Chris Bott - Moderator Posted October 25, 2010 Share Posted October 25, 2010 That will be the right thrust built in then won't it Danny? One thing that is confusing me in your pictures (yes I know confusing me is really easy) is the photo showing the glued and sanded side. On the plan just below that side is a cutout showing an almost hexagonal former with different side parts glued to different hexagon faces. But you are saying the side will have to be bent around the formers?? "I gave him a couple of socks... !" Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted October 25, 2010 Share Posted October 25, 2010 Hi Danny I like your idea about the battery / motor box I might copy your idea instead of using studding, still no wood cut, but I did stick some cork floor tiles to my building board to make it easy to pin things to yesterday Tom Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 Hey Tom, its a start matey, steal away. I did used to be a big fan of the studding method and in the right situation it works fine. The trouble with it is you are wasting a bit of nose area, that could be utilised for the batteries. If the model has no issues with C of G then great the threadall method is quick, light, and strong. It also allows infinite adjustment and also allows different length motors to be tried very easily. However if you need the weight as far forward as possible (still have never added nose weight to a model) then the box methos works well. It is a lot of extra work though Hi Chris, the sides are curved from top to bottom over the formers. And the sides are also curved towards the back as per normal. The massive 1" square triangle blocks have also to be curved to glue to the sides. Tony gets around this by notching them. This all means a fuselage can be knocked together very quickly. "For those less educated I'll translate, our chum can't believe the Sudan has fallen....." Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 25, 2010 Share Posted October 25, 2010 Thanks, makes sense now. Once its all glued together there's going to to be lots of balsa shavings Then maybe time to break out the belt sander I do love a good whittle / carve. Or does that make me a bit of a butcher? Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 Yes lots of shavings, shame Roisin doesn't have a hamster or guinea pig I do know what you mean as far as carving big lumps of wood, I find it very therapeutic to use the razor plane, and shavings are easier to clear up than the dreaded balsa dust This shot shows the lite ply doubler that is not shown on Tony's instructions. I had to tweek mine slightly to ensure the bulkhead F1 alignment was correct and to ensure the gap around F2 was tight. I have to remove a good bit of F2 to clear the Battery box. The RHS is done as far as I can go. I used a razor saw to cut the notches in the 1" triangle stock, cutting about half way. I made more frequent cuts than Tony did, but my saw was making much narrower cuts. Anyway it worked better than I expected and the slots closed up nicely when the wood was curved. Thin Cyano was wicked in to make it all a bit more solid. The LHS was placed together to see if there was going to be a repeat of the RHS. It all fitted really well. No warps and it all glued together really easily. Once again I used Titebond for its gap filling properties. I am not looking forward to bending the wood along these glue joints. Definitely need some amonia or as Tony suggests water. Tally ho! "Get that Bowzer out of here, we'll go with what we've got!" Quote Link to comment Share on other sites More sharing options...
Herri Posted October 25, 2010 Share Posted October 25, 2010 This shot shows the lite ply doubler that is not shown on Tony's instructions. It looks like I made a mistake here and glued the FD1 up against WS1 and didnt leave room for F2. I'll have to modify F2 and make sure the joint at F1 is strong enough. B*****! Herri Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 LOL I had to chuckle at that Herri sorry.... I think that area is somewhat over-engineered so you will be fine with a nice fillet of epoxy. At least you didn't add 1/4 of an inch of balsa to one of your fus sides then have to cut it back of again And to finish my day off, I was just about to glue the wing seat doubler to the LHS fus that I have joined....... very, very, nearly had two right hand fus halves..... hands up those that have done that Now the next quote always brings a bit of a tear to my eye when watching THE film. If you know my favorite plane then you will know why....... "You know what to do with the lame ducks........." Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted October 25, 2010 Share Posted October 25, 2010 Have now glued the LHS together, not much but its a start! All went together perfectly, lots of batteries to weigh it down. Tom Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 Nice one Tom, pulling the pieces together used my main stock of pins, my spare stock and ANOTHER packet of T pins Have you a power set-up in mind yet? Cheers Danny "We haven't got all day!" Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted October 25, 2010 Share Posted October 25, 2010 Yes, pretty much the same as you Turnigy SK5065-270Sentilon HV ESC8s1p 3700mAh LiPo7.5A UBEC Total weight 1363g or 3lb! Will run it at 1800W @ 60A hopefully get 6 Min flights with some in reserve for landing, will probably try 5000mAh cells later on to get 8 Min flights, depending how the CoG works out. Need a prop and some servos next, but will wait untill I've built some more, I have 3 gliders that need repairing at the moment and another 1/4 built, and then there are the jets Edited By Tom Foreman on 25/10/2010 22:54:17 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 Hi Tom, indeed very similar. I have opted for the LiPo route, though the A123 would fit, but the thought of wiring 4 packs together puts me off, I am lazy. I have ordered a pair of 2S 5000 lipo packs to go with two 5S 5000 packs I have. That would give me a 7S 5000 on the slightly higher 380 KV motor, and another set to fly while I charge the first. There is room to go the 8S route but then I would need an High Voltage esc and I have a cheap 90A, 7S max esc doing nothing "I must therefore request that not one more fighter be sent across the channel" Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted October 25, 2010 Share Posted October 25, 2010 Posted by Danny Fenton on 25/10/2010 18:01:20:LOL I had to chuckle at that Herri sorry.... I think that area is somewhat over-engineered so you will be fine with a nice fillet of epoxy. At least you didn't add 1/4 of an inch of balsa to one of your fus sides then have to cut it back of again And to finish my day off, I was just about to glue the wing seat doubler to the LHS fus that I have joined....... very, very, nearly had two right hand fus halves..... hands up those that have done that Now the next quote always brings a bit of a tear to my eye when watching THE film. If you know my favorite plane then you will know why....... "You know what to do with the lame ducks........."" Flood the cowling, plenty of it...." Hi Danny - nice thread mate, it looks an interesting build Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted October 25, 2010 Share Posted October 25, 2010 Hi Danny, have you weighed your power train yet? I'm guessing its going to be similar to my set-up, hope its enough to balance this monster! RHS stuck together now. Better start cutting up F1, maybe tomorrow Tom Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 25, 2010 Share Posted October 25, 2010 I don't know, cant connect 4 batteries together. You plug one red into one black... that's two of em in series.... repeat - that's the other two.. (only joking) I bet you try it on A123's at some point. "Corporal, refuel them immediately!" (Now that you can do if you have a second battery set ) Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 25, 2010 Author Share Posted October 25, 2010 Hi Leccy, you got the next line well done that man. The following thirty seconds show probably the best low level flying I have ever seen, how that 109 pilot misses hitting the fence I will never know, absolutely superb. If you cant remember, its about 5 minutes in, go on get the film out, you know you want to.... what not got a copy.... shame on you However seeing all the beloved Hurricanes going up is not so nice. (good job they are only mockups) What are the chances of as many Spits up at next years RCM&E bash as they had at Duxford this year......(clue, I think it was 26) So don't just sit there, get one up! "Defeat in France will involve the final, complete and irremedial defeat of this country." Tally Ho!!! Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted October 26, 2010 Share Posted October 26, 2010 Posted by Danny Fenton on 25/10/2010 23:30:00:Hi Leccy, you got the next line well done that man. The following thirty seconds show probably the best low level flying I have ever seen, how that 109 pilot misses hitting the fence I will never know, absolutely superb. If you cant remember, its about 5 minutes in, go on get the film out, you know you want to.... what not got a copy.... shame on you However seeing all the beloved Hurricanes going up is not so nice. (good job they are only mockups) What are the chances of as many Spits up at next years RCM&E bash as they had at Duxford this year......(clue, I think it was 26) So don't just sit there, get one up! "Defeat in France will involve the final, complete and irremedial defeat of this country." Tally Ho!!! It'sa bit of a family joke mate - my boy Youngleccy had the BoB video on constant play from when he was about 3 years old until he was at High School, so I reckon we've seen it several hundred times. The three of us score points for getting a BoB line into the conversation. Mrs L collected the best point in refusing the chance of a trip to the club - "I've seen it" she said" A nasty little shack full of dead flies" which put us in our place. It also means keeping a constant look out for any pub called The Red Lion :D I recommend the excellent pair of books on the making of the film by Robert J.Rudhall. I'm not all that certain that the lowest Bf109 did actually miss that fence either . 