Josip Vrandecic -Mes Posted October 15, 2010 Share Posted October 15, 2010 NO CHANCE to get an electronic value-scheme of any Futaba products,especially 2.4 Ghz, so listen to John' advice....and replace the antennaCheers! Quote Link to comment Share on other sites More sharing options...
Simon K 3 Posted October 15, 2010 Share Posted October 15, 2010 I'd suggest thinking of it this way...The Owner knows that part of his equipement is damaged.He's not sure if this affects the "servicability".God forbid he has an "incident"....I'd suggest that he may not be insured....?I'd suggest that a good prosecution lawyer may well be able to use this...?CAA would probably take a very dim view of this, if it came to their attention....?Therefore, Is it really worth taking the risk? Ultimately his choice.... EVERY DECISION HAS A COST... CAN HE AFFORD TO MAKE A BAD ONE?Edited By Simon K 3 on 15/10/2010 15:47:32 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted October 15, 2010 Share Posted October 15, 2010 Wow, I've been out of circulation for a couple of days - even missed my Thursday flying day - and when I last looked at the thread there was only Timbo's one word reply which I thought said it all. I was absolutely amazed to see the number of posts! Why take a chance - even though the original post seemed receiver orientated? Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted October 16, 2010 Share Posted October 16, 2010 Actually, to put a spanner in the works, yes he will be fine flying his FUTABA tx with a couple of mm missing from the end of his TX aerial, the last 25mm or so is a plastic shield, no wire inside, so if it was just a mm or so then yes he will be fine. Regards Chris. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 16, 2010 Share Posted October 16, 2010 NO Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 16, 2010 Share Posted October 16, 2010 And before you ask.....because how can be SURE that the cable didn't suffer a fracture or severe strain during impact - this could cause an intermittent fault, or loss of range, or complete failure at some point - if not now.Come on guys...is it really worth the risk. Quote Link to comment Share on other sites More sharing options...
Geoff N Posted October 16, 2010 Share Posted October 16, 2010 Posted by Tim Mackey - Administrator on 16/10/2010 18:55:16:And before you ask.....because how can be SURE that the cable didn't suffer a fracture or severe strain during impact - this could cause an intermittent fault, or loss of range, or complete failure at some point - if not now.Come on guys...is it really worth the risk. Your right the shock could have been transmitted to the main circuit board via the case ,so best buy a new transmitter and be safe Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted October 16, 2010 Share Posted October 16, 2010 Well if you seriously suspected that, it would make sense to check the PCB visually or get it checked out by a service agent but in the real world there's a far more realistic chance of referred damage to the adjacent wire or connection plus there's always the question of why Futaba thought it worthwhile to put 25mm of wasted plastic on the end. Perhaps the idea is to give you 27 nanoseconds warning that you're about to trim something useful off the end? Quote Link to comment Share on other sites More sharing options...
Erfolg Posted October 16, 2010 Share Posted October 16, 2010 It should be apparent by a visual inspection if there is any possibility of the aerial having been potentially shortened. If it is apparent there is either a hole or a conductor is seen, then it there is a risk that the aerial has been damaged. However if only plastic is apparent after a close visual inspection, it is not unreasonable to assume that the damage is purely visual. In this case a range check would be prudent. Some of the responses seem hysterical. The set is still legal if it conforms to the appropriate regulations. Remembering that a non CE compliant device cannot be resold legally. But can still be legal for use. Insurance should not be invalidated. Quote Link to comment Share on other sites More sharing options...
Jazzy-cjb Posted October 18, 2010 Share Posted October 18, 2010 Firstly Thank you Keith for bringing this to my attention. I am the Chairman of the club involved here. I would like to point out, that when I was made aware of this incident today, I immediately contacted the member involved. I have instructed him not to use this radio until it has been fixed. Either by sending it away or returning it to ripmax personally. I would like to also thank all of you for your responses to the thread. Obviously this cannot be used to fly and I hope the pilot in question wouldn't have flown with it. Colin Barnby Chairman bmfc Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 18, 2010 Share Posted October 18, 2010 A wise and responsible response jazzy-cjb. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 25, 2010 Share Posted December 25, 2010 Quote " But how can he be breaking the LAW, it is at worst a free flight model" No its not ! How can a rc model be compared to a free flight model ? Erflog obviously has not trimmed any FF models for a long time or forgoten how to . Free Flight model also tend to be a bit lighter than the average 120 sized rc model . I realise its supposed to be a fun argument, but I (and modellers I know ) have actually seen and had to deal with this type of approach to model flying and it is at times frightening . IF its broke dont fly it get it checked.Edited By Engine Doctor on 25/12/2010 12:25:37 Quote Link to comment Share on other sites More sharing options...
kiwi g Posted December 26, 2010 Share Posted December 26, 2010 just read this thread. and Im now wondering why.. why all the answers when the simple one was no. get it fixed. Why even consider wrecking a plane , hurting someone ,or damaging property. seems a bit thick if you ask me. its not like this sort of information isnt made public from the maufacturers and if one reads the instruction book it will say dont operate if damaged. good to see the club chairman stand in and take effect.. good on that man. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 26, 2010 Share Posted December 26, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
kc Posted December 26, 2010 Author Share Posted December 26, 2010 This thread is now FINISHED! It was started by me to obtain technical opinions to enable the club committee to have good reason ( if necessary ) to ban the gear if the member tried to use it. I understand the member concerned sent the Tx away for repair. Quote Link to comment Share on other sites More sharing options...
