Rich too Posted February 1, 2014 Share Posted February 1, 2014 I just read that too. but John, don't they supply a template for DLE 30? I got the impression they do and that guy used the wrong template? I just noticed that you cannot change the angle of your motor with washers because it is too close to the cowl already - moving the engine up would help that.. Rich Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 this might be the answer - look at the angle of the spinner to cowl.... **LINK** check out post #12 "I installed it and set the cowl on the motor came out dead center like it shold but the cowl itself has way to much angle on the spinner ring. over 7* downthrust when run on the thrust line of the plane. irritates me but no one else really notice" reading that thread you've got nothing to worry about as you are, the guy said it flew great! Edited By Rich2 on 01/02/2014 15:44:06 Edited By Rich2 on 01/02/2014 15:46:07 Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 yeah thanks for that rich , I'm just going to go with it as you say , Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 same thread, same issue! **LINK** I don't think you've anything to worry about, there is obviously an issue with the angle of the front of that cowl. Edited By Rich2 on 01/02/2014 15:55:14 Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 Totally agree rich , look at this .... Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 The surface which the cowl is sitting on is perfectly level Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 1, 2014 Share Posted February 1, 2014 You can't measure relative to the base of the cowl - it doesn't mean anything John. You are assuming that the base of the cowl is a 90 degrees to the thrustline - there is absolutely no reason why that has to be so. BEB Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 Indeed! At least they are consistent!! No BEB, I agree with you, it can't be measured accurately but the thread I found above reported the same issues as John. there is obviously some issues with the angle on the front of that cowl - others reported the same in the thread. and the cowl line should in theory be 90 degress or thereabouts Edited By Rich2 on 01/02/2014 16:27:55 Edited By Rich2 on 01/02/2014 16:30:55 Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 to be honest I dont think this problem is related to the engine box at all , after comparing photos from other sites and reading similar posts I think the problem lies with the cowl . with the fuse level as per martns diagram the engine while looking from the side with cowl off definately has downthrust , and while looking from the top , plan view , the engine definately has right side thrust . Quote Link to comment Share on other sites More sharing options...
iqon Posted February 1, 2014 Share Posted February 1, 2014 i dont want the plane anymore, i want the phone....... Quote Link to comment Share on other sites More sharing options...
Masher Posted February 1, 2014 Share Posted February 1, 2014 There are times when we think - why are we doing this, it's less stressfull at work! Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 Posted by john melia 1 on 01/02/2014 16:33:56: to be honest I dont think this problem is related to the engine box at all , after comparing photos from other sites and reading similar posts I think the problem lies with the cowl . with the fuse level as per martns diagram the engine while looking from the side with cowl off definately has downthrust , and while looking from the top , plan view , the engine definately has right side thrust . I agree John. Quote Link to comment Share on other sites More sharing options...
Mark a Posted February 1, 2014 Share Posted February 1, 2014 Looks like the cowl is the problem, you may be able to fettle it so it sits a bit better in relation to the spinner. Edited By Mark a on 01/02/2014 18:18:15 Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 1, 2014 Share Posted February 1, 2014 Glad to see you are getting to the bottom of it. You still should get an incidence meter though. Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 mark I'm in the process of re-shaping the front of the cowl . cymaz I'm sure you're trying to flog me one Quote Link to comment Share on other sites More sharing options...
iqon Posted February 1, 2014 Share Posted February 1, 2014 Posted by john melia 1 on 01/02/2014 18:29:22: mark I'm in the process of re-shaping the front of the cowl . cymaz I'm sure you're trying to flog me one I think he has a box full, never felt the need for one myself Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 hehe yeh iqon I think he's got job lot of em Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 Posted by iqon on 01/02/2014 18:32:21: Posted by john melia 1 on 01/02/2014 18:29:22: mark I'm in the process of re-shaping the front of the cowl . cymaz I'm sure you're trying to flog me one I think he has a box full, never felt the need for one myself me neither, so long as it flies, that's good enough for me Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 I think its all about how deep you wanna delve , I'll stay close to the surface methinks Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 and just to top things off , I'm gonna congratulate myself on my 1000th post Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 1, 2014 Share Posted February 1, 2014 congrats there john........look's like you've been had by the little lad's across the watter with that there s/bach ......take your time with the maiden flight-I would do it without the cowling on...to make sure the the motor box is where it should be...then do the fettling up with the cowel...... ken Anderson.....ne....1...... fettling up dept. Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 thanks ken , but I've already fettled Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 John, you don't hang about! lets see it i agree Ken, I tend to maiden mine "unfinished" now - just in case! Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted February 1, 2014 Author Share Posted February 1, 2014 Here you go rich , needs sanding and a lick of paint , will two pack it on monday ........ Quote Link to comment Share on other sites More sharing options...
Rich too Posted February 1, 2014 Share Posted February 1, 2014 well done John, that's much better. I can't wait to hear the flight report! Rich Quote Link to comment Share on other sites More sharing options...