26 Spitfires would be something to see at next year's bash. What about fifty? "You're not getting fifty. You're not even getting ten" Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Author Share Posted October 26, 2010 Hi Tom, Leccy and Chris, as well as anybody else joining in. Any other building one of these and just keeping quiet?? Not had much time today but got a little more done. The LHS is now finished to the same point that the RHS is. So its time to look at joining the two sides with some formers. Some thought also needs to be kept in mind about servo trays/rails and snake/pushrod runs. I know Herri is probably building a super neat cockpit and will fit that before he joins the sides. I think I will keep my cockpit pretty basic on this one. Excuse the glue staining, I used thin CA for the triangular sections and I fitted a fresh capillary tube it was sort of uncontrollable after that lol. I fitted a different brand tube now and order has been restored "The battle of France is over, the battle of Britain is about to begin." Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Author Share Posted October 26, 2010 More progress.... I made two templates to help set the front bulkhead F1 angle, and to set F4. F2 and F3 are vertical, so an engineers square can sort them out. When dry fitted F2 I found that the triangle stock was inboard too far, not much guidance on the plan really I had to releive it slightly to allow the fus sides to remain parallel. F1 first to get some epoxy.... Then F2 with lots of engineers squares to keep everything true (Not shown sorry ) Then it was F3's turn to meet Mr Z-Poxy (Again not shown, but the former was surrounded by engineers squares to keep it true while it set) Then it was time to do F4 because the fuselage has already started to taper in at this point the bulkhead is not at 90 degrees. A scrap balsa template was made using the plan view. And there you have it, the fus sides are joined. At the front at least. I then couldn't resist trying the battery box/Motor bulkhead for fit and checked the allignment. I have made an error somewhere the battery box is 0.25 mm out "Their Embassy in London gives you two weeks.......... So what's stopping you?" Tally Ho! Quote Link to comment Share on other sites More sharing options...
Herri Posted October 26, 2010 Share Posted October 26, 2010 You're really storming along Danny, but at least I'll be able to look at yours before I glue. My cockpit and spats are still holding me up and I have some other non modelling stuff to do this week. Cheers Herri Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Author Share Posted October 26, 2010 Hi Herri, once I get on a roll LOLOL Built a box within the battery box to do two things, one- stiffen the mount even more, and two- protect the end of the motor shaft. We don't want it spearing the cells in an abrubt conflict between the airframe and the ground do we? This should have been before the other pic lol I also closed in the other end of the battery box. Don't want the cells flying into the cockpit, that would ruin PO Pegge's day for sure. Fitted some servo rails too Tally Ho! Edited By Danny Fenton on 26/10/2010 19:38:49 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Author Share Posted October 26, 2010 Snakes and controls.... what are you guys doing as far as making the waggly bits move at the back end? I am a closed loop person myself but this model is not an out and out scale jobbie so am not too worried about the horns showing. I am probably going to use a slec heavyweight snake, for the elevator, and a lighter weight job for the rudder. I really do miss a steerable tailwheel on my Sea Fury, so would like one for this but the geometry is not good to make it steerable. Again what are you guys doing with yours? "We will fight them on the beaches...." Quote Link to comment Share on other sites More sharing options...
Herri Posted October 27, 2010 Share Posted October 27, 2010 I intend to use snakes for the elevator and rudder. The elevator horn will be inside the fuse and I had thought about a bellcrank at the rear and wire to the rudder horn so you dont see the snake. Cheers Herri Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 27, 2010 Author Share Posted October 27, 2010 What about a steerable tail wheel Herri? Any thoughts?? "Don't threaten or dictate to us until you are marching up Whitehall, and then we won't listen!" Cheers Danny Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted October 27, 2010 Share Posted October 27, 2010 Just be careful that it has a nice friction-free movement. "Undercarriage lever a bit sticky, Sir?" Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 27, 2010 Author Share Posted October 27, 2010 Toying with a variation on the RDS theme, might work. "As a matter of fact it was.... Well I shouldn't tell the CO that" Quote Link to comment Share on other sites More sharing options...
