Propwash67 Posted November 19, 2022 Share Posted November 19, 2022 I am new to this forum and know I am going to get criticize for asking stupid questions, but has anyone or does anyone know about adding the Spektrum SPMA3173 Gyro to a Draco Spektrum AR637TA receiver Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 19, 2022 Share Posted November 19, 2022 (edited) https://www.spektrumrc.com/product/gps-module/SPMA3173.html Looking at the page, Spektrum only recommends it with certain model aircraft. Speaking as a non Spektrum user, these planes must use specific receivers. You could contact a shop and ask what receivers are in the models. https://www.nexusmodels.co.uk/spektrum-gps-module-carbon-cub-s2-sportsman-spma3173.html Edited November 19, 2022 by cymaz Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 19, 2022 Share Posted November 19, 2022 Welcome to the forum Propwash, you have any questions, get them asked, most on here don't bite. 😉 Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 19, 2022 Share Posted November 19, 2022 Doesn't the receiver have a gyro system already? Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 19, 2022 Share Posted November 19, 2022 Just now, Shaun Walsh said: Doesn't the receiver have a gyro system already? Sorry you mean you want to add a GPS module to the receiver. Quote Link to comment Share on other sites More sharing options...
Propwash67 Posted November 20, 2022 Author Share Posted November 20, 2022 Yes, add a GPS, even though I will be an Intermediate flyer I still would like some backup, having a fence and panic button would make the $600 project a little less stressful, I am learning to fly on a cub less expensive, plz again I am new to the forum, don’t send me away crying, thanks for the inputs Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 20, 2022 Share Posted November 20, 2022 Hi Propwash, this will do exactly what you want: ZOHD Kopilot Autopilot System Flight Controller with GPS Module [ZOH1000-002] Motion RC Europe Click on the Support tab on the Motion RC page to find the manual. The manual takes a bit of reading/understanding, but all you need is there. If the steps are followed correctly, it's relatively simple to set up and works well. Kolpilot is a flight controller only, so it works in conjunction with your receiver. Using a 3 postition switch you can have, (a) totally manual flying with no interference from the flight controller, (b) stabilised flight or (c) return to home. However, as the Kopilot takes care of all aspects of the flight in (b) & (c) above you need to disable the SAFE and AS3X capabilities of the AR637T receiver, otherwise you will have two systems competing which will not have a good outcome. I'm not a Spektrum user so you'll have to find out from other forumites how SAFE and AS3X can be disabled. The Kopilot FC only controls channels 1-4 for ailerons, elevator, throttle and rudder, and channel 5 for mode select. Other channels, used for auxiliary things like flaps and lighting, are controlled direct from the receiver. GDB Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 20, 2022 Share Posted November 20, 2022 (edited) 2 hours ago, Propwash67 said: Yes, add a GPS, even though I will be an Intermediate flyer I still would like some backup, having a fence and panic button would make the $600 project a little less stressful, I am learning to fly on a cub less expensive, plz again I am new to the forum, don’t send me away crying, thanks for the inputs Don't think that they are compatible. If you want features like geofencing and autoland I think you would need the receiver and fight controller (2 separate items) supplied for the Carbon Cub S+ together with the gps module and even then I'm not sure if it would work correctly in a different airframe, Edited November 20, 2022 by Shaun Walsh Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 20, 2022 Share Posted November 20, 2022 48 minutes ago, Caveman said: Hi Propwash, this will do exactly what you want: ZOHD Kopilot Autopilot System Flight Controller with GPS Module [ZOH1000-002] Motion RC Europe Click on the Support tab on the Motion RC page to find the manual. The manual takes a bit of reading/understanding, but all you need is there. If the steps are followed correctly, it's relatively simple to set up and works well. Kolpilot is a flight controller only, so it works in conjunction with your receiver. Using a 3 postition switch you can have, (a) totally manual flying with no interference from the flight controller, (b) stabilised flight or (c) return to home. However, as the Kopilot takes care of all aspects of the flight in (b) & (c) above you need to disable the SAFE and AS3X capabilities of the AR637T receiver, otherwise you will have two systems competing which will not have a good outcome. I'm not a Spektrum user so you'll have to find out from other forumites how SAFE and AS3X can be disabled. The Kopilot FC only controls channels 1-4 for ailerons, elevator, throttle and rudder, and channel 5 for mode select. Other channels, used for auxiliary things like flaps and lighting, are controlled direct from the receiver. GDB The Kopilot would probably work. SAFE and AS3X are easily disabled, simply power up the transmitter and receiver, open the Forward Programming menu on the transmitter, and choose reset to factory settings, it should then act as a normal unstabilised receiver. Quote Link to comment Share on other sites More sharing options...
