Balsa Basics Spitfire
I'm looking to start my Vintage Model Company Balsa Basics Spitfire in the next wee while, and was just looking to hear from anyone who had experience of building it.
I've had my kit for 4 years, but have been so preoccupied with trying to build foamies that it's been sat collecting dust for yonks!  Mine has the "upgrade" pack which included the single-stub exhaust pipes and the dual radiator fairings.  Paint scheme TBD - possibly a Battle of Britain-style paint scheme or something similar.
25 minutes ago, Daren Cogdon said:
Good to hear!
In the videos, the standard covering seems to be something called Oracover?  Is there anything you would recommend?
Oracover works, as would any generic iron on film. I personally used dressmakers polyester and Ezedope on mine. The Spitfire I used coloured fabric for an almost 1950s FAA Seafire, the Hurricane and 109 I painted.
10 hours ago, Daren Cogdon said:
Good to hear!
Maybe worth looking at using the laminating film in this case, since you'll be wanting to paint the Spitfire and using Oracover for that is a tad expensive, especially if you are going to paint over it.
Ron's thread about using 38 or 42um laminating film is very instructive and I've been delighted with it in use.
Daren, if you fancy trying the laminating film, just drop me a PM with your address and I'll pop a few metres of it in the post. Afraid I've only got the 38um gloss film as surplus  in stock, so that will need rubbing down prior to paint application, but it'll give you a chance to experiment.
45 minutes ago, Nigel Heather said:
Presumably it cost you a lot less 4 years ago though.
Must admit, was tempted to buy a hurricane though - will have to see what electronics I have lying around at home.
The hurricane is by far the best BB kit. At 44" she's the biggest, and she just "copes" better with more conditions. It's got the most wing area too, and it'll absolutely float in like a trainer.
The Spit is good, brilliant in fact, but the Hurricane is more gooderer.
The 109 can be a little tricky, and there was a typo in the original instructions that put the CoG too far back, but they're all brilliantly flyable and the build are almost identical.
  • 1 month later...
