Peter Miller Posted November 19, 2010 Share Posted November 19, 2010 I like your Pix-e Tim. I could never get the original to fly back in the early 50s. Probably my lack of experience but it just would not fly for me. I can't rememebr seeing one fly but they must have done. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 19, 2010 Author Share Posted November 19, 2010 Thanks Peter! I have to say that the little Pix - E is a lovely model to fly, although it seems to do even better if I leave the sticks alone! tim Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted November 19, 2010 Share Posted November 19, 2010 Tim, this looks fabulous. Yes please to a plan (free or otherwise) hint hint david Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 22, 2010 Author Share Posted November 22, 2010 Posted by rActive on 19/11/2010 15:51:08:Tim, this looks fabulous. Yes please to a plan (free or otherwise) hint hint david I'll do my best - promise! Having deliberated for weeks, I spent a bit of time on Saturday cobbling a steerable tailwheel together. A piano wire leg pases through a plastic tube (itself glued within a hardwood block), and has a bearing disc of brass soldered below, and brass arm soldered to the top.I did contemplate (in turn) a fixed wheel, a castoring wheel, and a tail skid, but thought that this would allow for any eventuality! Now the other end of pushrod is connected to the rudder servo, but not wanting to transmit any undue loads to the servo's tiny gears, I've made up a sort of shock absorber with a couple of short lengths of silicon cable insulation. I've used simialr items before that use steel springs, so we'll see if this works, eh? Other than that, I've spent a few minutes fitting the dummy engine cylinder in place withing the cowl ring. They'll look better when when they're painted.... So now it's time to start filling and sanding! tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 22, 2010 Share Posted November 22, 2010 Hi Tim I have a future project for you. There are other pictures. I designed a CO2 powered version many years ago at 22" span and it flew FF like a dream. SAMs models do my plan of that model. I toyed with the idea of a big one but for the power that I would want to use it would be very big, far wider than my my board. There is a Russian Website that google can translate after a strange fashion. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 22, 2010 Author Share Posted November 22, 2010 What a bizarre looking creature! (No, not you Pete - I meant the aeroplane.......) It's a sort of motor-glider I suppose. No shortage of wing area either! tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 23, 2010 Share Posted November 23, 2010 I thought that you would like it. Yes, it started out as a glider which was aerobatic. Then in 58 they fitted a little flat twin engine. As I said, my CO2 version flew like a dream. Yes, I probably look bizarre too but not quite as much as that. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 25, 2010 Author Share Posted November 25, 2010 Have to admit, Peter, it does look tempting...... Anyway, I'm strictly a one-at-a-time sort of bloke, so I'm now festooned with silver Solarfilm......(Mind you, I've just ordered 10 metres of Solartex for the next project.......) tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 26, 2010 Author Share Posted November 26, 2010 Now, covering isn't my favourite part of a build, so I tend to have little projects on the go to distract me form time to time. So with the wing covered, I figured it was time to paint the canopy framing with silver enamel, and then start to actually glaze the cockpit. Although there are no compound curves involved, it is quite complex so I'm doing it in small section. tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 1, 2010 Author Share Posted December 1, 2010 It's been a little hectic here over the last few days, but I have actually managed to finish the last of the glazing. The four overhead panels were best done one at a time. Then the frame was disguised with strips of silver Solartrim. Anyway, here're a few more pics of the full-sized Courier, in order to offer a few more colour schems. The RAF camoflage looks pretty obvious (including a much deeper cowl), but I'm unable to obtain any details of the actual colours used in the other schemes. Any guesses? Edited By Tim Hooper on 01/12/2010 17:19:50 Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 3, 2010 Author Share Posted December 3, 2010 See? I told you I'd been busy, didn't I? tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 4, 2010 Share Posted December 4, 2010 Very neat indeed. You wil find a picture of an all silver courier here http://www.airliners.net/aviation-photos/ The best site that I know for aircraft pictures. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 4, 2010 Share Posted December 4, 2010 Really looks great Tim. I look forward to the assembled shot Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 4, 2010 Author Share Posted December 4, 2010 Thanks Peter! Dan, I'm going to get the model in the air, just to see if it flies, before I start on any graphics or detailing. The tail surfaces are installed and hooked up to their servos, as are the ailerons. The motor is installed and tested (Turnigy 3542 1250Kv). The 9x6 prop is balanced, so now I'm just working out where to place the battery to achive the correct CG. Nervous? Me? Naaaah.......tim Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 4, 2010 Share Posted December 4, 2010 This will fly beautifully Tim, it looks right I know its not the sort of question you ask of a lady, but how heavy is she? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 5, 2010 Share Posted December 5, 2010 Weight is not the question to ask, it is meaningless on its own. What is the wing loading? Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 5, 2010 Author Share Posted December 5, 2010 OK, out with the calculators........ Weight currently stands at 2lb 10oz (including 3S cell pack), so it really shouldn't be much more than, say, 44oz when completed. Wing area is pretty close to 415"², so that equates to a loading of around 15 oz/ft. Unless my maths are wrong, of course....... tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 5, 2010 Share Posted December 5, 2010 That is very good. Should be really nice. My Fournier will have a wing loading of just over 17 oz per sq. ft. Quote Link to comment Share on other sites More sharing options...
