Danny Fenton Posted September 26, 2010 Share Posted September 26, 2010 I have been plodding away at a BT Hurricane for nearly a year and I need a bit of a break. As Tony has just released the latest latest incarnation of his popular Spitfire I thought it would be great to put one together for electric power. I had a look at 4Max's motor choice for this on Tony's site, and George has picked a pretty good motor in the 5065. The Turnigy version is a favorite of mine I have the 350kv version in the Fury, and am using the 320kv in my BT Hurricane. The spit should have a 24" prop at 1/6 so have ordered a 270kv to try. A session in the garage with the range of motors, props and cells sounds on the cards. I will give CB (Chris Bott) a nudge, he loves all the techie research stuff and always has a good chuckle at my quest for the biggest props possible, often heard mumbling words such as torque, and unflyable LOL I think I will have to shave a little weight of this airframe as I want a bit longer than my normal 6 minute flight time, will want to up the A123 cell count to 15 - 18. it may still end up at 15lbs but hopefully no heavier as that is my fields limit. I will be using Fighteraces epoxy resin and glass, for those want to see how to use it, and Warbird colours again from Phil at Fighteraces. The subject???? The early airframes were very similar, so we can go from a MkI to a MkV. I am torn between K5054 the prototype and the clipped wing Vc but I am still thinking about that. So if anybody wants to join me, I will snap in a new number 23 and get started Tally Ho Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 26, 2010 Share Posted September 26, 2010 Hey....I'll be watching with interest Danny. I'm just about to start a Top Flite Sea Fury so will be interested in how the glassing is done as I think I'll use that on the SF but have never tried it. I do like the simple lines (and colour) of the prototype I think you have to weave a line from the film BOB into every post though Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted September 26, 2010 Share Posted September 26, 2010 Hi David, Second Danny on the Fighter Aces resin. Have never glassed before with a proper epoxy resin but have been useing the fighter aces stuff on my Halifax. Can confirm it goes on brilliant. Super stuff. Give it a go you will be amazed with the results. As long as you follow Phil Clarkes accompanying instructions/glassing guide (pdf download from his site) to the letter you will have absoloutely no problems. Well worth a try for your Sea Fury Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 26, 2010 Author Share Posted September 26, 2010 Hi Guys thanks for joining in. I am really looking forward to seeing the Sea Fury go together David, one of my favorites thats for sure. Saying that anything from Sydney Camm is allright by me this one, though by some other bloke.....R.J. something or other should be good though The resin Phil sells is nice, it dries with no waxiness and is a joy to sand. There are some tricks to putting it on and you wouldn't believe how little you use. I am no expert by any means but got pretty good results fairly quickly. You will need some scales that read to the gram though. Plenty on EBay for around a tenner. I am also going to do some raised panel edges using electrical tape and filler, plus vinyl chart tape and hi build primer to show panel lines for those that want to see how that is done. Again I am no expert but should be able to let everybody see enough so that you can have a go. This is a great subject to practice these skills on. I have contacted Tony at Unitracts regarding the cost for the retracts and he has comeback with £110 for mechanicals and £215 for air driven (plus postage) I am going to go with mechanicals because I have a big meaty servo lying around, and because I have had no trouble with my Seagull Fury on mechanicals. I have been studying the plan this evening and I think there are several areas for losing some weight. In fairness to Tony he did indeed say this during the You Tube interview. There is a great deal of thick wood used, which I may try and reduce. And also with careful cell position, and some weight saving on the tail I will try and remove that 1.5lb of nose weight. A huge amount will depend on the quality of wood provided. If it is dense then the weight will shoot up. The beauty of A123 is that you can more or less build them into the airframe, so no hatches and you can wedge them right at the very front, directly behind the motor. The electric motor also concentrates the mass much further forward than an IC so that also helps. Anymore suggestions on a scheme shout away, CB has chirped in with AR501 which WAS in clipped wing guise in the 80's and was also weathered which I like. Though there is something rather significant by doing K5054 Really looking forward to this "I see. So I tell the cabinet, that you're trusting in radar and praying to God, is that right?" Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 26, 2010 Author Share Posted September 26, 2010 Sorry for the long post Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted September 27, 2010 Share Posted September 27, 2010 This should be an interesting one Danny - the prototype does look well worth doing. It'll make a change from military colours. Slightly off topic temporarily - how do A123 cells perform in the cold? Lipo's don't much like it.(Winter's coming up ) Cheers. Quote Link to comment Share on other sites More sharing options...
