Don Fry Posted October 19, 2023 Share Posted October 19, 2023 Err, flyin, don’t recall the steel melting, twisting due to loss of load bearing ability, as the fireman’s mantra from long before leccy cars were produced went, “don’t trust a truss” in my world a Dutch oven is a casserole pan with lid. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted October 19, 2023 Share Posted October 19, 2023 1 hour ago, john stones 1 - Moderator said: No expert on fires nor have I an agenda, dunno what temperature coke burns at, but when I was Blacksmithing we got it hotter by blasting air in, leave your work in forge too long and it melted ? Complex thing is fire and many factors at play in the various types. Certainly every opportunity for air to be drawn in through the open sided structure 1 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted October 19, 2023 Share Posted October 19, 2023 28 minutes ago, Martin Harris - Moderator said: Certainly every opportunity for air to be drawn in through the open sided structure It's a tricky balance, an opensided structure would help dissipate any hydrocarbon spillages and prevent a vapour cloud, petrol has a flash point of -45 degC, preventing concentrations reaching the flamable limit, so while enclosing it may reduce the severity of a fire, it may increase the probability. Offshore oil/gas production platforms enclosed modules are designed for a certain number of air changes per minute with gas detection sensors to monitor hydrocarbon, with non hazardous modules being at a slightly higher pressure to prevent hydrocarbon ingress. As you can guess quite expensive so where conditions permit open sided is preferred. Quote Link to comment Share on other sites More sharing options...