r6dan Posted December 5, 2010 Share Posted December 5, 2010 That is looking really good,the glazing looks to be a bit of a pain though! Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 5, 2010 Author Share Posted December 5, 2010 Peter, Just for you, I've blown the dust off my Wattmeter this evening and taken a reading. At full throttle (on a fresh 3S 2700Mah battery) the Turnigy 3542 1250Kv motor (on hard timing), turning an APC 9x6 prop is pulling 39amps, and showing a total of 460 watts. This equates to a power loading of 167watts/lb. I knew you'd be fascinated......Dan,You're right about the glazing - it's best done a bit at a time, in amongst the rest of the build.Right, it's ready for its maiden! Trouble is the weathewr looks appalling for the next few days, so I might as well plod on with the graphics....tim Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 5, 2010 Share Posted December 5, 2010 Looks great as usual Tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 6, 2010 Share Posted December 6, 2010 Tim. Now you are getting too technical. However, based on your figures it should be great on a .15 Possibly even a touch over powered for scale. What rpm was the motor doing on the 9X6? Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 6, 2010 Author Share Posted December 6, 2010 Posted by Peter Miller on 06/12/2010 08:41:14:Tim. Now you are getting too technical. However, based on your figures it should be great on a .15 Possibly even a touch over powered for scale. What rpm was the motor doing on the 9X6? Peter, I think that 460 watts would be equivalent to a .30 glo, or thereabouts. Obviously, there'll be no shortage of power! FWIW, the power train I'm using is a 'known' set-up, which I'm using in two other models - my 50" Seagull PC-9, and Nettys 50" Seagull Spacewalker. Both are 'comfortably' powered, and capable of big, smooth aerobatics. All of which means that I'd reckon that the Courier would be viable on a .15 or .20 sized glo. Bit of a confession here in that I've never possessed a tachometer! However, if we assume that the theoretical figures are correct, then our 460 watts divided by the 39A current draw means that the batteries are supplying about 11.8 volts under load. 11.8 volts multiplied by the stated Kv value of 1250 yields a RPM figure of 14,737rpm. Naaaah......I don't believe it either! tim (looking for a laughing derisively smiley) Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 6, 2010 Share Posted December 6, 2010 My .15 powered semi-scale racers are roughly the same size with slighlty higher wing loading. They go like stink and are very aerobatic. The engines are turning 8X6 props. Not checked the rpm. My 32s run on 10X6 props at around 12,000. a .25 would be on a 9X6 and somehwere around the same rpm. My "Little Bandit" has 451 sq. in and a wing loading of 19 ounces per sq. ft. It does the book on a West.25 on a 9X6 and 10% nitro. Quote Link to comment Share on other sites More sharing options...
MarkyMarc Posted December 6, 2010 Share Posted December 6, 2010 Posted by Peter Miller on 05/12/2010 08:22:51: Weight is not the question to ask, it is meaningless on its own. What is the wing loading? About half of one of your designs, Peter... Just kidding Quote Link to comment Share on other sites More sharing options...
