushless. Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 28, 2021 Author Share Posted September 28, 2021 9 hours ago, leccyflyer said: That sounds like a very pragmatic solution David, if you are building the model, it might be worthwhile to put three motor wires to each nacelle to make the model relatively upgrade-proof, should you later decide on going brushless. Good idea! Quote Link to comment Share on other sites More sharing options...
