Michael Adams 3 Posted September 5, 2022 Share Posted September 5, 2022 Could some one please help me, I have a Spektrum DX6i set up, I have fitted lights but do not know how to set up a switch to turn them on and off. Would the gear switch work ??. And how to set it into the Transmitter and receiver, also which channel to use. All help will be most appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 5, 2022 Share Posted September 5, 2022 You can assign Ch5 or Ch6 switch Michael, that are marked Flap and Gear, but surely the device in the model chooses the number. Your chosen Channel will need Activating in the menu It may be Inhibited marked INH Activated shows ACT Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 5, 2022 Share Posted September 5, 2022 Michael, I assume you have a lighting control unit on the plane. Check the servo monitor to see which channel is working when you use the gear switch, note you might have to adjust the channel travel to make your lighting controller work, which lighting controller are you using. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 5, 2022 Share Posted September 5, 2022 Michael On a DX6i the Gear and Flap switches are already assigned to channel 5 and 6 (aux) respectively. You can see this visually with the 'Monitor' function when you activate the Gear or Flap switch. You could use either channel as long as you are not using them for anything else.😉 Simply plug your light controller into your chosen channel on the receiver. By default you will see that activating the switch causes the signal to go to the mid point rather than full travel. Such a change is normally sufficient to activate most controllers but it can be altered if required. I hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted September 5, 2022 Author Share Posted September 5, 2022 Thank you all for the info, I will have a go when I can & let you know. The lighting system I am using is by G.T. Power Rc, if that is any help. Michael. Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted September 5, 2022 Author Share Posted September 5, 2022 (edited) 5 hours ago, Simon Chaddock said: Michael On a DX6i the Gear and Flap switches are already assigned to channel 5 and 6 (aux) respectively. You can see this visually with the 'Monitor' function when you activate the Gear or Flap switch. You could use either channel as long as you are not using them for anything else.😉 Simply plug your light controller into your chosen channel on the receiver. By default you will see that activating the switch causes the signal to go to the mid point rather than full travel. Such a change is normally sufficient to activate most controllers but it can be altered if required. I hope this helps. 5 hours ago, Simon Chaddock said: Michael On a DX6i the Gear and Flap switches are already assigned to channel 5 and 6 (aux) respectively. You can see this visually with the 'Monitor' function when you activate the Gear or Flap switch. You could use either channel as long as you are not using them for anything else.😉 Simply plug your light controller into your chosen channel on the receiver. By default you will see that activating the switch causes the signal to go to the mid point rather than full travel. Such a change is normally sufficient to activate most controllers but it can be altered if required. I hope this helps. Edited September 5, 2022 by Michael Adams 3 not wanted Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 5, 2022 Share Posted September 5, 2022 Michael I note that most GT Power lighting systems are for RC vehicles. Is that what you are using it for? Not my field of interest but they have features suited for that purpose, indeed it appears some require no extra channels at all and work in conjunction with the existing controls. Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted September 5, 2022 Author Share Posted September 5, 2022 Hi Simon, I did use it on Futaba in a plane but now I am on Spektrum it does not work. can you suggest a controller that would work or a complete new system. Thanks for all of your help. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted September 5, 2022 Share Posted September 5, 2022 3 hours ago, Michael Adams 3 said: Hi Simon, I did use it on Futaba in a plane but now I am on Spektrum it does not work. can you suggest a controller that would work or a complete new system. Thanks for all of your help. Flying Tech supply model lighting. Flying Tech Quote Link to comment Share on other sites More sharing options...
gangster Posted September 7, 2022 Share Posted September 7, 2022 I have never had anything to do with lighting control circuits but if the system works on a switch on the TX surely there is no difference between Futaba, Spektrum or any other radio. Try a servo in that channel and see if it responds to the switch. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 8, 2022 Share Posted September 8, 2022 21 hours ago, gangster said: I have never had anything to do with lighting control circuits but if the system works on a switch on the TX surely there is no difference between Futaba, Spektrum or any other radio. Try a servo in that channel and see if it responds to the switch. +1, I have tried different lighting systems from Hobbyking and Multiplex etc and they've all worked on my Multiplex and Spektrum gear, so I can't see why it wouldn't work. Try a servo in the channel as Gangster notes, also try adjusting the servo travel, it maybe that the default settings aren't enough to trigger the operation and you need to change the setting in the servo travel menu. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 8, 2022 Share Posted September 8, 2022 (edited) Are these the lights you have, you'll see on this video he's using a Spetrum radio and receiver so you light s should work. I also just checked my Dx6i and the travel adjust goes up to 125% (in each direction) so try that. Edited September 8, 2022 by Frank Skilbeck 1 Quote Link to comment Share on other sites More sharing options...
