fly boy3 Posted March 2, 2012 Share Posted March 2, 2012 Resetting trims etc on OD electric , selected wrong model with the result motor burst into life. Good thing I had removed prop. Cheers Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted March 2, 2012 Share Posted March 2, 2012 Seen that happen before with a 60 size 2 stroke. Chap started it on the starting bench, thing took off and was luckily stopped by the mesh guard at the pilot stations. It was secured at start up, but a 60 2S is preety powerful. it ripped the wings off when it hit the guard. Quick investigation, he has selected the wrong model on his TX. All sounds bad, but this guy is usually super safe and has been model flying for 50 years. He has many published plans and still writes for a US RC magazine. Lucky you had the prop off. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted March 2, 2012 Author Share Posted March 2, 2012 Hi Christian, apparently with the newer and more expensive Tx's this cannot be done. ? Cheers, a very good safety aspect. Quote Link to comment Share on other sites More sharing options...
John Privett Posted March 2, 2012 Share Posted March 2, 2012 I don't know about "newer and more expensive Tx's", but Spektrum have (and have always had) ModelMatch which uses the model memory numbery in the binding process so the the model won't respond if the wrong model memory is selected. But they patented it so nobody else can use it. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted March 3, 2012 Share Posted March 3, 2012 I think his was the old 72mhz Futaba 6EAX Quote Link to comment Share on other sites More sharing options...
moorer Posted March 3, 2012 Share Posted March 3, 2012 yep,did a stupld thing myself recently.resurrected my old formosa and was programming my dx6i did everything and the last check was motor rotation ,so fitted the prop, held the model and opened the throttle and all was ok,then i noticed that i was on heli and not acro, so i flicked over to acro----- BIG MISTAKE!!! the poor old thing promptly took off and demolished itself against the door frame!! i guess you never learn !! Quote Link to comment Share on other sites More sharing options...
Cyclicscooby Posted March 3, 2012 Share Posted March 3, 2012 I bought a 2nd hand VoyagerE Heli, with nice Bell230 fuse, while still learning to fly a little Zoom400.. Promised myself I wouldn't fly it until I was ready, but couldn't resist powering it up... ON THE BED... Like you do.. ! Throttle was reversed, so instant full throttle was achieved.. !! I panic'ed, and instead of moving the stick, I tried to remove the battery, which resulted in my arms getting cut, and tipping the heli over busting the blades, and bending the main shaft.. Fortunately, because it was on the bed, the fuse was OK, and I got to take the mechanics apart sooner than I thought.. !! I'd like to say i've learned from my mistakes, but we wouldn't be human if we didn't screw-up occasionally.. ! Luv Chrisie.. xx Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted March 3, 2012 Share Posted March 3, 2012 On the Planet 5, if you swop the throttle switch, the motor won't work, unless you actually switch off the tx/rx before powering up.Nice. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted March 3, 2012 Author Share Posted March 3, 2012 Hi Christian, I too was using a Futaba T6EXP on 35Mhz, perhaps the Model Match safety prog. is confined to 2.4 Ghz ? Cheers. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 3, 2012 Share Posted March 3, 2012 Model Match is a Spektrum only feature. Quite why no other manufacturer has found a way round the patent issues astounds me! Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 3, 2012 Share Posted March 3, 2012 Its a classic mistake FB3.....the other one is reversing the throttle channel whilst everything is connected up.....the motor goes from zero to max revs rather quickly......it underlines the very important point.......set up an electric model with the prop removed.... Quote Link to comment Share on other sites More sharing options...
Erfolg Posted March 3, 2012 Share Posted March 3, 2012 I find that a strange occurrence. Non of ESC will start on full or part throttle, until the start up procedure is gone through by the ESC. When it is identified that the throttle is not in the lowest position, they all make some noise, to tell you to shut the throttle, to a safe condition. I have about 20 ESC's. Hmm very strange. They will not even start if the prop is impeded, by say the ground. They vibrate back and forth trying to sort out the feed back. Quote Link to comment Share on other sites More sharing options...
Cyclicscooby Posted March 3, 2012 Share Posted March 3, 2012 I did move the stick amonst the panic, but my brain didn't compute what was wrong until after the fact... Its a Castle creation, 50A iirc, and it has got protection, but as I said, I panic'ed.. Luv Chrisie.. xx Quote Link to comment Share on other sites More sharing options...
