FW190 by Cambrian Funfighters
DaveB1
Thanks to all the tips from this forum, I spent another enjoyable evening applying some weathering. Panel lines and rivets using a fine black marker, highlighted using a white gel pen, then sprayed some dark grey weathering behind and to one side of each line with just some held card masking. A touch of dry brush silver on leading edges etc to illustrate some worn paint to finish.
The best bit was peeling off the windscreen masking to reveal the result - dead chuffed tbh.
Just the radio install to complete now
  • Like 9
  • Thanks 1
  • 3 weeks later...
Finally got to maiden it today. Used a 9 x 4 prop on 3S which pulled 31A. It's a bit heavy so lumbered into the sky from a kind club members launch. I was wary that it would be a bit wild, but it wasn't at all and was slower and softer on the controls than I expected. It slowed up well with a very soft safe stall which was reassuring.
I'll try next time with a 9 x 6,  (that pulls 44A on the ground and I only fitted a 40A ESC so need to be careful of full throttle use (I can always go to 4S). I'll also add more aileron throw and less expo. Pretty pleased really, it was stable and looked great in the sky. Glad I added the rudder, it just felt like I had fuller control options.
  • Like 2
  • 8 months later...
  • 2 months later...
