Anthony Green Posted March 23, 2009 Share Posted March 23, 2009 Hi, I have recently purchased a Top Gun Javelin 2, it its supplied with a metal engine mount & a two clamp bars, it tells you to use nut & bolt to clamp down the engine, so you don't actually put the screws in the engine holes. I have never seen this before, normally i just bolt the engine down with screws & nyloc nuts. Has anyone come across this? Its it ok/or should i purchased a different mount? Thanks Anthony Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted March 23, 2009 Share Posted March 23, 2009 I had one of those supplied with a Ripmax 40 Trainer. Didn't like the look of it so didn't use it. Stick with a standard mount. Quote Link to comment Share on other sites More sharing options...
Anthony Green Posted March 23, 2009 Author Share Posted March 23, 2009 Thanks, Here is an image of said engine mount. http://www.jperkinsdistribution.co.uk/detail.php?JPNO=5508173&activepage=1&Navmain=Accessories&subcatname=Engine%20mounts Anyone else used one/not used one? Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 23, 2009 Share Posted March 23, 2009 I first saw one in an Irvine Wild Card I bought about 5 years ago......I didn't like the look of it either but used it anyway.....mainly to try & prove myself right when the engine vibrated loose.....I'm still waiting!!!! Use threadlok, tighten the bolts fairly tight & you'll be fine (& I never thought I'd hear myself say that!!!) Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted March 23, 2009 Share Posted March 23, 2009 A lot of people swear by using self-tappers and have never had them fail. i prefer bolts and Ny-loks. Personal choice really! Quote Link to comment Share on other sites More sharing options...
Mark Lubbock Posted March 23, 2009 Share Posted March 23, 2009 I have used this system on a VMAR Extra/Irvine .46 & the engine never worked loose-The system works well in my experience Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 23, 2009 Share Posted March 23, 2009 Worked fine on my Javelin - follow the advice to use nylocs or threadlock. Quote Link to comment Share on other sites More sharing options...
winchweight Posted March 23, 2009 Share Posted March 23, 2009 Used them with nylok nuts. No dramas at all. Quote Link to comment Share on other sites More sharing options...
Anthony Green Posted March 24, 2009 Author Share Posted March 24, 2009 Hi, Thanks for all advice. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted March 25, 2009 Share Posted March 25, 2009 I had one in my Ripmax 40 trainer sa well. Nocked the front one day as I was putting it in the car. Both sides of the mount broke where the rear bolts went through it. Not sure if I had a duff one with a stress fracture or something else. Rplaced with a nylon mount and 7 or so years later it still flies. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 26, 2009 Share Posted March 26, 2009 you could just use it as a bench test engine mount, it is what i used my one like that for, in the end it was too fiddly mounting the engine dead in between the lugs, it now sits proud at the front of my workmate! Quote Link to comment Share on other sites More sharing options...
