Nigel Heather Posted May 18, 2023 Share Posted May 18, 2023 Does anyone know if the ESCs that come with the Wot foamies (Wot4, AcoWot, Wots Wot) are configurable - in particular do you have to 'tell' it the full and zero throttle. I've looked through the instructions and can't see anything. I can understand why the configuration could be hard set (non-configurable) but I would have thought you would have to teach it the full and zero throttle position. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 18, 2023 Share Posted May 18, 2023 I have a motor/ESC setup which I rescued from a Wot4 foamy. The ESC was labelled Ripmax Quantum 40 so I downloaded the instructions which worked to reprogram the brake... http://www.ripmax.com/Instructions/p-qesc40.pdf According to these instructions, you can set the throttle range. I'm guessing this is the ESC you have so it's worth a try. 1 Quote Link to comment Share on other sites More sharing options...
John Lee Posted May 18, 2023 Share Posted May 18, 2023 (edited) I have never needed to play with any settings on foam Acrowot/Wots-Wot on Spektrum/Futaba/Jeti Just plug n play. Edited May 18, 2023 by John Lee Typo 2 Quote Link to comment Share on other sites More sharing options...
Nigel Heather Posted May 18, 2023 Author Share Posted May 18, 2023 4 hours ago, Andy Stephenson said: I have a motor/ESC setup which I rescued from a Wot4 foamy. The ESC was labelled Ripmax Quantum 40 so I downloaded the instructions which worked to reprogram the brake... http://www.ripmax.com/Instructions/p-qesc40.pdf According to these instructions, you can set the throttle range. I'm guessing this is the ESC you have so it's worth a try. Thanks for the suggestion. Mine isn’t marked as a Quantum 40, it has Century branding. I tried the instructions anyway but they didn’t do anything. I must admit, I don’t recall ever having to set anything up, it just worked. Cheers, Nigel Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 18, 2023 Share Posted May 18, 2023 I'd mirror John Lee's comments - did nothing on a foamy Acrowot (Spektrum), or Wots Wot (Spektrum, Taranis and Radiomaster TX16) Quote Link to comment Share on other sites More sharing options...
