Danny Fenton Posted November 8, 2010 Share Posted November 8, 2010 LOL is the pot to put all those loose marbles Tim? Go on tell us LOL That fus is a real treat to the eye, nice one. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 8, 2010 Author Share Posted November 8, 2010 Posted by Danny Fenton on 08/11/2010 13:01:15:LOL is the pot to put all those loose marbles Tim? Go on tell us LOL Watch it, Fenton. tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 8, 2010 Share Posted November 8, 2010 The corrugated tube makes great cylinders!! Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 9, 2010 Author Share Posted November 9, 2010 Posted by Peter Miller on 08/11/2010 18:25:08:The corrugated tube makes great cylinders!! The man wins a goldfish! ............and a slice of that flower pot should make up the rear portion of the cowling, which has quite a pronounced taper. We'll give it a bash later. tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 9, 2010 Share Posted November 9, 2010 Been using the tube for years! I recently bought four Veron Cylinders on Ebay. Don't know what I will use them for but it was too good to miss. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 9, 2010 Author Share Posted November 9, 2010 Peter, Having hewn the cowl, it's going to be a bit of a fiddle to try to fit the dummy cylinders inside the cowl. There isn't much clearance! tim The balsa nose ring and slice of flower pot. Sanded to shape and trial fitted. Doesn't look too bad really! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 10, 2010 Share Posted November 10, 2010 Pretty good I'd say. Yes a bit crasmped for space Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 10, 2010 Author Share Posted November 10, 2010 Right-oh. No building today - the flying field is beckoning me to get a few flights in before I go to work this afternoon! It's a tough life etc....... Anyway, I did take a few minutes out to check weigh the progress so far, so I loaded up the scales thus; Airframe3S 2700 cells packMotor, prop, spinner,ESC,UBEC.Rx, 4 servosUndercarriage and wheelsPilot Total 2lb 7oz All I need to add now are the wing and wheel fairings, covering, linkages etc. so we could be in for an AUW of less than 3lb for 400²". Fingers crossed, eh? tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 12, 2010 Author Share Posted November 12, 2010 Oooooh look...................wing fairings! I've never made these before, so I'm pretty pleased with this mornings work. tim With the wing protected by cellophane, I made some rough paper templates. 1/32 ply formed the bases. The wing seat was relieved slightly to make room for the ply. 1/32 balsa easily conforms to the contours. Just needs filling and sanding... Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted November 12, 2010 Share Posted November 12, 2010 Tim, You know your way with balsa, your doing a great job with this model. What can I say more than keep on posting those pics so I can follow and enjoy your every step. Ton Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 13, 2010 Share Posted November 13, 2010 A Master Class in building Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 14, 2010 Share Posted November 14, 2010 THose are really neat wing fairings. I know just what a pig they can be to make Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 14, 2010 Author Share Posted November 14, 2010 Thank you Gents - although I'm far from being a master at this aeromodelling nonsense! Anyway the rain stopped long enough this morning to allow to pin/tape/tack all the bits together for some shots of the almost-ready-to-cover airframe. Netty gives the Courier some scale.... Sorry about this one! Quote Link to comment Share on other sites More sharing options...
Augusto Posted November 14, 2010 Share Posted November 14, 2010 It's a beauty Tim, congrats fellow Cheers, Augusto Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 14, 2010 Share Posted November 14, 2010 Very nice Tim, aircraft of that period just have a certain charm and charism i think, look forward to seeing the finished project. Lindsay Quote Link to comment Share on other sites More sharing options...
Erfolg Posted November 14, 2010 Share Posted November 14, 2010 I cannot but note the short nose. Will ballast be needed to get the Cg whee you want it? I ma particularly impressed with the wood work in the front windows. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted November 14, 2010 Share Posted November 14, 2010 Super looking model Tim, well done. If its true that if it looks right it will fly right then this one surely must Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 14, 2010 Author Share Posted November 14, 2010 Thank you Gentlemen! Your kind comments do indeed mean a lot. Erf, I noted the short nose when I first drew up the plan, so I've already lengthened the nose by some 20mm! You'll also note that the battery tray is over 12" long to allow myself to place the battery wherever it's needed. Mind you, I was quite surprised today to find that the airframe as shown (but with wheels retracted aft) actually balances exactly on my chosen CG point, which means that, even after covering and servo installation, I should be able to achieve the CG just by moving the cellpack around a tad, without resorting to adding ballast. Good,eh? tim Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 14, 2010 Share Posted November 14, 2010 Your to clever for words Tim,2 lovely models and you ,nice photos,looking forward to seeing the complted model. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 14, 2010 Author Share Posted November 14, 2010 Posted by Stephen Grigg on 14/11/2010 17:39:20:2 lovely models and you...... Any more veiled insults like that, and you'll be joining Fenton in the Naughty Book, OK? tim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 14, 2010 Share Posted November 14, 2010 Superb Tim. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 14, 2010 Share Posted November 14, 2010 Awesome Tim, nice job Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted November 15, 2010 Share Posted November 15, 2010 TIm, thats excellent. Highly impressed Whats the chances of it being a future RCME plan?? Craig Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 15, 2010 Share Posted November 15, 2010 Very good Craig from our perspective. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 15, 2010 Author Share Posted November 15, 2010 Posted by Craig Carr on 15/11/2010 10:29:50: Whats the chances of it being a future RCME plan?? Craig Craig, That all depends if it flies or not........Put it this way; the plan is drawn and the accompanying article is mostly finished! Other than that, we'll have to see!tim Quote Link to comment Share on other sites More sharing options...