Herri Posted September 27, 2010 Share Posted September 27, 2010 Nice one Danny, I will be joining you soon. My bench will be cleared today. The retracts have been ordered from Unitracts (air) although they cant deliver until november. I intend to do a MkV, maybe the Al Deere one from 1941. I have all the wood etc so I am really looking forward to this one. Cheers Herri Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 27, 2010 Share Posted September 27, 2010 My only comment Danny is DON'T build the clipped wing version...its 'orrible!!! A Spitfire has elliptical wings.........end of story!!! Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted September 27, 2010 Share Posted September 27, 2010 Might put mine on floats! D Quote Link to comment Share on other sites More sharing options...
batcho99 Posted September 27, 2010 Share Posted September 27, 2010 Nice one Danny. I'm keeping a close eye on this one. Good luck. I still cant make my mind up, i'm about 4 models behind everyone else when it comes to TN models! Arghh. I still want to do the hurricane. Iain. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 27, 2010 Author Share Posted September 27, 2010 Hi Richard A123 don't object to the cold as badly as lipo. the other thing is that they stay in the warm inside the fus I like the prototype, I always thought it was silver, but apparently a presentation model was built in 1936 using the same blue paint as the full size. That paint was used to match the replica in the photo. Anybody got any walkaround photos? Hi Herri, would be good if we can compare notes. Should be a nice model to build, not too difficult but a good size. Builds like a big funfighter Hi Steve, I must be odd, I really like the clipped wing variant. Not as beautiful as the std wing but kind of brutish in a Fury sort of way and different. Not as ugly as the extended wing tip variant. Hey David not sure if you are winding me up? certainly would be different though Hi Iain, good to have you watching. This is my first TN design so its never too late. Get on the blower and get some bits ordered, plenty of time to join in. Maybe we can all meet up at an event next year and get them up together. And for young Mr Ashby......... Shut up! Silence - in Polish! Edited By Danny Fenton on 27/09/2010 21:49:33 Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted September 27, 2010 Share Posted September 27, 2010 Well, much as I love the profile of the Eliptical wing, there is something about the Clipped wing... Something... Tough and functional. K5054 had three different paint jobs to my knowledge. It maidened in an aluminium and primer finish and then was very soon after painted Duck Egg blue. It then had the "A" camo scheme for public consumption. You have me thinking now... I might have to build my 62" Mk IX as an LF V with clipped wings. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 27, 2010 Author Share Posted September 27, 2010 Hi Hugh thanks for the background on K5054, that explains a lot I must confess I am not as well up on the Spitfire as I am on the Hurricane. I am looking forward to seeing how your S6B comes out Cheers Danny The *engine's* overheating, and so am *I*! Either we stand down, or *blow up*! Now *which* do you want? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted September 27, 2010 Share Posted September 27, 2010 Hi Danny, I always thought of the prototype colour as "airfix spitfire blue" and wondered why they used that colour plastic!. Here she is (well the replica) More pics at Plane Crazy Never let me catch you doing a victory roll over my airfield again. Understood? Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 27, 2010 Author Share Posted September 27, 2010 LOLOL thats the spirit...... How many time have I told you - never fly straight and level for more than 30 seconds in a combat area! Thats a lovely shade of blue but doesn't look like a weapon of war somehow.... Cheers Danny Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 28, 2010 Share Posted September 28, 2010 Colour scheme wise I've always liked the PR version too......... "We must find more pilots or lose....." Edited By David Ashby - RCME Administrator on 28/09/2010 08:10:40 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted September 28, 2010 Share Posted September 28, 2010 Somehow I think a spit just has to be Green/Brown or Green/Grey, don't you think? Here's AR501, this time with wing tips restored. "Hello? Hello, Abbeville? "Edited By Chris Bott on 28/09/2010 09:24:16 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 28, 2010 Author Share Posted September 28, 2010 Hello Rabbit leader......... Many years ago a friend of mine did PR Spit from the Mick Reeves kit, his was in pastel pink, the rivet detail etc showed up really well, but somehow it didn't look right to me. The PR blue is nice though. At the moment I am drawn to a mud and grass clipped wing...... Sorry Steve..... But I can't find one. They are all grey and green. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted September 28, 2010 Share Posted September 28, 2010 Detachable tips ? Problem solved ! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 28, 2010 Author Share Posted September 28, 2010 The Air Minister, sir. on the scrambler............Quick Steve is coming put the wingtips back on............ Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 28, 2010 Author Share Posted September 28, 2010 I am going to run out of quotes at this rate........ Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted September 28, 2010 Share Posted September 28, 2010 You can teach... Monkeys to fly better than that. I got a milion of them. If all else fails, we can start using quotes from Dark Blue World. Go the clipped wings. It'll roll better at low altitudes. Cheers, Hugh Edited By Hugh Coleman on 28/09/2010 11:03:19 Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted September 28, 2010 Share Posted September 28, 2010 did you know that they got the car builders at rolls royce to paint that colour on the prototype just because someone liked the colour they had seen on a car they built Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted September 28, 2010 Share Posted September 28, 2010 I Quite like it, I think thats the colour scheme for my half built Cambrian fun fighter sorted. "Where the hell are you Simon!" (Used by Pink Floyd on "Vera" from "The Wall"). Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 28, 2010 Author Share Posted September 28, 2010 Hi guys, well this will never do, page two and no wood in sight....... I did spot a rather famous Spitty that would be very fitting to model......despite pointy wings. "I thought you would come out of the sun....." Quote Link to comment Share on other sites More sharing options...
