Futaba R3008SB or R2008
Rocker
Have a Futaba 10J Transmitter and have always used the Futaba R3008SB receivers in my models .I am about to change 3 models over from Spektrum to the Futaba 10 J .So I need 3 Futaba receivers to do this  Was going to buy 3 R3008SB  but I do not use telemetry so was thinking of getting 3 R2008 receivers.
Anyone tell what is the difference between the 3008 and the 2008 .I do not use telemetry  It is just that the 2008 are a bit cheaper
I
The difference between the 2008 & 3008 is the Modulation Type in similar way as Spektrum DSM2 & DSMX.......  the Futaba 2008 is S-FHSS and the 3008 is T-FHSS not all Futaba Tx's transmit both T-FHSS & S-FHSS some only do one or the other where as the Futaba 10J does transmit both
Edited by GaryW
