Hitec Servo horns
Shaun Walsh
I have 4 Hitec HS-85MG servos in a 3D foam model which was given to me, the problem is that the servo arms are a bit too short to get sufficient control throws so performance is mild rather than wild. Can anyone tell me the part number for the right Hitec spares or point me in the right direction for longer replacements?
Thanks
Hi Shaun,
There are a number of different splined shaft sizes, depending on the servo.
This page gives the part numbers for servo arms for various HiTec servos. The HS-85 uses horns 7, 8 and 9 on the chart. Part number 56326 for the horns only, or 56327 for the horns and hardware set (screws etc.).
https://hitecrcd.com/products/servos/servo-parts-and-accessories/servo-horns-and-hardware/product
They are widely available, an arm, a cross and a disk in a pack for under £2.00. The arm is 28mm from point to point, the cross 22mm from point to point and the disk is 16mm diameter.
Typically here:
https://www.rcworld.co.uk/acatalog/Hitec-Horn-Set-HS60-HS81-HS85--56326--22956326.html
Hope that helps.
Brian.
2 minutes ago, RottenRow said:
Hi Shaun,
Typically here:
Hope that helps.
Brian.
That is just what I was looking for! Many thanks.😀
